Old 07-14-2001, 03:19 PM   #1
HomerJay
Member#: 1135
2005 WRX WAGON
Question Crush washers from oil pan ok for Tranny pan?
I'm about to change my tranny oil to Motul 300(thanks to Nativo) and I was wondering if you can use the crush washer from the engine oil plug for this application. I have a bunch of them because the dealer throws them in w/ the oil filter and I have a fumoto valve
HomerJay is offline   Reply With Quote
Old 07-14-2001, 03:50 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Should be fine
Brian
AIM: captaindamorgan ICQ: 84483950
http://www.northursalia.com
...something that rhymes with bones
Old 07-14-2001, 04:24 PM   #3
Fred Zaplitny
Gone... But not forgotten
Member#: 92
1999 2.5RS Coupe
Blueish Kind of
Exclamation Not so fast.....
I'm not so sure about that. I believe the tranny drain plug is quite bigger than the oil drain plug in diameter. The tranny plug has a big magnet there to collect the metal shavings. I would call a dealer if I were you to see if they are the same. Or you could just use the old one on the trans like I did. It doesn't leak. I just remember thinking of how huge the trans drain plug was and how the washer was much bigger than the oil plug washer.
Fred
Fred Zaplitny is offline   Reply With Quote
Subaru Gauge pack oil temp put in tranny pan? XWRATED Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 12-08-2006 05:36 PM
Does the Oil Pan have a Crush Washer? wildnuts Service & Maintenance 27 09-11-2006 03:52 PM
oil pan crush washer question Charlton Service & Maintenance 12 02-02-2004 11:27 PM
crush washer for oil pan moojamboo Service & Maintenance 22 02-12-2003 08:32 PM
Crush Washer - first oil change Peaty Newbies & FAQs 0 08-04-2002 04:45 PM
