Old 02-11-2005, 02:25 AM   #1
elhalisf
Member#: 56332
2005 STI Cobb Stg 2
Default Can ACT, Exedy or Spec Stage 1 Pressure plate work with stock clutch disc?
I found a deal on a Spec Stage 1 pressure plate. It uses the organic disc. Can I just buy a new OEM WRX clutch disc? Same question goes for the exedy and the act stage 1's. Because I was told it was only the pressure plates that are the upgraded piece. Thanks!
elhalisf is offline   Reply With Quote
Old 02-11-2005, 08:39 AM   #2
STiTuner
Member#: 5778
09 135i
Jet Black
they are modifed oem pressure plates (just different springs), you shouldn't have a problem.
STiTuner is offline   Reply With Quote
Old 02-11-2005, 04:12 PM   #3
VTsuby
Member#: 81369
2007 STI
would the opposite be true stock plate performance disc?
VTsuby is offline   Reply With Quote
wtb act stage 1 pressure plate omega force Private 'Wanted' Classifieds 0 04-01-2008 10:59 PM
Which clutch disks work with stock pressure plate and 5-7psi? (td04) Anhdalai Transmission (AT/MT) & Driveline 4 08-28-2007 01:53 PM
Cobb AP Stage 1...Will it work with a DP?? BigJ04STi Engine Management & Tuning 1 01-07-2005 06:45 AM
Can I keep my ACT pressure plate & just buy another disc? Juicy Transmission (AT/MT) & Driveline 4 11-23-2003 04:26 PM
Will Vishnu Stage 1 re-map work with these mods? Tweak-WRX Engine Management & Tuning 7 01-31-2003 12:19 AM
