Old 02-07-2005, 05:27 PM   #1
all-trubo [STi]
Member#: 41738
04 jbp sti
twinscroll
Default switching oil weight
well im at 50k on my sti, and it was suggested to me by a few folks to run a heavier weighted oil. maybe bumping up to a 10w-30 or 15w-50 or so. its time for me to change my oil, and im just wondering if i should or shouldnt do it. will a thicker oil not be consumed by the 2.5 or maybe not as much as the 5w-30?? i am curious.
btw, i did search for this topic and all i found were topics about the sti eating oil (which mine does as well) and people toasting their motors for not having/adding oil because of the consumption.
all-trubo [STi] is offline   Reply With Quote
Old 02-07-2005, 10:16 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
Please post in the right forum.
There are many experts on different facets of Subaru information. They tend to view and respond in the forums where their knowledge level is highest. By posting in the inappropriate forum, you are not only diluting the wrong forum, but short changing the search results of others and increasing the chances of an expert missing your question.
Old 02-07-2005, 10:20 PM   #3
scoobdude
Member#: 50699
2004 WRX
Platinum Silver
please check out www.bobistheoilguy.com this is pure oil and lube info
scoobdude is offline   Reply With Quote
Old 02-08-2005, 10:57 AM   #4
vvk
Member#: 6436
1998 Impreza 2.5RS
BDP
Impreza GC8 yes
Yes, given reports of increased oil consumption from others, I would recommend using something slightly more robust than low-HTHS 5W-30. If you'd like to stay with recommended viscosity for warranty retention, try using a 5W-30 oil with HTHS above 3.5. BMW 5W-30 comes to mind -- inexpensive and readily available at your friendly local BMW dealer.
An API-rated "high mileage" oil would do nicely, too. But look for one that has the right viscosity. For example, Valvoline MaxLife is NOT the one to use. Castrol GTX HM 5W-30 and Pennzoil HM 5W-30 both have slightly higher HTHS viscosity. Look for 5W-30 oil that does NOT indicate "Energy Conserving" on its label.
If warranty is not a concern, I would use German Castrol Syntec 0W-30, if you can find it. Or a more commonly available 10W-40 oil, such as new Mobil 1 EP 10W-40, Castrol Syntec 10W-40 or Valvoline Durablend 10W-40. For low-temperature environments use 5W-40, such as Valvoline SynPower 5W-40 available at PepBoys.
vvk is offline   Reply With Quote
Old 02-08-2005, 11:18 AM   #5
dsc
Member#: 15559
Use whatever weight the manual says to use. If the manual says 5W-30 it's because the clearances in the motor are designed for that viscosity. Using a heavier oil will result in reduced oil flow. Why would you want that?
Also, why is the motor using oil after only 50K miles? Is it a leak issue or a oil burning issue?
dsc is offline   Reply With Quote
Old 02-08-2005, 12:58 PM   #6
bluesubie
Member#: 767
04 FXT
The manual lists many weights. 5W30 is "preferred" for better fuel economy, but 10W30 and 10W40 are probably listed on the temp. chart for higher temps. It also probably says that oil of a higher viscosity is required to properly lubricate the engine in high temps.
I would not use less than a 10W30 in So. Cal.
-Dennis
Old 02-08-2005, 03:20 PM   #7
all-trubo [STi]
Member#: 41738
04 jbp sti
twinscroll
im positive its not a leak, its just consuming it. it was very minimal but now its about 1qt every 1k miles.
Old 02-09-2005, 11:16 AM   #8
dsc
Member#: 15559
Bummer. Is that a common problem with STi motors?
Just curious - Are you using synthetic oil? I know that synthetics are more prone to leak, but I've not heard that they are any more likely to get consumed by the engine.
Old 02-09-2005, 12:49 PM   #9
bluesubie
Member#: 767
04 FXT
I'm really starting to believe it has to do with so many STi owner's using 5W30, regardless of their driving habits or where they live. A lot of STi owner's probably use Mobil1 5W30 and, going back to vvk's points, it has a low HTHS (3.08).
If you drive in high heat, drive hard, drive in stop and go traffic, etc., M1 5W30 is probably going to shear down close to a low 30 or high 20 weight. It happened with my FXT last summer.
