Welcome to the North American Subaru Impreza Owners Club Friday March 6, 2015
Old 02-07-2005, 02:43 PM   #1
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
Default Let's make a complete compendium of big/rotated turbo kits.
GT35R
Perrin Performance - http://www.perrinperformance.com
Includes:
GT35R
Uppipe
Downpipe
Wastegate (Tial 44mm) (plumbed back into downpipe)
Gaskets
Oil/Water fittings
Intake with bigMAF
Adaptor piece to fit FMIC
Fits most FMICs
Price: $2700
Notes:
Turbo is not a 3" conical discharge GT35R.
Possible idle problems with provided intake.
Minor fitment issues.
Helix - http://www.gruppe-s.com
This kit is not out yet. The kit is projected to include:
GT35R
Uppipe
Downpipe
Wastegate (Tial 38mm or 44mm, possible adaptor)
Gaskets
Oil/Water fittings
Intake
Price: <$2500
Ultimate Racing - http://www.ultimate-racing.com
Includes:
GT35R
Upipe
Downpipe
Wategate (Tial 44mm) vented to atmosphere
Gaskets
Oil/Water fittings
Col Air Intake with MAF housing
Price: $3600
Notes:
Has reputation for good fitment.
Can be made to fit TMIC, traditional FMIC, or custom pipes.
GT30R
Includes:
GT30R
Uppipe
Downpipe
Gaskets
Oil/Water fittings
Intake with bigMAF
Fits most FMICs
Price: $2500
Notes:
Turbo is not a 3" conical discharge GT30R.
GT30R
Uppipe
Downpipe
Gaskets
Oil/Water fittings
Intake
Price: <$2500
Includes:
GT30R
Upipe
Downpipe
Wategate (Tial 38mm) vented to atmosphere
Gaskets
Oil/Water fittings
Codl Air Intake with MAF housing
Price: $3400
Notes:
Ultimate Racing recommends the GT35R for the sti, and if you insist on a smaller turbo, use their T3/T04E kit which offers similar performance as a GT30R for less, according to them.
Other
Element Tuning - http://www.elementtuning.com
GT65 kit
Includes:
"GT65" 65 lbs/min garret non-ball bearing turbo
Upipe
Downpipe
Wastegate (Turbosmart 38mm) plumbed back
Gaskets
Oil/Water fittings
Intake
Price: $2900
Notes:
Designed to work with Element Hydra, no MAF solution provided
upper charge pipes $300 option
APS - http://www.airpowersystems.com.au
TSR70 rotated mount
Includes:
70 lbs/min twin scroll ball bearing turbo
Uppipe
Downpipe adaptor (fits with APS downpipe)
Gaskets
Oil/Water fittings
Intake Adaptor
Price: $3000
Notes:
EWG can be plumbed back or vented to atmosphere
REQUIRES APS twinscroll headers for $800
Godspeed - http://www.godspeedinc.com
Includes:
Spec R 520, Spec R 650, or Spec R 750 ball bearing turbo (FP turbos)
GTSpec II header
Uppipe
Downpipe
Wastegate (Tial 44mm) plumbed back to downpipe
Gaskets
Oil/Water fittings
Inlet pipe/intake with air temp sensor
Outlet pipe for APS FMIC
Price - $3600
Greddy T67 - ???
Includes:
Mitsubishi 25G turbo
Uppipe adaptor
Downpipe
Wastegate (Greddy) vents to atmosphere
Gaskets
Oil fittings
outlet adaptor for Greddy FMIC
Price - $2500
T3/T4
Includes:
50-trim T3/T04E with .63 A/R Garret turbo
Uppipe
Downpipe
Gaskets
Oil/Water fittings
Cold Air Intake with MAF housing
Price: $2500
Notes:
Includes:
T3/T04S with .63 A/R Garret turbo
Uppipe
Downpipe
Gaskets
Oil/Water fittings
Price: $2600
Notes:
Bolt-on
AVO 450 (Bolt on, most bolt on wrx FMIC's will work)
AVO 500 (Bolt on, most bolt on wrx FMIC's will work)
AVO 600 (Bolt on, most bolt on wrx FMIC's will work)
APS SR50 (Bolt on, most bolt on wrx FMIC's will work)
APS SR55 (Bolt on, most bolt on wrx FMIC's will work)
Superzilla (Bolt on, most bolt on wrx FMIC's will work)
Superzilla 55 (Bolt on, most bolt on wrx FMIC's will work)
Superzilla 65 (Bolt on, most bolt on wrx FMIC's will work)
SBR GT10-14 (Bolt on, most bolt on wrx FMIC's will work)
FPGreen (Bolt on, most bolt on wrx FMIC's will work)
FPRed (Bolt on, most bolt on wrx FMIC's will work)
Capt Crunch is offline   Reply With Quote
Old 02-07-2005, 03:58 PM   #2
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Ultimate Racing GT series and T series turbo kits
'Big' Turbos--APS SR50/55, AVO 450/500, Deadbolt Superzilla 51lb/55lb wheels, SBR (Fullthrottle) GT10-14
Godspeed kit
Greddy t67 turbo kit
Blitz K-series turbo kit
HKS GT-RS turbo kit (internally gated)
Apexi i believe has one
Soon2Bgreat is offline   Reply With Quote
Old 02-07-2005, 04:18 PM   #3
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Not sure what the point of this is without at least links to threads or info. btw.
