Old 02-08-2005, 12:51 PM   #1
phunkeeHomosapien
Member#: 56061
Default Walbro pumpo in gf8?
K so i went to install my walbro 255lph fuel pump today that i got from some one who was using it on a 2002 wrx, using the instructions that are on scoobymods and i come to find out that the 93 wagon doesnt use a clip but rather just a positive and negative hookup do i have the wrong pump and if not what do i do to connect it?
phunkeeHomosapien is offline   Reply With Quote
Old 02-08-2005, 03:25 PM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
A: that is the wrong pump (multi speed vs single speed) it could melt leaving you stranded
B: you can get the harness/ from the junk yard from any mid 90s honda
Old 02-09-2005, 10:21 AM   #3
phunkeeHomosapien
Member#: 56061
so i need the single speed?
also i have a wrecked 98 2.5rs should i just pull the fuel pump assembly out of that?
Old 02-09-2005, 10:58 AM   #4
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
what motor do you have
unless you have a wrx ecu/ fuel pump contoler
you need the single speed version
Old 02-09-2005, 01:29 PM   #5
scobaru
Member#: 31345
05 LGT, GC8, NA
blue, white, blue
humm this is intresting... I have a 94 impreza L with a JDM WRX swap and I Want to upgrade to a walbro 255lph fuel pump orginally I was running a WRX fuel pump and IIRC my car doesn't use a fuel controller like the WRX's. can WRX's run the single speed verison? how would I know if its the single speed verison if I'm buying it used?
scobaru is offline   Reply With Quote
Old 02-09-2005, 02:30 PM   #6
phunkeeHomosapien
Member#: 56061
ej20g with the wrx ecu
Old 02-10-2005, 08:41 AM   #7
phunkeeHomosapien
Member#: 56061
anyone?
Some thoughts on Walbro 255 in Baja Baja_Gernaut Baja Forum 12 05-14-2010 11:48 PM
07 sti springs in gf8 scoobyoutback73 Brakes, Steering & Suspension 0 04-30-2010 06:53 PM
FS: GM-style Walbro 255L In-tank fuel pump MTS Non-Subaru Stuff 2 11-30-2007 01:26 AM
rs hood in gf8 hatch edr0ck Interior & Exterior Modification 4 01-02-2005 09:44 PM
Stereo install in GF8 94GF8 Car Audio, Video & Security 1 09-17-2003 11:57 PM