-Dennis
Old 02-09-2005, 05:01 PM   #10
stripperluva
Member#: 64073
2004 WRX STI
Aspen white
My '04 burns 1 quart every 1500 miles right now and the subie dealer says 1 qrt per 1000 miles is acceptable.
........I am thinking bullsh**
stripperluva is offline   Reply With Quote
Old 02-09-2005, 08:56 PM   #11
Hayes
Member#: 11808
I think 1000 miles per quart is BS too. That is the number General Motores told their dealers to say when that had big oil consumption problems in the 50s and 60s. eddie
Hayes is offline   Reply With Quote
Old 02-10-2005, 03:18 PM   #12
poison
Member#: 37678
Bull****. They say 5/30 to meet CAFE requirements. If the 'tolerances were designed for a 5/30', then why the **** do Brits run 15/50 in the same car no problem?
i love oil old wives tales: "My granpappy said..."
poison is online now   Reply With Quote
Old 02-10-2005, 05:42 PM   #13
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
10w30 is the lightest I'd run...especially M1....the 5w30 M1 is like water....
The truck/suv 5w40 is the next change fro me.
Old 02-10-2005, 06:58 PM   #14
poison
Member#: 37678
MMMMM, 5/40 t&s, good stuff, maybe the best. That will be my next change after I use my stash of 10 German Castrol 0/30.
Old 02-11-2005, 03:17 PM   #15
dsc
Member#: 15559
Well, poison clearly knows his oil. Otherwise, he wouldn't be cussing about it. I mean, if I've got someone cussing at me about oil, you better believe I'm going with him over the manufacturer's recommendations every time.
All kidding aside, I think that it might be true that Subaru recommends 5w30 to help its CAFE numbers. That is why I use 10w30 in the Impreza. The book says either is OK.
poison, are you saying that 15w50 is a good weight to use in an Impreza? If so, why wouldn't 80w90 be even better?
Old 02-11-2005, 03:38 PM   #16
bluesubie
Member#: 767
04 FXT
I'm thinking of trying the T&SUV 5W40, but wondering if it will be just a hair too thick. Maybe the 0W40 for me.
dsc - What do you mean by "over the manufacturers recommendation"? Just check your owner's manual. For the FXT, there is a temp chart that says 5W30 is "preferred", then you will see 10W30 and 10W40 on the chart for use in higher temps.
After that it states: "engine oil viscosity (thickness) affects fuel economy. Oils of lower viscosity provide better fuel economy. However, in hot weather, oil of a higher viscosity is required to properly lubricate the engine." My manual then goes on to list the following viscosities for severe driving conditions: SAE30, 40, 10W50, 20W40, and 20W50. I believe most Subaru's show a similar range of viscosity in the manual.
Remember, just because 5W30 is on the oil fill cap doesn't mean that you can't use something thicker. All of our choices wouldn't be able to fit on the oil cap.
-Dennis
p.s. - poison does know his oil, he's just a little passionate.
Old 02-11-2005, 03:53 PM   #17
WRXout
Member#: 52908
2005 WRX STI FTI 20G
ASPEN WHITE
i use syntec 10w-30 on my sti, no oil consumption :knock on wood: 10995 miels
WRXout is offline   Reply With Quote
Old 02-11-2005, 03:53 PM   #18
subenerd
Member#: 72630
2004 STi
Ive been using redline 5w30 for about 34k miles and have been thinking of moving to 10w30. Car runs good, doesnt burn barely anything unless Im very hard on it. The engine seems loud, maybe I could use thicker oil, I dunno...oil specs make my head spin
subenerd is offline   Reply With Quote
Old 02-11-2005, 04:05 PM   #19
bluesubie
Member#: 767
04 FXT
Redline 5W30 is thickAr than M1 10W30 at 100C, and has a higher high temp high shear viscosity as well. Must be those polyol ester base stocks.
My head is spinning too.
-Dennis
Old 02-11-2005, 04:13 PM   #20
dsc
Member#: 15559
Originally Posted by bluesubie
...dsc - What do you mean by "over the manufacturers recommendation"? Just check your owner's manual. For the FXT, there is a temp chart that says 5W30 is "preferred", then you will see 10W30 and 10W40 on the chart for use in higher temps.
