Welcome to the North American Subaru Impreza Owners Club Tuesday July 28, 2015
Mid West Subaru Owners Club
Go Back   NASIOC > NASIOC Chapters > Mid West Subaru Owners Club Forum -- MWSOC
Old 07-14-2001, 06:55 PM   #1
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Default My misfire problem.... solved!
The turbo seized! No wonder it was having a hard time at idle.
Beautiful, huh?
Old 07-14-2001, 07:11 PM   #2
01 Black RS
Member#: 2770
*** is going on?!?
01 Black RS is offline   Reply With Quote
Old 07-14-2001, 07:27 PM   #3
98mpreziveRS
Member#: 972
Turbo seizied? Was it your oil feed line? Hmm.. gets me wondering..
Hey Nick, if you are going to get yours rebuilt who are you using? I am looking for a place to rebuild mine right now before we go any further on the project..Know of any good shops around this neck of the woods?
Sorry to hear about that turbo though, that bites the big one
98mpreziveRS is offline   Reply With Quote
Old 07-14-2001, 07:28 PM   #4
dada21
Member#: 383
2001 Outback Sport
Turbo seized? That makes no sense. I don't remember, did you buy it used? What's the cost to repair?
Also... Are there preventative mechanisms (guages, sensors, etc) that could have warned you that you didn't buy?
dada21 is offline   Reply With Quote
Old 07-14-2001, 10:36 PM   #5
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Ok, NM. I could only wish it was the turbo that seized. Looks like I may be out of a car for a while...
Old 07-14-2001, 11:28 PM   #6
98mpreziveRS
Member#: 972
Uhh ohh.. umm.. does it have something to do with getting some piston slap ?
Anyhow, sorry to hear that Never fun when the car's not behaving and making a bigger headache than was hoped for..
Man, i am seriously curious now.. lol
And Dada, there really is nothing you can do gauge wise IMHO to prevent you from seizing your turbo, the only thing you could possibly use is a oil temp gauge and intake temp. (beleive it or not.. lol) gauge, but even then.. the best way to prevent it is make sure your lines are clean, and you're getting good oiling to the turbo and just double checking everything every now and then.
As for the cost of rebuilding a turbo, it depends on what turbo, etc. Generally a couple hundred (2-300 IIRC) to get a rebuild, but you can't always rebuild, depends on the severity of the damge, my rebuild is going to run around 275 if i remember right.
Old 07-15-2001, 03:48 AM   #7
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
'09 Concours 14 ABS Black
Angry
Well i hate to say it but 8's car will be out of commission fo ra little bit. Not sure what happened just yet but it seems that a piece of either a valve or piston broke loose in number 4 smashing the electrode on the spark plug, making it's way out the exhaust valve and into, do i dare say?? The Turbine, that was the grinding it noise it all fo a sudden made. Chewed up the Turbine fins pretty badly and knicked the #4 piston pretty badly. Well i believe 8's feeling ont he #4 injector was proven right today, the car was finally running GREAT, the first run w/o the ITC was pinging a little bit but as the ECU started to learn the curve it was doing nicely at correcting. WEll it seems like that #4 injector might be the culprit after all causing it to run lean, there fore shattering the ring land off the piston(my guess) and causing it to nail the spark plug...and so on and so on. Well 8 ready to put a motor together?? Just say the word brotha.
Jeremy
Old 07-15-2001, 03:54 AM   #8
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Let me put it this way, I'm hoping that the problem is left in my cat. somewhere. :-/
Old 07-15-2001, 04:03 AM   #9
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Arrow
8, we'll have to pull the pipe off and see if we can shake it out of there, i am sorry it had to happen bro. You know if you need anything i am totally willing to help
Jeremy
Old 07-15-2001, 07:34 AM   #10
rao
Member#: 52
2005 Legacy GT
98 BMW 540i LS2/T56
Bummer Nick I was afraid this was going to happen.
"We can rebuild him, we can make him better, stronger and faster." Hopefuly for less than $6 Million
Good luck
rao is offline   Reply With Quote
Old 07-15-2001, 01:50 PM   #11
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Not a big deal... just hoping that it didn't do any valvetrain damage on the way out. If that holds true, then I'm nearly home free other then a bit of work.
Old 07-15-2001, 07:15 PM   #12
Marcin
Member#: 2874
2005 CGM WRX WGN
Jorge Tunned BattleWagon
I'm sorry that all this happens.
When you guys say that a ring or something broke off, what would be a possible reason for that?
Marcin is offline   Reply With Quote
Old 07-15-2001, 07:28 PM   #13
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Bad detonation. I still think that the injector on #4 is a little clogged. Wish there was a way I could test it real quick other then ohm testing it (16.0 vs. 16.5-16.7 like the others).
Old 07-15-2001, 09:20 PM   #14
Redline8k
Member#: 2968
Beat it to fit,
Paint it to match!
Well Im sure that between all of us we can get the car running great again. As always you know if you need me Im there in a phone call bro! Just say the words and we can get things started...
-nick
Redline8k is offline   Reply With Quote
Old 07-16-2001, 03:42 AM   #15
HndaTch627
Member#: 6551
'01 GC8 Dinged STM
Cool
2.5T on a stand?? Looks so small, yet SO powerful ....I think i should get subaru certified for this one ....do i see that bare block being a 2.5T buildup soon??
Jeremy
Old 07-16-2001, 04:07 AM   #16
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Jeremy - You want a job at a Subaru place, I will be there with pictures in hand and stories ready to tell making sure you get in.
Yeah, I think that spare block is going through a phase of changing identities. First it was a block that I looked at and studied, then it was a donor block, and very soon it will be a buildup block.
Yet another misfire problem, (ill give you props if you can solve this!) alieus Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 01-14-2009 12:35 PM
i just solved ALL of my OT problems! rogue Off-Topic 5 11-16-2005 08:41 PM
i just solved ALL of my house problems! dr_wheel Off-Topic 3 11-16-2005 07:31 PM
Oil catch can solved my detonation problem Impreza Rider Mid Atlantic Impreza Club -- MAIC 1 08-23-2003 04:06 PM
Solving my understeer problem? HIHO Legacy Forum 6 05-01-2002 08:53 AM
