Old 02-11-2005, 05:55 PM   #1
edaniele1212
Member#: 71013
2004 WRX STi
Java Black/Goldies
Default The best WRX STi engine management
What are your thoughts for the best engine management. My car is a everyday driver so it cant be "too" radical. I would like to be able to switch it on and off.
edaniele1212 is offline   Reply With Quote
Old 02-11-2005, 05:59 PM   #2
Scoobyracer1
Member#: 35114
On & Off = multipule maps....soo....Reflashes, unichips, Ecktec, Exide are all out.....
UTEC is a multi map system, I believe FCON, Hydra, and Emanage are as well
Scoobyracer1 is offline   Reply With Quote
Old 02-11-2005, 05:59 PM   #3
MajinVejitaXV
Member#: 71162
1997 Eagle
Talon NA
Stock or modded? And what mods?
-Corey
MajinVejitaXV is offline   Reply With Quote
Old 02-11-2005, 06:10 PM   #4
edaniele1212
Member#: 71013
2004 WRX STi
Java Black/Goldies
By the time I get the EM I'll have TBE, FMIC, ColdAir Intake, Pullys, ect... (maybe injectors and a pump) I dont really know how easy it is to switch them on and off, but I would like to switch it when I want to race or when I take long trips.
Old 02-11-2005, 06:22 PM   #5
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Then you definitly need a multimap system. Your best bet is probablt the XEDE or UTEC if you want to keep the stock ECU (which you probably do for a daily driver).
mcowger is offline   Reply With Quote
Old 02-11-2005, 07:44 PM   #6
tt_ttf
Member#: 4431
MY07 STi and '06 WRX
Urban Grey & WRC Blue
Sorru but you're wrong about ECUtek
ECUtek supports dual maps - I have that in my WRX with the second in my case set up as a valet map
But you can do just about anything - stock, fuel econ, 100 Octane etc with the second map
tt_ttf is offline   Reply With Quote
Old 02-11-2005, 07:57 PM   #7
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
sounds like you want the TurboXS UTEC. Car can be switched to stock with just a push of a button and it will give you 25whp with no other modifications.
Good Luck
BLACK02WAGON is offline   Reply With Quote
Old 02-11-2005, 09:08 PM   #8
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
please post in the correct forum.
in this case the ENGINE MANAGEMENT forum.
moving now...
Old 02-11-2005, 09:14 PM   #9
supermarkus
Member#: 6971
2008 WRX STi
SSM
I inquired about multi-map support for STis a while back and found that they hadn't implemented it yet for my car. It might be different now, I haven't been actively pursuing EM lately.
supermarkus is offline   Reply With Quote
Old 02-12-2005, 01:40 AM   #10
XtianLA
Member#: 29958
03 WRX
Good Luck
I wouldn't take the UTEC over the ECUtek. The ECUtek has better resolution.
XtianLA is offline   Reply With Quote
Old 02-12-2005, 02:06 AM   #11
x99percent
Member#: 27108
2004 STi
2004 A4
The dual map support on WRXs with a EcuTeK flash is limited to two different boost maps. If someone has told you otherwise (fuel economy, high octance, etc.), I believe they were misinformed.
However, it is possible to leave plenty of "learning headroom" in the timing maps so that the ECU can take advantage of higher octane fuel... but I don't know how good or bad that might affect ignition timing for day-to-day driving.
edit: eye khant speell
x99percent is offline   Reply With Quote
Old 02-13-2005, 10:39 AM   #12
rich728
Member#: 40328
2004 WRX STi
BSP #728
XEDE is also an option
rich728 is offline   Reply With Quote
Old 02-13-2005, 10:45 AM   #13
kapnkrunch2
Member#: 79104
ecutek and utec together "the utec works alot better when it doesnt have the ecu fighting it for control"
kapnkrunch2 is offline   Reply With Quote
Old 02-13-2005, 05:25 PM   #14
ScoreBo
Member#: 30643
2004 PSM WRX STi
GT35R - 33PSI - 500WHP
What about the Cobb AccessPORT? Multiple maps by just hooking it up to the AP + you don't have to get it tuned like the Ecutek. If you are changing injectors, you won't be able to go back to a stock ECU. Food for thought.
ScoreBo is offline   Reply With Quote
Old 02-14-2005, 05:30 PM   #15
kwilson36
Member#: 67449
03 VF22, TXS FMIC
EcuTek, Catless...:)
No need to do a FMIC, Injectors and a pump until you have an upgraded turbo in the works..(think FP Green). once you do the injectors your goanna need EM to adjust a/f and timing. And if you do a FMIC the cold air intake is out... just wont fit with the FM piping, you'll want to do a turbo xs shorty or Perrin Ram pod.
UTEC is the weapon of choise. Fairly inexpensive and when you want to sell it you just unplug it and post it here....no purchasing a new ECU. Just make sure that if your not into doing the tuning yourself that you have access to a knowlegable tuner... which is no different than if you were to choose EcuTek; which you cant tune anyway.
