Go Back   NASIOC > NASIOC Subaru Models > Baja Forum
Old 02-10-2005, 05:33 PM   #1
pgv
Member#: 73808
2003 Baja
Default Getting Sprung for Spring!
Yahoo! I just spend the tax refund that I'm not getting on new lift springs for the Baja!
Here's the story on the delay...apparently ISR/Rennick had springs all along for the Legacy Outback, but had no way of knowing if they fit the Baja, and Scorpion went to another planet for awhile and could not be contacted.
After finally getting together on this they learned that all they needed was a different spring seat for the front (or is it the back?). Those come from Subaru for about 25 bucks. With those in place the Leg. OB wagon springs fit.
So, anyone interested...there ARE lift springs at ISR/Rennick.
I'm stoked! The waiting is gonna hurt however!
Perry
pgv is offline   Reply With Quote
Old 02-10-2005, 06:50 PM   #2
Rick Maize
Member#: 80991
2003 Baja
Yellow w/ OzzBros cover
Perry,
did you ever get your springs?
How 'bout and update?
RGM
Rick Maize is offline   Reply With Quote
Old 02-10-2005, 07:45 PM   #3
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Subysolutions.com offers a rear SSI overload springs for a Outback sedan or wagon.They say you can increase load capacity by 200-300 lbs and can raise some cars as much as 1/2 inch.And they have a good ride without cargo.This would be good for someone that did'nt want to do springs all around,but increase load capacity.
ajabobrut is offline   Reply With Quote
Old 02-10-2005, 08:43 PM   #4
Pursuit
Member#: 38370
Fantastic, thanks Perry! Who's your guy you're talking to at Rennick? So you're saying they're in stock?
Pursuit is offline   Reply With Quote
Old 02-10-2005, 08:59 PM   #5
pgv
Member#: 73808
2003 Baja
Default Lift springs at Rennick
They are in stock at Rennick. The spring seats come from Subaru.
Mine are shipping out on Monday I hope! Hopefully there will be pictures shortly thereafter.
I talked to Brett at Rennick, he was very knowledgeable. Give him a call.
Old 02-10-2005, 09:17 PM   #6
Pursuit
Member#: 38370
Great, I appreciate it!
Old 02-10-2005, 09:49 PM   #7
pgv
Member#: 73808
2003 Baja
Default Part #s, if anyone wants them
The springs are King KSFR32(front) and KSRR29(rear)
The spring seat # is Subaru 20323FA000.
Old 02-11-2005, 12:13 AM   #8
ajabobrut
Member#: 56726
2004 Baja Turbo
Regatta Red Pearl
Hey Perry,
How much lift are they getting with these springs?Did they say how much they would affect the ride?Thanks.
Old 02-11-2005, 08:01 AM   #9
pgv
Member#: 73808
2003 Baja
I guess the amount of lift remains to be seen. The posted lift is 1.5 inches, but Rennick said 2 inches for the Baja. So, I guess I will say between 1.5 and 2 inches. Hows that for definitive.
The ride will be stiffer, but I don't mind that. I want to use a trailer, and load the bed with stuff on bad roads, so I think it will help for that.
I guess will have to report back after the springs are on as to how the ride is really affected. The down travelfor the wheels will be reduced, so the next thing is to see if I can find longer strut inserts.
Perry
Old 02-23-2005, 03:06 AM   #10
jamba
Member#: 79759
03 Baja
Default need update
Perry,
congrat on getting the springs. once you get them installed, could you answere some questions for me?
How much lift did you actually get?
what's the ride like?
Could you go down to the local tire dealer and try on 225/70-16s to check on rub, front and back and is there any rub when springs are fully compressed?
Demmit I'm demanding sorry. Any help with this is much appreciated.
and in case you are interested in other mods (bigger tires need more hp/tq) check these sites out.
http://www.techworkseng.com/
http://www.boxer4racing.com/
thanks again
Jack
jamba is offline   Reply With Quote
Old 02-23-2005, 08:13 AM   #11
pgv
Member#: 73808
2003 Baja
They are getting installed tomorrow. I can put up pics and comments after that.
Old 02-23-2005, 11:17 AM   #12
BajaT05
Member#: 78337
2005 Baja Turbo
Regal Blue Pearl
So you just doing springs to lift it... with this hurt the suspension travel etc and the camber of the tires? How much are the springs?
BajaT05 is offline   Reply With Quote
Old 02-23-2005, 02:16 PM   #13
pgv
Member#: 73808
2003 Baja
Yup, just the springs for now. Yes, they will hurt the suspension down travel. I wonder if there is a way to placed a spacer in the tops of the struts to get some of that back? How much they hurt the downtravel I can't say as yet. Since they are also stiffer, it may not be noticable. Only time will tell.
