Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-11-2005, 04:36 PM   #1
1fastsube
Member#: 42567
2005 STI
Element GT65
Default Hydra in, no start????? Help!!
I just installed the hydra on my 05 sti and there car does not run. I have went over my work and checked the vaccum lines, plugs, injectors, everything. I unhooked the hydra and plugged in the stock ecu and even that didnt make the car start. I have perrin injectors, big maf intake, full exhaust, and e-boost controller. Please give me any info on how to make the car start. Thanks
1fastsube is offline   Reply With Quote
Old 02-11-2005, 04:44 PM   #2
lowturboboost
Member#: 61424
Then it's NOT an ecu issue. Check your harness and everything else you have installed along with the Hydra and give it a try.
lowturboboost is offline   Reply With Quote
Old 02-11-2005, 04:52 PM   #3
1fastsube
Member#: 42567
2005 STI
Element GT65
I checked the harness, its installed correctly. The bottom arrow of the diff. setting on the dash is also flashing and the car has never done that before.
Old 02-11-2005, 06:14 PM   #4
antimullet
Member#: 44193
2008 WRX STi
I had that issue with my ecutek flashed ecu. You get a flashin CEL and a flashing lower diff light. For me it meant the flash didn't take. Another symptom is that when you turn the key you will not hear the fuel pump prime.
What did you change besides the ecus? Cause it sounds like something else is messed up.
Did you have a base startup map installed in it (Hydra)?
Also, was the eboost working with the stock ecu? Or did you do that and the other mods all at once then install the hydra?
If so I'd unhook the eboost for now and see if that may be wired incorrect, or not suitable for the hydra.
antimullet is offline   Reply With Quote
Old 02-11-2005, 06:53 PM   #5
bboy
Member#: 56468
04 Improved STI
Dirty White
I agree with mullet. What changed other than injectors and ECU?
Tell us the steps you took to get to the point where you tried to start the car, and what happened when you tried to start it. Just make a list of the installation events.
Very definitely unplug the eboost and plumb up you stock boost control solenoid, or alter PWM Map 4 to not use the stock boost control system. (I do not recommend eBoost unless you wire it in to the Hydra (Phil only knows). You are running a speed density system with excellent boost control for all but the biggest turbos).
Is Big MAF using the stock Denso MAF sensor. The Hydra references the stock MAF for intake temp only, but ignores the MAF signal.
ps I doubt car will start with big injectors, it's almost twice the fuel. If it did start it would be a smoke fest and probably a fire hazard.
Old 02-11-2005, 07:54 PM   #6
pux888
Member#: 8356
02 STi swap
12 WRX limited
mine would start on the stock ecu w/ the 800cc injectors but it was a mess to say the least.
pux888 is offline   Reply With Quote
Old 02-11-2005, 11:47 PM   #7
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
If it won't start with the factory ecu then it could be a million things. This so far has been the root of all recent problems and all started after one or more of these was resolved. Focus on the items not related to the Hydra since your car will not start with the factory ecu:
These apply to cars with no damaged sensors, coil packs, or spark plugs, and that start with OEM ECU (just try them anyway )
Car cranks and makes no attempt to start:
General wire taps into ecu harness where a wire may me not be passed through in the Hydra.
Defi Link, gauges, tachometer wire taps in OEM ecu harness
Water Injection wire taps in OEM ecu harness
Turbo Timers
Alarm Systems with start disable
Not enough battery Voltage:
Less than 10.4 Volts while cranking will result in the car not starting. Monitor Voltage while cranking with Hydra Software.
Charge or replace the battery
If this only occurs when below freezing or colder temperatures
Replace battery with more cold cranking amps
A tell tale sign of not enough voltage will result in no RPM reading (monitor with Hydra software) while cranking the car
Fuel Map too lean:
Add fuel to the "cranking Enrichment" and or "Start Primer" maps
Fuel entry and return lines to fuel rail reversed:
These are the lines coming out of your fuel filter
Main Fuel map may not be appropriate for injectors:
Injectors with low response times such as PE may not be delivering enough fuel under low fuel pressure and voltage
Increase the values in "Main Fuel" Map by using the "Injector Change Trim" feature under the "Tools" Menu
Crank Triggers Incorrect:
This is rare but if the crank triggers are wrong the Hydra will not see 2 syncs of the crank and therefore will not attempt to start
A tell tale sign of wrong triggers is no RPM reading (monitor with Hydra software) while cranking the car
Car tries to start or does not stay running:
Coil pack Wires reversed:
Car may start with OEM ecu but will not with Hydra
White connectors always in front, black in back
Fuel Map too lean:
Add fuel to the "Post Start Enrichment" map under the coolant temperature areas where car stalls
Increase the idle under "select/settings/ISC" and increase the "Min PWM" to around 40-50 to idle the car higher. This will keep the car running so you can asses how lean the AFR is. If after the car is warm, and the AFR is leaner than 14.7, the "Main Fuel" map is too lean.
Injectors with low response times such as PE and others may not be delivering enough fuel under low fuel pressure and voltage
Car does not start when cold
Add fuel to the "cranking Enrichment" and or "Start Primer" maps under the coolant temperature trouble range
Good luck!
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 02-12-2005, 12:40 AM   #8
bboy
Member#: 56468
04 Improved STI
Dirty White
Wow!! Thanks Phil.
Now, 1fastSubie tell us what you did. Don't be shy only half of us bite.
