Old 07-14-2001, 05:17 AM   #1
STEALTH-WRX
Member#: 7822
Multi layer snot green
Default how do i get really loud turbo whine?
how do i cover up the volkswagen like exhaust noise and hear the turbo whine from the exhaust. i dont really know much, but i heard a turbo supra and it had a really really loud turbo spool. what do i do to get that noise. thanks for any help
STEALTH-WRX is offline   Reply With Quote
Old 07-14-2001, 05:53 AM   #2
illmatic
Member#: 3536
2015 IMS BRZ Limited
2002/2003 AW/PSM WRX
Take out the intake silencer, get an intake, or get a ball bearing turbo.
illmatic is offline   Reply With Quote
Old 07-14-2001, 09:56 AM   #3
gossamer_monster
Member#: 3574
Blase' Yellow----R.I.P.
A turbo back exhaust will help also.
I just put my BPM MKIII system on and you can here the turbo all the time. Even through the tail pipe.
Bill
*edit*
My girlfriend`s car is a a 1.8T Jetta and boy can you hear the turbo whine. Her car turbo is still louder then mine. So I wouldn`t go comparing it to a VW.
gossamer_monster is offline   Reply With Quote
Old 07-14-2001, 12:11 PM   #4
blaster88
Member#: 1109
1999 Suzuki Samurai
Blackish
Drain all the oil out.
It'll whine like crazy!
blaster88 is offline   Reply With Quote
Old 07-15-2001, 12:59 AM   #5
The Real Oaf
Member#: 6608
1996 Legacy Outback
Unhappy
You want whine? Follow these simple instructions.
1. Cut a 3" section from a coat hanger.
2. Remove your intake boot & insert the coat hanger piece.
3. Button everything back up & start the motor.
Don't ask how I know that this works, it still hurts to think about.
The Real Oaf is offline   Reply With Quote
Old 07-15-2001, 10:05 AM   #6
gossamer_monster
Member#: 3574
Bill
Old 07-15-2001, 01:10 PM   #7
wrxcanada
Member#: 4450
Stealth-WRX,
I'm no expert, but I think part of your answer is in the BOV. This won't give you a lot of whine, but you will get that loud blow off of air sound. Check out the TurboXS page for more information.
The valve vents to atmosphere at sound pressure levels in excess of 110 db making it one of the loudest on the market. If you want a Blow Off Valve that looks, sounds and performs like no other blow off valve available in the market today, get the TurboXS Blow Off Valve Type H.
wrxcanada is offline   Reply With Quote
Old 07-15-2001, 01:54 PM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Get a 3" exhaust with no cats, no resontaor, and no muffler. You hear it perfectly that way.
Old 07-16-2001, 11:08 AM   #9
WRXeFEX
Member#: 8215
2002 Impreza WRX
WR Blue
Thumbs up
I did the 3" exhaust with a Apexi Dunk muffler with no cats and my car sounds like a mack truck. You can hear the turbo crusing in every gear
WRXeFEX is offline   Reply With Quote
Old 07-16-2001, 11:28 AM   #10
NoLimitWRX
Member#: 6927
2016 WRX
Talking
I just put on my BPM mkiii too!!!!
Boy does it sound S W E E T!!!
NoLimitWRX is offline   Reply With Quote
How do you get contaminated parts, really, perfectly, verifiably clean? williaty Built Motor Discussion 3 01-07-2011 11:55 PM
How do you get through really hard times? BhamRoadrunner Off-Topic 116 04-25-2007 12:21 PM
walbro getting really loud. stu Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 10 06-07-2006 10:26 AM
Loud turbo whine cause found. Pictures and video. powerlabs Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 10-04-2005 03:28 PM
Loud turbo whine / noice at idle Bill_WRX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 09-13-2002 06:32 PM