So...
www.ultimate-racing.com (~3500) GT30/35 35 has made 500+whp
www.kingpinperformance.com (~3500) 30/35 35 has made 500+whp
www.forcedperformance.com (~1500) Green has made 400+whp
www.perrinperformance.com FP 3052 has made ~400whp
www.gruppe-s.com (T67, HKS, Blitz) also www.mauromotorsports.com (~2500/~3000/?)
www.slowboyracing.com (~1400)
www.avoturbo.com (~1700) 450/500 500 has made 440whp
www.airpowersystems.com.au (~1800) sr50/sr55 55 has made 400+whp
There is obviously alot of data on many of these on many different dynos. It's going to be tough to decide how to organize everything and what to list exactly. It may be better to be more broad and list some good search terms. I don't know, maybe just add the missing ones to the turbo FAQ.
P.S. These are all off the top of my head so please correct me if i've made a mistake...i'll try and check these later and add more hopefully.
Old 02-07-2005, 04:37 PM   #4
Capt Crunch
Member#: 10852
thanks for the help S2BG
if you guys can help me find dyno sheets of all these setups and more specifics, post them and I'll update my post.
Old 02-07-2005, 04:43 PM   #5
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
http://forums.nasioc.com/forums/showthread.php?t=705831
Kingpin gt35 (atmoshpere dump wastegate)
http://forums.nasioc.com/forums/showthread.php?t=588640
Ultimate Racing gt35 (atmoshpere dump wastegate)
http://forums.nasioc.com/forums/showthread.php?t=710836
Perrin GT30
http://forums.nasioc.com/forums/showthread.php?t=710259
GT32
http://forums.nasioc.com/forums/show...ighlight=green
SBR GT11
http://forums.nasioc.com/forums/show...ghlight=avo500
SBR GT12
TXS Green on STi
FP Green on 2.0l sti motor
http://forums.nasioc.com/forums/show...=sr55+dynocomp
SR55 Results on a few cars iirc
Superzilla 49lb?
http://forums.nasioc.com/forums/showthread.php?t=650057
Gruppe-S gt30 (atmoshpere dump wastegate)
http://forums.nasioc.com/forums/show...ight=HKS+gt-rs
HKS GT-RS kit
AVO 500
AVO 600 (Forgot to add this turbo beforehand)
XS500=AVO 450
http://allwheeljunkies.com/modules.p...ewtopic&t=5552
Section 8 gt30/35 kits (wastegate rerouted to downpipe)
http://forums.nasioc.com/forums/show...highlight=dr65
APS DR65 (atmoshpere dump wastegate)
APS SR50
Forgot to add the APS DR55 and DR65 rotated mount setups.
EDIT: Element Tuning will be releasing a kit (thanks IRSFan). There is also GPmoto's GT40 turbo kit.
Alot of these are obviously not a great representation of what the turbo is truly capable of and what should 'normally' be expected out of it, these are just starting points.
Old 02-07-2005, 04:51 PM   #6
zinc99
Banned
Member#: 56030
02 stage 2 wagon
Sticky!!!! Now!!!!!!
zinc99 is offline   Reply With Quote
Old 02-07-2005, 05:17 PM   #7
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
ya this needs a sticky, it has some good info. Lots of companies are starting to release there big turbo kits now, and after riding in phils car this past weekend, im gonna have to buy one too I know hes working on one as well.
ImprezaRSfan! is offline   Reply With Quote
Old 02-07-2005, 05:38 PM   #8
Kingpin
Vendor
Member#: 41252
Twin 2005 600WHP
FormulaD/TimeAttack Sti's
We have three turbo kits. We have a GT kit, a T3T4 kit and a T04R kit. The only difference is the downpipe between the GT and T3/T4 kit as the T3T4 turbos use the 4 bolt T3 turbine. The T04R kit uses the T04 hotside and T04R compressor at 75 lbs a min. This kit is on our shop car now and is being tuned. The kit is not in production yet. The T3T4 kit can be had with just about any Trim T3T4 turbo you want for around $3000. The GT35R kit runs about $3800 and the G30R kit runs about $3600. Our kit has many options so price can vary alot. We offer HPC coating, choice of intake, bov and of course turbo trim. Its best to call me to get a qoute on exactly what you will need.
