Welcome to the North American Subaru Impreza Owners Club Thursday December 18, 2014
Old 02-09-2005, 07:54 PM   #1
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Default Engine gasket/seal kit WRX vs EJ22T
Doing an ej22t build up, subaruparts.com has a gasket/seal kit for the WRX engine. Will this work for the 22t since most of it is the same?
Matt
TyranosaurusWRX is offline   Reply With Quote
Old 02-11-2005, 08:45 PM   #2
marios03wrx
Member#: 33593
2002 WrX-ShAgNwAgOn
that is 05 WrX Power'd
i'm actually curious about the same Q ??
What heads are you going to be using? Are you going to use all of the stock internals? I'm doing the same swap right now just trying to figure out the thickness of the WRX head gasket since the legacy one is to thick. i want to use the stock internals or i'm going to have to buy pistons and use the legacy head gasket. let me know whats up w/ your swap.
Mario
marios03wrx is offline   Reply With Quote
Old 02-11-2005, 09:47 PM   #3
TyranosaurusWRX
Member#: 25731
02 wrx(sold)/2005
Sti/ 93 Leg Wag
Hey Mario,
I am using the WRX heads. Although the stockers are in good shape, I am using aftermarket internals. Pretty much everything from Crawford Performance. I'm using one of his head gaskets as well, which I believe is the same thickness as the WRX. He informed me that his pistons stay below the deck.
I know the stock 2.2 pistons peak above the block (deck) just a hare, so I don't know if you could use the WRX headgasket without making contact w/the valves....I really don't know either way.
The WRX head gasket is .008 mm, the 2.2 is .0152.
If you end up using the thicker HG, you can customize the piston compression ratio at the Crawford Performance website. I'm sure he would work w/you with any questions.
Matt
WTB: Engine Gasket Master kit MyRad25rs Private 'Wanted' Classifieds 7 04-21-2009 08:41 PM
gasket/seals kit? kyleblix Built Motor Discussion 3 06-13-2008 03:08 PM
Engine gasket and seals kit...What's in it? jojo Subaru Conversions 7 05-04-2006 01:24 AM
Engine gasket and seals kit...What's in it? jojo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 5 05-03-2006 02:57 PM
Engine Bay fusebox differences WRX vs. RS Randoramma Subaru Conversions 4 04-25-2005 06:51 PM