They were delivered to me for about 400 bucks. 4 springs and two new spring seats for the front.
Old 02-23-2005, 03:39 PM   #14
holland_patrick
Member#: 72014
05 Baja gone
Winner best wax job 06WBM
Now being the 04-05 are taller will this spring set make those taller or does it just bring the 03 to the higherlevel of the 04-05
holland_patrick is offline   Reply With Quote
Old 03-02-2005, 01:11 PM   #15
pgv
Member#: 73808
2003 Baja
I don't have a definite answer about 04/5. It depends on how they were raised. It seems to be a body lift, but not everyone I ask agrees. It is is a body lift, then the springs will work fine. If it is a suspension lift of some kind then it will have litttle effect. I know that Sean at Rallitek decided against the springs for that reason, but others don't agree.
As for the ride quality, I like it fine. Better in fact. I have not noticed the loss of downtravel as of yet.
Old 03-02-2005, 03:24 PM   #16
pgv
Member#: 73808
2003 Baja
Default The "lifted" B-ha
Okay, here it is. About a 1.5 inch lift over stock. Just slightly more than the factory would do it.
Old 03-02-2005, 09:19 PM   #17
02_Forester
Member#: 11015
'06 Volvo V70R
Sonic Blue
it looks good and it looks really close to the height of my '05.
02_Forester is offline   Reply With Quote
Old 03-05-2005, 02:53 AM   #18
blubaja03
Member#: 55144
2001 Panda Fozz
1999 OB wagon
Hey,
I missed something man. What is ISR/Rennick? I mean, what is the url for their site? I really really want those springs. Thanks so much for getting this mod. :-D
Frank X.
blubaja03 is offline   Reply With Quote
Old 03-05-2005, 09:18 AM   #19
pgv
Member#: 73808
2003 Baja
It is Rennick Motor Sports, or RennickMotorSports.com
Go for it, I am happy so far with the results.
Originally Posted by blubaja03
Hey,
Frank X.
Old 03-05-2005, 03:11 PM   #20
blubaja03
Member#: 55144
2001 Panda Fozz
1999 OB wagon
Hey,
Thanks man. I tried www.rennickmotorsports.com ..nothing man. Did they close up or something?
Old 03-05-2005, 07:48 PM   #21
cliffhanger
Member#: 80446
2005 5spd Baja-T
370+405=new clutch
i got you man.. it is www.isrperformance.com/main.html i think they changed their website b/c i couldn't find 'em for a while either.... hope this helps... anyone try these springs on the 04/05 's yet? i would really love to find out if these will work
cliffhanger is offline   Reply With Quote
Old 03-05-2005, 09:45 PM   #22
jamba
Member#: 79759
03 Baja
Default apologies
there is one "n" in renick http://www.renickmotorsports.com/oscommerce/catalog/
when all was said and done, I did get the discount that was promised, or at least most of it, without putting up a fuss... and it does look like the parts will get here when promised as well. I apologize unreservedly for any emotional harm that I, or my statements, may have caused... I therefore undertake to never react hastely hereafter... and may god have mercy on my soul
Old 03-05-2005, 09:47 PM   #23
Pursuit
Member#: 38370
Mine are going on Monday!! It's either gonna be or ... we're going to try on different size tires while we're there as well to figure out how big we can go.
Old 03-05-2005, 10:02 PM   #24
pdiz
Member#: 82424
2005 Baja Turbo
Black Onyx
It will be interesting to see how much lift you gain on the '04/'05 model. I am on the edge of my seat! I have an '05 and also wanted to go a little higher. Could you measure a fixed point on the body with the OEM wheels/tires, then again with the new springs with the OEM wheels/tires? I just want to see how much lift is gained on the '04/'05s without new wheels/tires being a factor. Thanks! Also pics would be awesome! Good luck and enjoy!
pdiz is offline   Reply With Quote
Old 03-05-2005, 10:10 PM   #25
Pursuit
Member#: 38370
Don't worry, I'll be documenting! I'll post up asap.
getting ready for spring jasontee1 Member's Car Gallery 8 12-31-2008 02:22 AM
Possible to still get NEW Eibach springs for the BD/BG? Mikeye Legacy Forum 26 03-04-2008 10:37 AM
Get sprung! Springs for 02/03 WRX and RS MastroWRX Suspension/Brakes/Handling 3 04-20-2004 03:18 PM
getting ready for spring subiebill Off-Topic 4 04-05-2004 07:54 AM
Looking for springs...or do you have anything in your garage you want to get rid of.. MUGWUMP Mid West Subaru Owners Club Forum -- MWSOC 1 09-05-2003 03:37 PM
Message Board Statistics All times are GMT -4. The time now is 02:47 AM.
