Old 02-11-2005, 08:23 PM   #1
Killian Maynard
Member#: 73734
2005 WRX I caught
you a delicious bass
Default 2005 WRX Cobb STG 2 lower RPM stutter
I'm running Cobbs AP stage 2 Cali with a MRT 3" TBE with only 1 cat in the 2nd cat position with res box removed and a K & N filter. During initial exceleration (between 1500-3500 rpms) the power delivery is a bit choppy untill 4500rpms where the engine begins to feel very smooth accompanied by a very strong pull up untill about 6K where power stops increasing. Also during the choopy phase (1500-3500) the intake suction (louder because no resbox) sounds inconsistent. Instead of a solid and consistent "sucking" noise it sounds as if the opening is changiong diamter so to speak making higher and lower pitches of sound. Like this whheeeeooooooowhheeeeoooooo instead of whhiiiiiiiissssssshhhhhh you know? I wish I had a recording, sorry.
So along with the choppy power band and funny intake sound the power just doesnt seem to be there like it should (I ran a access ECU stage 2 02 WRX with same mods and that felt faster than my 05?)
Any suggestions or help would be greatly appreciated. Thanks in advance.
Killian Maynard is offline   Reply With Quote
Old 02-11-2005, 09:22 PM   #2
yergi
Member#: 65303
nope nope
"dooby specialist"
how is it that you have a cat in the "second position" if you have a TBE?
by this I think you are trying to speak of the downpipe cat?
yergi is offline   Reply With Quote
Old 02-11-2005, 09:53 PM   #3
Killian Maynard
Member#: 73734
2005 WRX I caught
Yes being that there are 3 cats in a stock system one in the upipe (1) and two in the stock TBE (2 and 3 respectively). The second cat in the stock TBE is right after the turbo outlet and the third cat is in the midpipe. My MRT TBE has 1 cat in the second cat location.
Old 02-11-2005, 10:19 PM   #4
yergi
Member#: 65303
nope nope
"dooby specialist"
why not just say DP cat then?
anyhows, Did you realize that COBB requierments for running stage 2 with the AP is to have NO DP cat?
Old 02-12-2005, 12:34 AM   #5
Killian Maynard
Member#: 73734
2005 WRX I caught
Sorry about the confusion, I guess I see the DP as having 2 cats and the second cat being what you consider the DP cat. Anyways, you may be right. I was hoping this setup would work ok because of the design of the outlet mouth and distance before the cat. I suppose running stage 1 might smooth things out. I will give that a try and see what happens.
Whats interesting about this is the comparrison between say the PPP which run with a downpipe almost exactly like I have. Prodrive still maages to get to similar power figures and spool up characteristics. I wonder what sort of tuning differences are employed be each.
Old 02-17-2005, 03:08 AM   #6
lmon50
Member#: 33010
2002 wrx wagon
I didn't see the requirement from cobb to run catless in the dp. they do remark that their high flow cat test did not reduce the peak performance of the package compared to the catted dp.
i'm interested to see if your experiment going back to stage 1 will smooth things out.
lmon50 is offline   Reply With Quote
Old 02-17-2005, 04:53 AM   #7
03twrx
Member#: 73737
I've travled 500 mil
es to give you my seed
lmon50 is right. Cobbs tests with the catted dp and non catted dp show no differance in power. This is the only reason I bought a high flow catted Helix dp. It may be differante with a restrictave cat though. This may be why the stg2 only works with a full TBE. Most if not all companies TBE's are either catless or include high flow cats for cali. Your not running the wrong oct gas are you? How about any cel's?
03twrx is offline   Reply With Quote
Old 02-17-2005, 10:42 AM   #8
subieworx
Member#: 47769
You're a moron, no offense. Do you even have an AccessPort? I think probably not.
You need an aftermarket DP to run Stage 2 that only has at most one cat.
subieworx is offline   Reply With Quote
Old 02-17-2005, 10:43 AM   #9
subieworx
Member#: 47769
Stage 2 works fine with just a DP. I ran it with a Stromung DP with the rest of the exhaust from there stock. Worked fine.
Old 02-17-2005, 11:34 AM   #10
yergi
Member#: 65303
nope nope
"dooby specialist"
come one bro, that was pretty uncalled for.
and yes, i beleive that the offense was intended.
in any case, yes, I do own an access port (street tuner on order)
the comment about the cat in the downpipe came from cobb's technical board where this question was asked in relation to the absolute minimum requierments to running stage 2. The question was answered with a statement from, I beleive trey, that the only real requierment was that the dp had to run without the cat.
link:
http://www.wrxforum.com/cgi-bin/ulti...585;p=2#000016
I think some people here may have some confusion with what a midpipe is, and what the downpipe is. the midpipe has a cat. you can leave that in place.
and subieworks: of course stage two works fine with just the downpipe,
It is the ONLY requirement (being that the stock cat restrictor is right there next to the turbo) not sure why you just contradicted yourself by agreeing with me?
Old 02-17-2005, 11:42 AM   #11
subieworx
Member#: 47769
link:
I guess the real problem is in the definition of the exhaust components. You define a DP as the first section of exhaust. I don't. Some poeple define the Mid pipe as the pipe that goes from the where a cat back would attach to the axle back. Some don't. I guess a lesson for us all is to not take info for granted and make sure we fully explain what we mean.
Old 02-17-2005, 11:45 AM   #12
yergi
Member#: 65303
nope nope
"dooby specialist"
now we are all on the same page, yes?
Cincy - 2005 WRX Cobb Stg II For Sale luckysung Mid West Subaru Owners Club Forum -- MWSOC 6 05-12-2009 04:52 PM
FS(Tri-state): 2005 STI cobb Stg 2 PSM $21k obo! djpete Private Vehicle 'For Sale' Classifieds 41 07-05-2008 10:27 AM
2006 WRX + Cobb stg 2 estimates RexusFastus Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 11 08-25-2005 09:09 PM
Dynoed my 03 WRX Cobb stg 2... Swine Proven Power Bragging 23 05-10-2005 07:48 PM
03 WRX Cobb Stg 2 93 octane on Dynojet Lordhowe Proven Power Bragging 40 03-11-2005 03:09 PM
