Vancouver Impreza Club
Old 02-08-2005, 08:24 PM   #1
GoGoGo
Member#: 17508
2000 RS 2.5 Sedan
Blue Ridge Pearl
Default self changing a set of tires, ok?
em a newbie for rims & tires,
recently got a set of new rims + tires,
should i or should i not to put them on myself???
ne thing related to balancing stuff that i couldn't do by myself.??
and is it safe?
GoGoGo is offline   Reply With Quote
Old 02-08-2005, 08:28 PM   #2
tora
Member#: 5851
09 Forester XT
+ NA Miata
Are the tires mounted on the rims? Do you have a mounting and/or balance device? If the tires are already mounted and balanced then it is very simple to just put it on the car.
tora is offline   Reply With Quote
Old 02-08-2005, 08:37 PM   #3
GoGoGo
Member#: 17508
2000 RS 2.5 Sedan
Blue Ridge Pearl
o, the tires are already mounted on the rims,
Old 02-08-2005, 08:42 PM   #4
GlobalWaste
Member#: 74792
then you can simply mount them on but you might want to get them balanced first (unless you have the proper equipment which I doubt, I don't think you can do it on your own)
GlobalWaste is offline   Reply With Quote
Old 02-08-2005, 09:26 PM   #5
420WRX
Member#: 27752
2004 WRX+Ver.8 EJ207
Plus there's the whole 'how tight' part that requires a tourqe wrench if you aren't used to putting on wheels.
And just cause it seems easy to lift a wheel/tire combo, it's an entirely different thing to hold it at the exact height you need and then rotate it to match the studs. You might want to take your time and expect some cursing.
420WRX is offline   Reply With Quote
Old 02-08-2005, 09:48 PM   #6
GoGoGo
Member#: 17508
2000 RS 2.5 Sedan
Blue Ridge Pearl
o, sounds like i better not doing it myself,
any shop that's cheap for tire installation?
also, does the 02-04 wrx rims fit 00 rs? or even ts??!!
heard that the offset's a bit different! is that the case??
how far off can offset be ?
Old 02-08-2005, 09:48 PM   #7
GoGoGo
Member#: 17508
2000 RS 2.5 Sedan
Blue Ridge Pearl
o, forgot to say; THANKS!!!!!!!!!!!
Old 02-08-2005, 10:00 PM   #8
Ken
Member#: 34
2005 WRX STi
World Rally Blue
cheap != quality mounting
Go see Bender at OK Tire on Marine.
Ken is offline   Reply With Quote
Old 02-08-2005, 10:05 PM   #9
imprezaboi
Member#: 7382
MY01 GC8 - 4
BRP
Tons, go to Ok tire on marine, bender works there and he'll either hook you up or overcharge you so be nice to him.
Yes they will fit both.
No they are the same.
It depends on things like camber, fenders and how far you want them to stick out. You can go anywhere from 45 to 55 (maybe more I can't remember)
imprezaboi is offline   Reply With Quote
Old 02-08-2005, 10:06 PM   #10
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
Come on now, if you can't put your own tires on, you'll be deemed a wuss.
Do you want a bunch of random internet geeks to think you're a wuss?
It's a very simple procedure to do.
Aside from the safety stuff like jack stand placement, and torque specs, all you're doing is removing 5 bolts per corner. Remove the old wheel, put the new one on, re-install the lugnuts, and you're done. It's like changing a tire, except you're not on the side of the highway, you're in the safety of your own driveway.
steve is offline   Reply With Quote
Old 02-08-2005, 10:31 PM   #11
veightkiller
Member#: 78967
2011 335i
i believe the guy doesn't have croc.jack and a jack stand or even a socket //anyways it's too easy installing tires men..
veightkiller is offline   Reply With Quote
Old 02-08-2005, 10:39 PM   #12
GoGoGo
Member#: 17508
2000 RS 2.5 Sedan
Blue Ridge Pearl
i only have the sub jack for putting up the spare tire~
Old 02-08-2005, 10:48 PM   #13
veightkiller
Member#: 78967
2011 335i
you can use that but it will take you too long men...just get it done with some tire-shop's to be safe..its your lost though co'z u'll be paying them for a simple job...
goodluck
Old 02-08-2005, 11:14 PM   #14
420WRX
Member#: 27752
Well it's either that or go on a spree and buy all the crap you need?
