Old 02-10-2005, 02:28 AM   #1
yukon1
Member#: 4730
07 Legacy Spec,B
Diamond Gray Metallic
Default cross member ?
Need too know if a usdm sti cross member will fit under a my00 rs?
yukon1 is offline   Reply With Quote
Old 02-10-2005, 11:56 AM   #2
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
yes with shimming
get a legacy turbo one if you can
Old 02-10-2005, 11:58 AM   #3
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
Do you have one you want to put on or just out of curiousity? I wouldn't know for sure...but I'd imagine it would, maybe with shims.
HeMan1320 is offline   Reply With Quote
Old 02-10-2005, 04:02 PM   #4
jeffg
Member#: 2958
2001 WRX (GC8)
and just to clarify the crossmember doesnt need shims, the spot where the control arms mounts to them need a shim to take up the wider bushing area, or you have to use WRX wagon control arms.
jeffg is offline   Reply With Quote
Old 02-10-2005, 10:13 PM   #5
tbd
Member#: 15322
1995 gf wagon
Blue Green Metallic 340
Default Clarify
Are you asking if the USDM WRX cross member will fit into that chassis w/ your current 2.5L factory engine? or will the cross member fit when you transplant a WRX motor? The headers are a concern.
tbd is offline   Reply With Quote
Old 02-11-2005, 01:52 AM   #6
yukon1
Member#: 4730
07 Legacy Spec,B
This is for a turbo swap.
Old 02-11-2005, 08:56 AM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I would just buy a WRX one and shim the a-arms, or spend the extra on the legacy one...
06 sti engine cross member/ 04 wrx egine cross member Fast06wrx Engine/Power/Exhaust 3 09-08-2010 11:30 AM
Need a turbo cross-member brace underground-mpyre Private 'Wanted' Classifieds 11 08-14-2003 12:57 AM
Transmission cross member torque specs? Shoelace Transmission (AT/MT) & Driveline 2 03-26-2002 09:42 PM
Cross members of STi Mlist and I clubs Gambit General Forum Archive 7 06-09-2000 10:07 AM
Is the 2.2L turbo Cross member the same as a WRX one ? Jay_UK Technical Forum Archive 1 05-27-2000 02:55 PM