Old 02-12-2005, 02:34 AM   #9
1fastsube
Member#: 42567
2005 STI
Element GT65
Ok guys I hooked up my labtop to the hydra and turned the car on and the hydra software said that the ecu was not connected. I made sure everything was hooked up and still it gave me the code 30001. I decided to try the stock ecu again and the car actually started up but was a mess.
Old 02-12-2005, 09:11 AM   #10
Element Tuning
Member#: 54918
673 WHP Element
Are you sure you have the coil pack leads correct? Double check both sides, with white in the front and black in the back. If it sounds like it's back firing out the exhaust on the stock ecu this could be the culprit.
With the "big" maf and modified injectors your STI should start and run normal on the factory ecu.
Thanks,
Phil
Old 02-12-2005, 11:43 AM   #11
bboy
Member#: 56468
04 Improved STI
Dirty White
Did you touch the coil packs? Maybe change the plugs? We can help a lot more if you tell us everything you did.
The fact that the Nemesis software cannot connect to the ECU could be a serial or serial-usb problem and have nothing to do with the Hydra's installation.
Old 02-12-2005, 01:20 PM   #12
1fastsube
Member#: 42567
2005 STI
Element GT65
Okay, the only thing i did was install the injectors and big maf. I never touched the coil packs or plugs . I started it up this morning and took a little drive around my neighborhood and the car ran fine. The car was warmed up so I turned it off and hooked up the hydra again. I went to turn the car on and it would not start witht he hydra installed. There ws no backfiring or sputtering with the stock ecu installed. Everythign workes fine until I hook up the Hydra.
Old 02-12-2005, 01:22 PM   #13
pux888
Member#: 8356
02 STi swap
12 WRX limited
i would run your boost line around the passenger window to the engine bay just to make sure it not getting pinched off some where. that will prevent the car from starting. just a thought
Old 02-12-2005, 02:12 PM   #14
1fastsube
Member#: 42567
2005 STI
Element GT65
the vac line that goes to the hydra works fine and is def not pinched because when i hooked up the stock ecu that line was not hooke din a dn i could hear it sucking air.
Old 02-12-2005, 06:08 PM   #15
antimullet
Member#: 44193
2008 WRX STi
Phil,
Does the immobilizer key on the 05s mess with the startup?
Old 02-12-2005, 08:54 PM   #16
pux888
Member#: 8356
02 STi swap
12 WRX limited
can you up load the map from the hydra at all?
Old 02-13-2005, 12:08 AM   #17
1fastsube
Member#: 42567
2005 STI
Element GT65
Nope I cannot load it at all. I really wish I could figure out whats wrong with the ecu so my car can get running again.
Old 02-13-2005, 12:24 AM   #18
pux888
Member#: 8356
02 STi swap
12 WRX limited
maybe theres not a map in the unit, thats doubtfull but i cant think of anything it could be if you havent touched anything else on the car. but even if there wasnt a map you should at least be able to pull up a template.
Old 02-13-2005, 03:22 AM   #19
HOK
Member#: 447
1999 EJ22T222B&EVO
Are we racing yet?
check each pin on your wiring harness and hydra connnectors... you might have pushed one out of the way of the pin hole
HOK is offline   Reply With Quote
Old 02-13-2005, 02:30 PM   #20
bboy
Member#: 56468
04 Improved STI
Dirty White
How do you know the computer can connect to anything?
Old 02-14-2005, 11:02 AM   #21
lowturboboost
Member#: 61424
Do you have a Serial-USB adapter. So far the only one I have seen that works is the one from I-Concepts. PDA Serial to USB converter.
Maybe your Hydra came without a map? (Doubt it if you bought it from Phil)
Check the coil pack leads.
Old 02-14-2005, 11:18 AM   #22
1fastsube
Member#: 42567
2005 STI
Element GT65
The only serial adapter I have is the one that came with the hydra. Im pretty sure it has a map though. I didnt touch the coil pack leads at all so nothing should be wrong with them.
Old 02-14-2005, 11:37 AM   #23
lowturboboost
Member#: 61424
OK - So right now it fires up with the stock ECU, just not with the Hydra? If so... does the car at least cranks? If it does.. as Phil said: Add fuel to the "Cranking Enrichment" and or "Start Primer" maps.
Old 02-14-2005, 11:38 AM   #24
lowturboboost
Member#: 61424
Wait... you said that you couldn't upload the map from the Hydra?
Old 02-14-2005, 12:44 PM   #25
bboy
Member#: 56468
04 Improved STI
Dirty White
If you have not been able to upload any Hydra map how did you calibrate the throttle (or O2 sensor if you have one). Borrow a computer or drag you desktop to the garage. :-)
I'm not sure how the Hydra would react to "idle" if it does not know what 0% throttle position is.
no start...help please subiedreamin Subaru Conversions 5 11-18-2009 09:51 PM
Hydra - will not start/ dies while driving: PLEASE HELP!!! ejsportcom Other Engine Management 2 07-03-2009 01:54 PM
No start, no accessory power Please help tunertrends Electrical & Lighting 3 07-14-2007 12:19 PM
03 EJ205 into 01RS. No start help jeffg Subaru Conversions 35 04-30-2007 02:27 PM
after motor reinstall, no fuel pressure, no start. help me diagnose! jared nelson Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 74 11-04-2005 01:36 AM