I assume that we are talking about normal driving conditions. As I recall, 5W30 and 10W30 are the only viscosities recommended for normal driving conditions. Those heavier oils are only recommended for high temperature driving. Aren't they? I don't have the book handy, so I stand to be corrected.
True.
I'm sure he does. I was just jerking his chain.
Old 02-11-2005, 04:36 PM   #21
subenerd
Member#: 72630
2004 STi
would 10w make the engine a bit quieter?
Old 02-12-2005, 01:15 AM   #22
poison
Member#: 37678
I apologise for my show of passion over oil.
15-50 would probably run ok in a hot climate, but with reduced gas mileage. Of course 80-90 would choke it, or kill it with the lack of start up protection. But I am pretty sure that the only place Subaru specs a 5/30 for pretty much all temps is in the US and that is because of CAFE. Elsewhere they spec the oils best for the engine.
By the way, the Mobil 1 T&S is rumored to be the same as or similar to the Mobil Delvac 1, a fully synthetic diesel/gas mixed fleet heavy duty engine oil. Pretty much the holy grail for outstanding protection and long OCI's.
vvk, who is on BITOG, here also, I think, has a 2.5L and has run a lot of different oils, with Redline 5/40 producing the best oil analysis. A lot of Suby owners seem to get good results with Redline.
Old 02-12-2005, 11:50 AM   #23
Silver04WRX
Member#: 37644
2009 Legacy 2.5i
-Dennis
Yeah...when I was looking into oils, I noticed that Mobil1 10W30 was somewhere in between Redline 5W30 and 10W30. I guess you can't always go directly off weights...I'm definitely gonna try M1 10W30 next oil change. It doesn't seem like a huge jump from M1 5W30....which is thin already.
Silver04WRX is offline   Reply With Quote
Old 02-14-2005, 04:12 PM   #24
dsc
Member#: 15559
No sweat.
Sounds reasonable. The point I was trying to make is that I don't have the resources to do the testing needed to know which oil to use, so I have a hard time departing from the manufacturer's recommendations. Sometimes the manufacturer's recommendations don't make a lot of sense. I think the book that came with my 1997 Impreza said to use 5W-30 for all temperatures, but permitted 10W-30 so long as the temperature does not exceed 90 F, or something like that. That recommendation makes no sense to me because 5W-30 and 10W-30 are supposed to act the same way at high temps. The difference between those oils is at low temps. Isn't it? I think that book is probably a good example of the recommendation being driven by CAFE rather than what's best for the motor.
I just bought a 1998 Honda Accord for the wife. It has the 2.3 litre VTEC 4-cylinder. What a sweet running motor. The book recommends 5W-30 "Energy Conserving" oil. It also says, "You may use a 10W-30 oil if the temperature in your area never goes below 20 degrees F (-7 C)." Now, what in the heck do I do with that information? I am inclined to use 5W-30 from November through March and 10W-30 the rest of the time. See any problem with doing that? I will probably use Mobil 1 because it is readily available, but I might use Amsoil.
Old 02-14-2005, 04:51 PM   #25
bluesubie
Member#: 767
04 FXT
The SAE has a range for each oil viscosity. This Advance Auto Parts site has good info.
"SAE 30 is SAE 30 no matter what the "W" prefix number is: 0W, 5W or 10W. This viscosity in centistokes (cSt) @ 100 degrees C is with the minimum of 9.3 cSt and a maximum of 12.5 cSt."
You can have two 5W30's with the thickness of one on the lower end of the range and the other on the higher end. Generally speaking, the one on the higher end will probably give you more protection. For example, M1 10W30 is 10.0 Cst @ 100C and German Syntec 0W30 is around 12.3 (IIRC). You're probably going to get better protection from the Syntec (then there's additives, base stocks, etc.).
You would think that all 30 weights would be the same, but that's not the case.
-Dennis
Oil Weight 10w30? or 15w50 ? Clegg Mid West Subaru Owners Club Forum -- MWSOC 2 06-24-2002 12:27 PM
Oil weight and filter for '02 WRX WRXforME Service & Maintenance 1 02-18-2002 03:31 PM
Proper oil weights? Chubler Transmission (AT/MT) & Driveline 1 10-11-2001 02:57 PM
Oil weight for high performance cars Jon Bogert Normally Aspirated Powertrain 22 02-26-2001 12:36 AM
