Old 02-10-2005, 05:05 PM   #1
SJwrx
Member#: 14970
1997 GF8
multi
Default WRX cross member = GD arms aswell?
Hey Guys,
On a common EJ20 swap into the old styles, I notice you have to use the front cross member in order to get the turbo piping in the 'stock' location. My question being, since you have to run a WRX cross member, can you also run WRX front control arms (will the fit the knuckles)? Wider? Skinnier?
Rich
SJwrx is offline   Reply With Quote
Old 02-10-2005, 05:37 PM   #2
RokketRide
Member#: 17984
1967 Barracuda
2000 OBSTi
http://forums.nasioc.com/forums/showthread.php?t=713424
the wider track from the GD will give you some crazy camber on a GC
RokketRide is offline   Reply With Quote
Old 02-10-2005, 05:44 PM   #3
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
You can run the wagon control arms which give you a narrower track. Option 2 is just to shim the old control arms, since the mounting bracket is wider.
Old 02-10-2005, 10:16 PM   #4
SJwrx
Member#: 14970
1997 GF8
multi
I knew the mounting wider, I was just hoping that the mount would be farther in aswell. Thanks for the help you two.
Rich
Old 02-11-2005, 12:06 AM   #5
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
is there any difference between a wrx sedan crossmember and a wrx wagon crossmember?is the wrx wagon crossmember like the older gc8(turbo) crossmember?thanks
petawabit is offline   Reply With Quote
Old 02-11-2005, 01:38 AM   #6
SJwrx
Member#: 14970
1997 GF8
multi
Nope, Sedan and Wagon cross-members are the same...same down to the part number.
Rich
Suib Part #20101SA000
08 WRX- Cross Member brace or Rear Floor Brace gdubduc Brakes, Steering & Suspension 5 07-28-2008 08:50 PM
WTB: wrx cross member nuclearfiziks Private 'Wanted' Classifieds 1 09-27-2006 06:59 PM
wtb: front wrx cross member norexyet Tri-State Area Forum 6 05-01-2005 02:53 AM
WTB: WRX cross member supaflyTS Private 'Wanted' Classifieds 1 05-20-2004 10:44 AM
WTB: WRX cross member supaflyTS Vancouver Impreza Club Forum -- VIC 2 05-20-2004 01:14 AM
