Old 02-09-2005, 01:37 PM   #1
CatchMyDrift
Member#: 54523
Lightbulb STi Intake Manifold on 03 WRX
I searched under a few different terms and didnt come up with much so here goes. My friend wants to know if an 04-05 STi intake manifold would fit on an 03 WRX and what the advantages / disadvantages are.
Benny
CatchMyDrift is offline   Reply With Quote
Old 02-09-2005, 03:32 PM   #2
latinskllz
Member#: 3461
1998 BMW M3 Coupe
Estoril Bleau
Benny
Nope, you will need a JDM V7 or TGV-less V8 JDM manifold. THe 04-05 STI intake manifold doesn't have the air bypass ports on the manifold that the 03 WRX Throttle body needs, plus the 4 bolts are smaller in size...
latinskllz is offline   Reply With Quote
Old 02-09-2005, 05:24 PM   #3
YaZahX
Member#: 11932
1998 CW ITR
2006 NBP SI
u cant use any USDM sti intake due to the drive by wire. you will have nowhere to bolt the throttle cables to..
you can use the JDM verion 7 upper(and lower if u do a tgv delete mod) and a verion 8 with TGV mod
YaZahX is offline   Reply With Quote
Old 02-09-2005, 05:59 PM   #4
rogue
Teddard Snark
Super Moderator
Member#: 7977
100% Abuse
I put what I guess is a V7 STi intake manifold on my 02 WRX. It fits fine... but I gotta say, that was a huge PITA install
I don't see any benefits so far... unless you're modding the hell out of your car, I'd say skip this one... paint your stock manifold red maybe
rogue is offline   Reply With Quote
Old 02-09-2005, 06:39 PM   #5
CatchMyDrift
Member#: 54523
Ill let him know. Thanks for the replys.
Will an 04 STI Intake Manifold fit 03 wrx EJ205? simon930 Built Motor Discussion 7 12-03-2009 10:23 PM
V7 Intake Manifold on 03 WRX Cautionjump Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 04-10-2007 07:28 PM
Sti intake manifold on a wrx Se7enrex Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 10-20-2006 02:48 PM
USDM Intake manifold on 03 wrx? dan avoN7 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 02-23-2005 07:34 PM
sti intake manifold on 03 wrx Smoke Show Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 8 03-14-2004 04:50 PM
