Welcome to the North American Subaru Impreza Owners Club Wednesday August 20, 2014
Old 02-08-2005, 04:09 AM   #1
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
426whp aspen / 340whp psm
Default Aluminium Control Arms on WRS swap
Hello
I had done swap into my 2000 RS 2door now I want to use Aluminium control arms on my Rs from wrx sti.
The Crosmember is from wrx and right now i have rs control arms with washers. I wanted to change to wrx Sti aluminium control arms.
Would there be any problem with alignment or fitting them in?
They should go in the wider wrx crosmember space and i wont be needing washers.
Any problem with replacing them with STI ones?
Thank you
Ireneusz is offline   Reply With Quote
Old 02-08-2005, 10:37 AM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
the sti arms are 20(?)cm wider will make for wacky alignment
Old 02-08-2005, 11:07 AM   #3
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
Jaxx is right. If you use the GD Sti arms, you will get a crap load of negative camber. You will have to do some serious grinding to get back a decent alignment because the stock eccentric wasn't enough.
Ver.III is offline   Reply With Quote
Old 02-08-2005, 11:11 AM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I put some GD ones up to a set of RS ones the other day and the difference didn't seem to be that great. 20cm would be lowrider territory, I think the difference is somewhere between 5-10mm. I know it doesn't have to be very large to make things off quite a bit, but it seemed correctable with a set of camber plates. It was wide enough though that I don't think it's correctable within the sweep of the stock camber bolts.
Old 02-08-2005, 11:53 AM   #5
mrbell
Member#: 1871
2000 Impreza 2.5RS
Blue Ridge Pearl
it's about 20mm, not 20cm... but that's divided in two, so about 10mm per side, I believe...
mrbell is offline   Reply With Quote
Old 02-08-2005, 10:08 PM   #6
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
So what do you guys recomend not using ati auminium arms just keep the steel RS ones with washers.
How about old 2000 wrx sti from japan maybe they will fit but what about the wide gap on the mount where i got washers .
Does anyone know what would be best to fit them on (STI) arms.
Thanks
Old 02-09-2005, 11:46 AM   #7
MyFirstDeuce
Member#: 50193
1999 Rubasu Ziprema
Silverthorne
so its not recommended to use WRX control arms with a WRX front crossmember on a RS chassis?
I recently purchased a motor and got the WRX front Xmember with control arms and everything. Should i 'shim' the crossmember so I can use the stock RS arms or would I be ok with the WRX setup?
Are we just talking about GD STI arms. . or GD arms in general . . on a RS?
-al
MyFirstDeuce is offline   Reply With Quote
Old 02-09-2005, 12:30 PM   #8
RokketRide
Member#: 17984
1967 Barracuda
GD Sedan arms on an old school chassis is not going to work well. Like was stated earlier, the wider track will make for some really goofy negative camber that would be lousy on the street.
RokketRide is offline   Reply With Quote
Old 02-09-2005, 03:17 PM   #9
MyFirstDeuce
Member#: 50193
1999 Rubasu Ziprema
Silverthorne
Rokket. Thanks for the info.
Old 02-10-2005, 02:02 AM   #10
Ireneusz
Member#: 34464
1994 GC8STI /FXTSTI
Thanks for info i will stay with shimed RS arms
aluminium control arm differences zuczek Brakes, Steering & Suspension 333 01-24-2014 12:22 AM
GC8 STi aluminium control arms. S.G.D Private 'For Sale' Classifieds 18 10-08-2005 01:00 PM
FS Indiana: V8 USDM STi Aluminium Control Arms keirnna Private 'For Sale' Classifieds 6 06-20-2005 09:11 AM
FS or Trade: 2004 STi Aluminium Control Arms keirnna Private 'For Sale' Classifieds 0 06-17-2005 07:43 AM
Aluminium Control Arms MSo Brakes, Steering & Suspension 8 04-03-2005 11:52 AM
