Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 02-09-2005, 11:28 PM   #1
Mariuslt
Member#: 51670
04 2.5 RS
Pacifica Blue
Default 15k service recommendations
i did some searches and couldn't find the right answers
So tomorrow im going in for my 15k service:
Install Moc Oil Conditioner
Install Moc Fuel Cleaner
Rotate Tires
Service Battery
Service rear brakes
and they are gonna inspect lots of other things, but at the end it says: Recommended at this time:
MOC Fuel System Cleaning and Decarbonization and Brake System Flush
i was wondering, what do those do, and are they worth the doing them or is it just something for the dealership to strip more money from me.
Thanks in advance
Mariuslt is offline   Reply With Quote
Old 02-09-2005, 11:56 PM   #2
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
Read your manual and look at the service schedule in there, and follow that. At 15K no major services are needed, the 30K is the first major service. All you really need at this point is an oil change (if due) and some inspections, you can easily do it yourself.
Do not go for the fuel cleaning, oil conditioning, decarbonization or brake flush. As you already suspect these services are not needed and are just the dealer trying to dig into your pocket. The only valid service out of those is a brake flush, but not at 15K. That would normally be done at the 30K or two year interval. The others should never be done, they are a waste of money and Subaru does not recommend any of them.
There should also be no need for a rear brake service @15K unless you have a known problem with them, if anything the front brakes would need service first. You'll usually go through two or three sets of front pads for every set of rears.
Old 02-10-2005, 01:12 AM   #3
Mariuslt
Member#: 51670
04 2.5 RS
Pacifica Blue
Mulder, thanks for the quick reply, and gotta love X-Files
But for tomorrow, what should i have them do then?
the dealership gave me this paper that gives me a list of what needs to be done and here is what it says for 15k:
Rotate Tires
Service Battery
Service rear brakes
INSPECT:
Tire Pressure
Tire Condition
Coolant hoses and clamps
Belts
Exhaust system and hangers
Exterior lamps
Fluid Levels, Leaks
Front Disc Breakes
Throttle Linkage
Vacuum Lines
Fuel Lines
Air Filter
So what should i tell them to do, besides "stop stealing my money, and just look at this________"
Old 02-10-2005, 06:08 AM   #4
Uncle Scotty
Visiting NASIOC Timeout
Member#: 16200
OK buy Nates beans
westcoastroasting.com
Tell them only to do what you can not reasonably do yourself.
....the 15k is, really, just an oil change(I'd replace the air filter, too) and inspection....don't forget to put some distilled water in your battery, if you know how.
Old 02-10-2005, 06:51 AM   #5
Mulder
Trust no one
Member#: 11170
02 WRX
15 WRX/05 GTO
The service as you listed is mostly a bunch of inspections, which is why they are trying to pump it up with those unneeded services. And, I still would like to know why they are recommending a rear brake service at 15K.
Another thing you don't mention is how much they are charging you, chances are it's way too much.
This is a very good opportunity to bypass the greedy dealer entirely and do your own service, and as long as you document everything carefully and keep receipts for fluids and parts there is no problem with your warranty.
Old 02-10-2005, 09:29 AM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Do they sell VWs, too? Late model Audis and VWs have real soft rear pads that disappear in a hurry. Lots of dust, too.
OneOBS is offline   Reply With Quote
Old 02-10-2005, 11:22 AM   #7
Hayes
Member#: 11808
Look at Subarus' recomendations in YOUR service manual. Circle what the manual requires and take it with you and show the dealer what is required. Dealers can have their own agenda and recomendations that are not Subarus. My service manual recomends an oil/filer change/check all fluid levels and rotate tires. Unless your haveing a problem that is all you need. eddie
Hayes is offline   Reply With Quote
Old 02-10-2005, 11:27 AM   #8
spacenut999
Member#: 40307
2004 WRX Sport Wagon
spacenut999 is offline   Reply With Quote
Old 02-10-2005, 12:31 PM   #9
outback_97
Member#: 30874
0897 OUTBACKS
and 2003 TS wagon
I had the same question a while back as our 03 TS just turned over 15K recently (we don't put a lot of miles on it obviously). I was able to find threads similar to this one with a search on "15K service" IIRC.
Anyway, from other posters' experiences, I was prepared for the bogus and excessive list of services when I called my dealer and asked them what the 15K service entailed, but was pleasantly surprised. They do the oil change, inspections, and brake fluid change for $70, which isn't that bad considering it's a dealer. If the car was 1 year old and had 15K miles, I'd pass on the brake fluid, but at 2 years now it might not be a bad idea in my case.
Steve
outback_97 is offline   Reply With Quote
Old 02-10-2005, 01:06 PM   #10
jay2theb
Member#: 37568
2003 WRX Sedan
Rotate Tires
Service Battery
Service rear brakes
INSPECT:
Tire Pressure
Tire Condition
Belts
Exterior lamps
Fluid Levels, Leaks
Front Disc Breakes
Throttle Linkage
Vacuum Lines
Fuel Lines
Air Filter
seriously, is that a joke? Do you not have your manual for your car? Can you not read the section for 15k service?????
jay2theb is offline   Reply With Quote
Old 09-06-2005, 07:56 AM   #11
pezman04wrx
Member#: 66558
Bump for being helpful ... Sometimes I just have to wonder ... I guess having a new car, just makes you want to do these services because they say they need to be done ... Went to my dealership to check it out while getting my Oil Filter/Crush Washer, and damn, $260 ... So I figured I'd check it out here before doing anything ... Read the manual as mentioned (duh ... Sometimes I'm an idiot), and low and behold there's barely anything there ... Needless to say I've done the 15k service myself with the addition of an air filter ... Sometimes this place is just invaluable ... Thanks for the sanity check ...
pezman04wrx is offline   Reply With Quote
Subaru's Recommended 15K Service DriveFast Service & Maintenance 3 03-11-2006 10:57 AM
Shop recommendations for 15K service? late67 Bay Area Impreza Club Forum -- BAIC 1 10-09-2002 01:27 AM
15k service Matt South East Region Forum 8 05-30-2001 11:56 AM
('93-'01) what is BG motor oil additive? 15K service manifest says they add it but i run synth nkodemus82 Impreza Forum 6 04-23-2001 09:37 AM
15k service $$ Ragstylz General Forum Archive 5 10-15-2000 03:57 PM
