Old 02-10-2005, 05:53 PM   #1
speedblind
Member#: 42202
Default Help with fuel filter install
I'm having a hard time getting the hoses off the fuel filter in my 02 WRX. I mean a really hard time! I'm thinking of just buing replacement fuel hoses, cutting the stock ones off, and doing it that way. Any advice before the knife comes out?
speedblind is offline   Reply With Quote
Old 02-10-2005, 06:27 PM   #2
cnk
Member#: 10757
2013 BRZ Limited 6MT
They were tight for me as well. I found that they broke loose by grabbing them with some pliers and twisting them on the hose bib. Once they broke loose, they slid right off without a problem.
Calvin
cnk is offline   Reply With Quote
Old 02-10-2005, 06:42 PM   #3
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Put some white lithium grease on the barbs when you put the new filter on. It will allow it to come off much easier next time you change the filter .
Brian
Old 02-11-2005, 09:53 AM   #4
vile
Member#: 32371
'02 t-rex wagon
platinum
what i did was i took a small flathead screw driver and gentlely lift up a small section of the hose from the filter. while it's lifted, spray a little lubricant in it. work your way around the hose like this, you don't need to go all the way around, just the accessable portion. let it sit for a minute or so, then use a twist/pull motion
done and done
vile is offline   Reply With Quote
Old 02-11-2005, 10:28 AM   #5
IDAFC21
Member#: 60471
2004 GTO
QSM
when i did mine i got the 'In' side out alright, but i could NOT get the 'out' side off, i tried prying/twisting/pulling, eventually the hose just kinda cracked and fuel started leaking out, so i just cut it off and bought a new piece of hose to replace it
IDAFC21 is offline   Reply With Quote
Old 02-11-2005, 12:18 PM   #6
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
me too - works almost every time for stuck hoses.
Old 02-11-2005, 05:24 PM   #7
speedblind
Member#: 42202
Thanks for the suggestions. I'll give it another go tomorrow and see what happens.
Old 02-12-2005, 01:47 AM   #8
AlpineFD
Member#: 42573
2004 WRX
twist, then pull
AlpineFD is offline   Reply With Quote
Old 02-14-2005, 07:29 PM   #9
badboiWRX
Member#: 42565
getting it back on was the challenge for me...
badboiWRX is offline   Reply With Quote
Old 02-26-2005, 02:43 AM   #10
Kyguy
Member#: 38705
'95 GM2 Rally Car
& '08 WRX
I've found that replacing the fuel filter was the most entertaining thing I've done under my subaru's hood so far
Kyguy is offline   Reply With Quote
Old 02-26-2005, 10:51 AM   #11
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
What I do is use the 90 pic out of my pic set to get under the edge of the hose and spray rubbing alcohol(I ALWAYS have a spray bottle of rubbing alcohol around for lubricating rubber parts ) on it and work the pic, carefully, around the edge of the hose...letting the alcohol do it's job.....spray a bit more, maybe.....twist/pull and done.
Rubbing alcohol is great for lubricating rubber/silicone 'cuz it won't damage it or anything underhood or paint....it lubricates, then evaporates leaving NO residue...it cleans.....it is cheap..... and can be entertaining at need, too
Old 02-26-2005, 08:48 PM   #12
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
I do what you're thinking of, speedblind. When I change the fuel filter I just cut the hoses and replace them with new 5/16" fuel injection hose.
In general I find plastic round-jawed hose pinch pliers useful for removing hoses; they're gentle on the hose so you can push harder than you can with metal pliers.
vrg3 is offline   Reply With Quote
Help with Fuel rail install, injectors loose noonagon Newbies & FAQs 1 02-28-2009 06:10 PM
fuel filter installed right? voam Service & Maintenance 2 08-15-2004 04:50 PM
Fuel filter install help diediemyscooby Service & Maintenance 6 04-21-2003 12:39 PM
Need help! Perrin Fuel rails installed but I need help with Fuel Evap Line STR8OUT Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 7 04-18-2003 12:11 PM
fuel filter installation Gambit Normally Aspirated Powertrain 11 11-11-2000 12:30 AM
