Old 02-08-2005, 11:33 AM   #1
daytontp
Member#: 9797
2005 Honda S2000
New Formula Red
Default I need an A/C Compressor Clutch
I own a 2002 WRX sedan and I need to replace the clutch piece on my A/C compressor. I had an AutoMeter Oil Pressure sendor tied to a brace piece on the compressor housing. Over time the crimp seal on the sendor started to leak oil on my engine. So, I removed it. Then about 6 months ot a year later, the bearing in the clutch started making noise. To the point where I no longer have the A/C belt on the car anymore. I am not sure if the compressor went bad due to the oil or over tightening the belt or just a bad part. The sendor was on the car for over a year without an issue. By the way, the A/C still works great even though the clutch made noise. Which it did with the A/C turned on and off.
Anyway, you can not buy the clutch as a part from the dealer, you have to buy the whole compressor and clutch together for around $450. So, I want to buy just the clutch and replace one part. If I replace the compressor, the system needs to be recharged.
So, does anyone have an idea where I can find this part?
Here is my gauge setup when it was on the car.
http://www.pbase.com/daytontp/gauge_parts_stuff
daytontp is offline   Reply With Quote
Old 02-08-2005, 11:55 AM   #2
phijar
Member#: 26835
I have a V7 a/c compressor sitting around, make an offer if you are interested in it. I believe it is identical to the USDM unit, I removed a/c so it is not being used just sitting. Came with the motor purchased form IA performance.
phijar is offline   Reply With Quote
I Need An A/c Compressor TWR3CKS TXIC Private Classifieds 8 06-15-2009 12:56 AM
AC compressor clutch / compressor smeghead Private 'Wanted' Classifieds 11 10-01-2007 12:53 PM
WTB - 2002 WRX A/C Compressor / A/C Compressor Clutch wetwilly1169 Private 'Wanted' Classifieds 0 06-16-2007 02:17 PM
I need an A/C Compressor....ASAP... RollingOnAll4 South East Region Forum 17 06-20-2005 08:48 PM
Anybody equipping a garage need an air compressor? Neek Off-Topic 6 05-13-2005 10:51 AM
