Welcome to the North American Subaru Impreza Owners Club Friday June 24, 2016
Old 02-10-2005, 11:28 AM   #1
BHawk
Member#: 61860
2004 WRX STi
Default Cobb Stage 2 plus stealthback
I am going to be running a Stromung 3" dp with divorced wastegate and a Stromung secondary pipe with a high flow cat. The rest of the exhaust will be stock.
Wil thisl be a good setup for a Cobb AP stage 2 map or is this not going to flow enough for what the map needs?
Also is this likely to experience boost creep? If anyone has a similar setup I would appreciate any insight you might have.
In any case I will post some results. I think this could be an excellent combination.
BHawk is offline   Reply With Quote
Old 02-10-2005, 01:11 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
For best results, you need a full TBE. Will your engine explode and kill 87 people with some stock components on it? No. Will you see full boost or full Stage 2 results? Maybe, maybe not.
You may see boost creep, you may not. It depends on how your car reacts and that isn't something anyone can guess.
Old 02-10-2005, 01:44 PM   #3
BHawk
Member#: 61860
2004 WRX STi
Thanks for the info, but I already knew that nobody can guess what will happen. I was hoping maybe somebody would already have this or a very similar setup. Maybe my hope was misplaced.
Old 02-10-2005, 03:47 PM   #4
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
i just ordered a cobb dp to mate up to the stock sti exhaust. I think it should cobb stage 2 just fine.
imprzya is offline   Reply With Quote
Old 02-10-2005, 05:57 PM   #5
AaronWRX
Member#: 7194
2011 997.2 Turbo
If only someone would do some real testing to find out how much of a restriction the sti axleback at your power level really is. I guess we can only dream.
AaronWRX is offline   Reply With Quote
Old 02-11-2005, 12:22 PM   #6
jsalicru
Member#: 58031
I ran a stealthback with the Stage 2. stock axelback. My max boost, even with the HWG map was 16.5 psi. It would rarely go above that level. When I switched to a full TBE (HKS Hi-Power mated to XS Race-pipe/downpipe), max boost jumped to 19.8 psi. I had to switch to regular Stage 2 map.
jsalicru is offline   Reply With Quote
Old 02-13-2005, 09:10 PM   #7
xrocket21
Member#: 81497
2005 STI, 2012 WRX,
2011 F150 ECOBOOST
does the accessport cancel the cel from adding a dp?
I was thinkin about just running a dp with the stock exhaust with stage 2 for stealth reasons, (cops)
xrocket21 is offline   Reply With Quote
Old 02-14-2005, 02:10 AM   #8
imprzya
Member#: 12181
2004 STi WRBro
15 Forester Touring
yes the AP removes the cel caused by the catless dp
Old 02-14-2005, 02:28 AM   #9
BoostdBoxer
Member#: 53163
I am running a Corn Cobb Stage 2++/- 32↕φ with a seconday Stage 64.654-11+12 stage Catback .. STAGE FREAKs BE QUIET
BoostdBoxer is offline   Reply With Quote
Anyone run Cobb Stage 2 with Turbo XS Stealthback? Faulk Tri-State Area Forum 2 04-24-2005 11:48 PM
cobb stage 2 plus headers WrexFactor36 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 14 12-05-2004 08:23 AM
turboxs stealthback/prodrive axle back w/ cobb stage 2 showcasewrx Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 04-17-2004 10:54 PM
Vishnu stage 0 package or Cobb Stage 2 with TXS Stealthback and uppipe. OvRclockR Proven Power Bragging 0 10-02-2003 10:46 PM
Is it ok to get cobb stage 2 reflash with stealthback? 03mbpREX Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-01-2003 07:04 PM