Clark
Kingpin is offline   Reply With Quote
Old 02-07-2005, 09:06 PM   #9
Soon2Bgreat
Member#: 2258
1999 gc8 ver7 6mt
GT35R 504.7whp;)
Internally Gated (Naturally offered this way)
AVO 450
AVO 500
AVO 600
APS SR50
APS SR55
Superzilla
SBR GT10-14
FPGreen
FPRed
HKS GT-RS
GPMoto GT32 (option either way iirc)
APS DR55/65
Externally Gated (Naturally offered)
GPMoto GT32
Perrin GT30/35
GPMoto GT40
Kingpin GT30/35/Tseries
Ult. Racing GT30/35/Tseries
Section 8 GT30/35
T67
APS DR55/65 (option either way iirc)
Godspeed GT30/35
Gruppe-S GT30
Preferred FMIC application:
APS DR55/65 (APS FMIC, adapter provided)
Kingpin (Kingpin FMIC, adapter available for APS)
Ult. Racing (Ult. Racing FMIC, adapter available for TMIC)
Section 8 (Sec. 8 FMIC, adapter available for TXS FMIC)
Perrin (Perrin FMIC adapter)
GPmoto 32 (GPmoto FMIC)
T67 (Adapter for Greddy FMIC)
Godspeed (Adapter for APS FMIC)
Gruppe-S (Adapter for APS FMIC)
*These are the already made available adapters or FMIC's from what i gathered in the threads. I'm sure many can provide adapter's that work with any FMIC. Many will also work with any FMIC even if not explicitly said so...it's just the vendor won't say so as they may not have tried it and can't 100% confirm it. Please consult the vendor obviously, this is simply a guidline.
Old 02-08-2005, 12:34 AM   #10
Capt Crunch
Member#: 10852
S2BG - thank you so much for your help, give me a day or so and I'll take all the info and try to formulate it into 1 giant post
Old 04-06-2006, 08:16 PM   #11
Capt Crunch
Member#: 10852
bump, with the new kits coming out, I refreshed the original post with what I think are the current kits out there.
feel free to add info, and PM me if you want info added. I like to put into the general consensus on kit quality in the Notes section.
Old 04-06-2006, 08:38 PM   #12
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
UR no longer plays with GT30r turbos.....
GruppeS no longer has one either....
jigga is offline   Reply With Quote
Old 04-06-2006, 08:44 PM   #13
Capt Crunch
Member#: 10852
it's still on their website, so I assumed they still carried it for the sti. I also removed Gruppe-S from the list.
Old 04-07-2006, 12:36 AM   #14
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
its there, but they don't play with it anymore... They now use that T3/T04 turbo instead, since it is much cheaper and not much lagier.
Old 04-08-2006, 02:25 PM   #15
o2sys
Member#: 43842
200? WRX STI
Angry
all GT32 reviews are on 2.5L blocks
o2sys is offline   Reply With Quote
Old 04-10-2006, 12:33 AM   #16
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
I think that's because most of these setups give a good bit of lag on a 2.0L...especially the ej205
Old 04-10-2006, 01:53 AM   #17
Poweredbysnail
Member#: 74753
2003 Wrx 2.5Lw/gt30r
Team Snail
this is great info
Poweredbysnail is offline   Reply With Quote
Old 04-10-2006, 10:35 AM   #18
Capt Crunch
Member#: 10852
I'll PM UR and ask if I should take it off. Thanks for letting me know.
To everyone: is there anything else I can add to make this more useful? I'm wary about adding dynoplots, because they are largely incomparable. Maybe pics?
Old 04-10-2006, 10:37 AM   #19
Capt Crunch
Member#: 10852
oh and mods, can I cross post this into the 2.5 forum? I think they would get some use out of this too.
Old 04-10-2006, 01:13 PM   #20
comradeboris
Member#: 33280
2005 STi
links to some sound clips of the external gated models would be interesting along with those pictures.
comradeboris is offline   Reply With Quote
Old 04-23-2006, 07:59 PM   #21
FNR32
Member#: 84147
03 WRX
I would really lie to know that a GT35R looks like on a stock 2.0 EJ20 if in fact the motor could hold it
FNR32 is offline   Reply With Quote
Old 04-23-2006, 10:46 PM   #22
wrxfactor
Member#: 49978
2002 WRX w/ JDM STi
6spd, EJ255, VF39 & EWG
Something something full spool at 5.5k revs something something?
Just a guess.
wrxfactor is offline   Reply With Quote
Old 05-03-2006, 12:42 AM   #23
Capt Crunch
Member#: 10852
the motor probably couldn't hold it.
Old 11-13-2006, 05:14 AM   #24
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
bumpity
WRXRallyBlue is offline   Reply With Quote
Old 11-19-2006, 10:16 PM   #25
WRXRallyBlue
Member#: 48831
2002 Protuned Wagon
Bugeyes Forever
bump. Is this information updated?
F.S.: Garrett 35r rotated turbo kit w/ 44mm tial EWG, DP, UP complete hock3yplay3r20 MWSOC Private Classifieds 1 06-30-2009 12:24 AM
FS: Huge Apex'i / IHI RX6d Complete Rotated Turbo Kit With Blitz Intercooler GT35R pirotlord Engine/Power/Exhaust 1 03-19-2009 02:10 PM
Any body have a review of the TXS Rotated turbo Kit ASU Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 30 10-15-2008 01:10 PM
FS: The mother of all rotated turbo kits HybridLove Engine/Power/Exhaust 13 03-30-2008 10:31 PM
rotated turbo kit? Who makes them reasonably priced? GTR STI Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 16 09-27-2004 05:23 PM
