Old 07-14-2001, 05:14 PM   #1
CUNNINGHAM
Member#: 5563
JDM 98 GM6, 05 BP6
Porsche 955
Question Need Help with motor build!!
I am building a turbo engine for my 98RS. I just want a great reliable turbo motor the can take the abuse. I have a complete 1991 2.2 legacy motor. I will be using the block along with slightly worked 98RS heads and intake. What should be used inside the motor as far as rods and pistons (looking to run up to 10Lbs). Also, What head gasket do I use and will the 98RS clutch and trans fit to the 2.2.
CUNNINGHAM is offline   Reply With Quote
Old 07-14-2001, 05:35 PM   #2
zaidallas
Member#: 4106
Default ???!!??
you want to build up a motor and run only 10 psi ? is that legacy block a turbo or NA block ? i'd call b-specusa.com or cobbtuning.com and ask them for the availability of rods and pistons. there has been several people who've done the legacy turbo block/RS heads hybrid , which i'm also considering. do a search if you havn't done alreay and see what turns out.
later..........
zaidoun
zaidallas is offline   Reply With Quote
Old 07-14-2001, 09:29 PM   #3
Greg 99
Member#: 1388
Default Don't bother unless it is a turbo block
Greg 99 is offline   Reply With Quote
I need some assistance, need help with my build Harnicka Built Motor Discussion 9 09-08-2009 01:58 PM
i need help on motor build!!!!!! firsttimetunner Texas Impreza Club Forum -- TXIC 27 07-21-2008 05:47 PM
need help on motor build!!!!!!!! firsttimetunner Newbies & FAQs 1 07-20-2008 03:08 PM
need help with motor running will pay $$ if need be railguy Mid Atlantic Impreza Club -- MAIC 14 08-13-2007 08:05 PM
Long story, but I need help post motor build! cegpcola Built Motor Discussion 12 03-26-2007 08:48 PM