I did that.. I have 8 wheels, 16 tires, trolley jack, stands, wheel blocks, air compressor and a complete air tool kit with everything I need. I just swap the winter/summer wheel sets and if I wanted to do something nasty I have some crap tires, plus the OE RE92s to abuse. I just have to pay someone to have the tires swapped cause I didn't buy the tire machine. Yet.
Old 02-08-2005, 11:23 PM   #15
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
You need one of these.
The dyno, not the integra.
Old 02-08-2005, 11:33 PM   #16
420WRX
Member#: 27752
Hells no! Then I'd have all these lewzers with 2 wheel drive cars hanging out at my place. Hahaha
Yeah an AWD dyno would kick ass, but it's even more expensive than a tire machine.
Old 02-08-2005, 11:37 PM   #17
GoGoGo
Member#: 17508
2000 RS 2.5 Sedan
Blue Ridge Pearl
holy~
how much it cost to switch a set of tires?
i'd rather not to invest my such a dyno
Old 02-08-2005, 11:59 PM   #18
alexs001
Member#: 8096
1998 Impreza 2.5RSTi
Rally Blue Pearl
I think $20 would be a reasonable price to simply swap your wheels. More if they need to be balanced...
alexs001 is offline   Reply With Quote
Old 02-09-2005, 01:14 AM   #19
anonymous_wolf
Member#: 57780
2000 RS sedan, GC6
Blue Ridge Pearl
i think i paid something like 50-80 to get my tires mounted and balanced (mount as put tires on wheel)...
swapping wheels is simple, all u need is a torque wrench and sockets of right size...
even if u only have subaru jack it's okay...just take longer...good weekend exercise...
DIY is fun~
anonymous_wolf is offline   Reply With Quote
Old 02-09-2005, 10:01 AM   #20
eclone
Member#: 31567
Member 17508 and never taken off a wheel? Anyway, you should invest in a jack/torque wrench instead of paying someone $20+ to install. Also, make sure your current lug nuts work with your new rims. You might need the "tuner" ones.
eclone is offline   Reply With Quote
Old 02-09-2005, 10:20 AM   #21
veightkiller
Member#: 78967
2011 335i
i agree
Old 02-09-2005, 01:02 PM   #22
sonicbath
Member#: 67272
04 WRX Waggy-Stg3
Silver Bullet (Ya-right!)
No offense, but if you have to ask don't do it!
sonicbath is offline   Reply With Quote
Old 02-09-2005, 01:25 PM   #23
eclone
Member#: 31567
your nuts are ok you're using wrx rims. It'll fit no problem and are most likely balanced.
Go check out Princess Auto I picked up a torque wrench there (Toronto) back in December for something like $15. And you can usually get jack/stands combo for pretty cheap there or Crappy Tire
Old 02-09-2005, 03:38 PM   #24
steve
Member#: 4718
Sold my Subaru, and
now I'm so OT
good call eclone.
For about $150 you can get all you need to lift the car safely. A jack, a set of jackstands, and a cheapo torque wrench.
As anonymous wolf said, it's good to know.
Old 02-09-2005, 05:16 PM   #25
mooshoo
Member#: 19432
Judging from the way the original poster has talked, I think the safest, wisest, and economical route is to take it to some place like canadian tire or something. Have someone install the wheels for you to be on the safe side...
mooshoo is offline   Reply With Quote
FS(IL) 2 sets of tires (Azenis and Pilot sport A/S)I have 2 sets of tires for sale. g2wanderer MWSOC Private Classifieds 1 05-25-2010 08:36 AM
FS: 1 set of wheels, 2 sets of tires NH wicked13 NESIC Private Classifieds 49 09-05-2009 12:17 PM
DFW: Cheapest place to have a set of tires switched from one set of rims to another? gaugeof12 Texas Impreza Club Forum -- TXIC 17 08-18-2009 10:09 PM
CHICAGO, FS:2 sets of 17" wheels and 3 sets of tires DickWRX MWSOC Private Classifieds 41 03-19-2007 08:00 PM
stupid question, ok to run 2 diff sets of tires? Ghost Rider Tire & Wheel 9 10-13-2006 03:27 PM