If your really serious about EM look into Hydra, AEM, Motec... all a little more expensive but supiorior products. At least in my oppinion.
good luck.
-K
kwilson36 is offline   Reply With Quote
Old 02-14-2005, 05:46 PM   #16
ADR 04STi
Member#: 51918
2015 Audi S3
Daytona Gray
I would def look into the Cobb AP. Nice features and Realtime maps / stock mode etc. Good luck.
ADR 04STi is offline   Reply With Quote
Old 02-14-2005, 05:59 PM   #17
Jon [in CT]
Member#: 2992
02 WRX Sedan
The stock ECU and its algorithms are pretty damned good and if you or your tuner can change the calibration maps easily, then that's probably the best solution. It appears the Cobb STi StreetTUNER intends to provide that functionality.
Jon [in CT] is offline   Reply With Quote
Old 02-14-2005, 06:05 PM   #18
mcowger
Member#: 77483
2009 Audi A3 2.0T q
Lava Grey
Cobb's tunes are nothing like getting your car properly, professionally tuned. You'll make more more, safer, with a prof. tune....
Old 02-14-2005, 07:08 PM   #19
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
I completely disagree with kwilson, the first thing that you should do is EM. I will repeat something that I have said many times. Why upgrade something if you cannot take full advantage of the upgrade.
The only engine upgrades that I have are all TurboXS: FMIC, RFL-Ti(catless), shorty intake, and UTEC. With these upgrades and tuning alone, I made 324whp and 320 wtq so I again disagree with kwilson. Save the injectors and pump until you plan on doing another turbo. VF39 is plenty for daily driven though.
Old 02-14-2005, 07:11 PM   #20
BLACK02WAGON
Member#: 32574
2012 Nissan GTR BE
Vibrant Red
Impreza WRX STi
BTW.....you will want to use the UTEC if you need OBDII testing for state inspection. I don't know about ECUTEK, AP, etc but I know that standalones (hydra, AEM, etc) will not let you have OBDII.
Good Luck
Old 02-14-2005, 07:29 PM   #21
tt_ttf
Member#: 4431
Good Luck
ECUtek and Cobb AP are both based on the stock ECU so OBDII is not a problem (unless you mean the later 2005 odb spec which won't be an issue for a couple of years yet)
Old 02-14-2005, 07:50 PM   #22
supermarkus
Member#: 6971
2008 WRX STi
SSM
Originally Posted by mcowger
Cobb's off the shelf tunes are nothing like getting your car properly, professionally tuned. You'll make more more, safer, with a prof. tune....
Fixed it for you. They have the capability to "professionally" tune cars at their shop, I have a friend that was nothing but pleased with his custom Access ECU tune.
Old 02-14-2005, 08:02 PM   #23
Jon [in CT]
Member#: 2992
02 WRX Sedan
True, but with the Cobb STi StreetTUNER you don't have to rely on Cobb's tunes. You, or your tuner, can use it to adjust the stock ECU's calibrations to accomodate/support your modifications.
Old 02-16-2005, 11:49 PM   #24
yaggi
Member#: 60369
2004 Impreza WRX
I am new to the subaru world and engine management. I want to start modding my 04 WRX, but I am also hesitant to do anything that will void the warranty. From what I've read starting with EM (sounds like UTEC, XEDE, or ECUTEK is what I would want) before bolt-on's is a perfectly good and sounds like smarter route to take. My question is regarding what is physically involved in the EM upgrade. Does it completely replace the stock ECU or does it work in conjunction with it. Basically, I want to know if I have a problem with the car and I have the EM upgrade installed, what would I need to do in order for the dealer not to know it's there?....if that is even possible. Thanks for any info.
yaggi is offline   Reply With Quote
Old 02-17-2005, 02:52 PM   #25
ScoreBo
Member#: 30643
2004 PSM WRX STi
I had a UTEC and my only beef was the crossover hesitation. It certainly has a number of great features which makes it shine in a class by itself. There is a lot of experience tuning them and it doesn't alter your factory ECU flash. I just got tired of the crossover hesitation, so I went with the AP. With the StreetTuner that is coming out in a few weeks, I am hopeful to add my GT12 soon + try the AVCS controls.
what is best choice for engine management? Boxer4turbo2004 Engine Management & Tuning 11 05-19-2010 02:40 PM
FS:(Ontario) 02-05 WRX UTEC Engine Management & WRX ECU cribbie Engine/Power/Exhaust 3 04-01-2010 09:31 AM
WRX STi engine among Ward's 10 Best Engines of 2004 mlambert Off-Topic 4 12-11-2003 04:17 PM
WRX STi engine among Ward's 10 Best Engines of 2004 FunkerVogt Off-Topic 5 12-11-2003 02:01 PM
Best stand alone engine management jetfan8178 Normally Aspirated with bolt-on Forced Induction Powertrain 7 03-29-2002 10:46 AM
