#1 |
Member#: 79885
Vehicle:2004 wrx java black pearl |
I just changed oil about 3 weeks ago and now everytime i try to check the oil level it reads low. How is that when I just changed oil? Also when is the best time to check the oil level. Now I'm not sure if I'm running my car with not enough oil. I used mobil1 5w-30 and i put the whole galon which is suppose to be 5 quarts in there. What could be the problem?
#2 |
Member#: 71829
Vehicle:2002 Subaru WRX black with pearl blue |
Mine does the same thing... I heard that its normal (that is if you get on it a lot)
#3 |
Member#: 74894
same for me, changed it out with mobil 1 5w30 about 2k miles ago and it was also pretty low .i just make sure to check it every week and add oil as needed
#4 |
Member#: 11808
What do you call low? Engine oil level is good if between the holes when cold or warm and at or below the notch when HOT.
#5 |
Trust no one
Moderator Member#: 11170
Vehicle:02 WRX 05 GTO/11 Sonata(!) |
Um, a gallon is only four quarts, not five. If you put the contents of a gallon container in and no more then you underfilled it. The capacity is 4.8 qts.
| Thread Tools | |
| Display Modes | |
| WTB: complete wiring harness or plugs for the HID Leveling motors and leveling switch | Speedoponic | Private 'Wanted' Classifieds | 2 | 06-17-2009 11:11 PM |
| Can I monitor oil level with an oil pressure gauge? | vapore0n | General Community | 9 | 10-22-2004 11:27 AM |
| Oil Level Problems | Dougie01 | Factory 2.5L Turbo Powertrain | 1 | 02-16-2004 09:12 PM |
| motor oil level | mopman2 | New England Impreza Club Forum -- NESIC | 9 | 06-10-2003 11:47 AM |
| Problems switching to synthetic motor oil? | bigbird | General Forum Archive | 10 | 01-23-2001 09:15 AM |
