Vancouver Impreza Club
Old 02-08-2005, 01:21 PM   #1
alfy06
Member#: 70416
Rally Blue
Unhappy Need Some HELP!!!!!!!
Hi guys need some help with my car.. my turbo in my car is not working, the boost is not there, but the vacuum portion is. Does anyone know what is happening? Please help thank you! The car has no power
alfy06 is offline   Reply With Quote
Old 02-08-2005, 01:26 PM   #2
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Should have bought a STi ...haha...
What makes you think the turbo is not working? The boost gauge is showing vaccum yet the boost isn't there? Any recent work on the car? You might have a boost leak but you should still be getting boost AND vaccum.
fukamoto is offline   Reply With Quote
Old 02-08-2005, 01:31 PM   #3
alfy06
Member#: 70416
Rally Blue
The only thing that was done recent is putting the gauge in my car.. on the gauge it only reads the vaccum and not the boost...No boost is goin in..!!!!
Old 02-08-2005, 01:37 PM   #4
tora
Member#: 5851
09 Forester XT
+ NA Miata
Doe sit feel like the turbo is working or are you relying on your guage? Was the guage installed proper?
tora is offline   Reply With Quote
Old 02-08-2005, 01:41 PM   #5
alfy06
Member#: 70416
Rally Blue
No the turbo does not feel like its working properly my blow off value doesn't even relesae any air.... i'm not sure it happen to me last night while i was driving home and notice a big power diffrent, it was pedal to the metal and the car wasn't even moving.. Can anyone HELP????
Old 02-08-2005, 02:09 PM   #6
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Isn't the stock BOV 100% recirculating? It might be hard to hear it. If you installed an aftermarket BOV and just recently installed a boost gauge, are you sure you installed it properly? WHen you put the pedal to the metal, were you on a low gear or were you flooring it on 4th/5th. When you are on second gear at 3,500RPM for a few seconds, step on the gas all the way and see if you are getting a pull. If your turbo isn't working, it shouldn't even pull at all, but if it is, it should be a good pull in this gear at those RPM's. Just my .02
Old 02-08-2005, 02:13 PM   #7
alfy06
Member#: 70416
Rally Blue
No i'm not running a stock BOV i'm running Blitz its been install quite a long time. i'm not sure if the guages have to do anything with the power lost? On low gear and car does not give the pull. Even when i start off in 1st the car does not even pull.. i'm scared its the turbo went on the car.. Is there a shop i can bring it down too that can help me out???
Old 02-08-2005, 04:36 PM   #8
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Which vaccum line did you cut when you installed your boost gauge?
Old 02-08-2005, 06:21 PM   #9
alfy06
Member#: 70416
Rally Blue
The one runs off the BOV
Old 02-08-2005, 09:53 PM   #10
Ricewagon
Member#: 59703
2004 STi
always wrb
Just undo what you did when you installed your guage and see if the boost returns.
Ricewagon is offline   Reply With Quote
Old 02-08-2005, 10:07 PM   #11
alfy06
Member#: 70416
Rally Blue
Nope undid the guage and the boost is still not there! awwwwwwwh grrrrrrrrrrrrr! its pissing me off!
Old 02-08-2005, 11:40 PM   #12
veightkiller
Member#: 78967
2011 335i
that's odd..you have some vaccum readings but no boost..if it has a leak ..you should have boost like 5psi or lower than stock.....what the F is that i haven't heard such a thing...but you might want to check ur wastegate maybe it's broken or something...as far as i know the wastegate is the one holding the pressure on ur turbo..instead of producing boost it open's right away..and that's my best bet but im not putting my finger on it ...oh well good luck
veightkiller is offline   Reply With Quote
Old 02-09-2005, 01:28 AM   #13
polaris
Member#: 66663
2011 VW GTI
maybe '15 STI?
Dont you have warranty still? Take it to a dealer....ones not in Richmond
polaris is offline   Reply With Quote
Old 02-09-2005, 05:35 AM   #14
alfy06
Member#: 70416
Rally Blue
Yes its still under warranty but don't i have to put everything back to stock before i can take it down the dealership?
Old 02-09-2005, 05:40 AM   #15
fukamoto
Member#: 13339
2014 SWP WRX Wagon
Yes...
Old 02-09-2005, 09:59 PM   #16
alfy06
Member#: 70416
Rally Blue
Yes...
ok thats goin to suck trying to put everything back to stock! damn it!
Old 02-09-2005, 10:05 PM   #17
Ken
Member#: 34
2005 WRX STi
World Rally Blue
u fubar'd it go pay and get it fixed.
Ken is offline   Reply With Quote
Old 02-10-2005, 06:12 AM   #18
bwco
Member#: 44137
I think you're having the same problem as one of my friend's.
He has a Blitz BOV on his 02' wrx. That's it !
Somehow, the Blitz BOV screwed up his turbo wastegate.
It's like, his car is slower than a echo. No positive boost. Max is 0 psi. Turbo wasn't working. No matter how hard you press the gas, it's a constant acceleration. A slow one !
You should really remove your Blitz BOV and get it fixed by the dealer. Otherwise, the fix is over $1k at private shops.
My friend's car was reported to have a clogged catalytic covertor and a damaged wastegate. I don't understand what he said, but he told me that it's something doing with his Blitz bov.
bwco is offline   Reply With Quote
Old 02-11-2005, 03:43 AM   #19
alfy06
Member#: 70416
Rally Blue
Hey thnx for the info.. but yeah i have the exact same problem as your friend.. i just remove my blitz BOV and turn the car back to stock and i'm sending it back to the dealer to have it check out!
Need some help please cel plus more!!!! thrasher679 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-04-2010 10:21 AM
New WRX and need some help on some mods 02WRXguy Texas Impreza Club Forum -- TXIC 19 07-17-2002 12:49 AM
Need some help choosing some upgrades FlaaB Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 06-04-2002 01:00 PM
Possible Impreza purchase, have some ?'s, need some help. STi2001 Normally Aspirated with bolt-on Forced Induction Powertrain 4 10-15-2001 12:10 AM
I need some help and some answers coloradobound Normally Aspirated Powertrain 3 02-23-2001 03:01 PM
