Old 02-11-2005, 08:28 PM   #1
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
Default question about fuel pump controller.
hey guys. I been driving my RS W/ WRX conversion.. I recently changed my rear differential.. and STI sway bar.. well I have a CEL because of fuel pump controller and also Drink gas.. Have to put gas every other day..
is there a way to wire it up to the ECU? I think RS doesn't have a connector for the fuel pump controller in the right quarter like the wrx..If anyone has done the swap.. please help.. me I want to get rid of the CEL.. and new york city is coming out with a new inspection machine that goes by OBD II and any car that has a CEL will fail the NYC Inspection.. please please help me thanks.. kevin
taeyax82 is offline   Reply With Quote
Old 02-12-2005, 12:02 AM   #2
taeyax82
Member#: 49465
03 Bugeye Wagon
Red
help help~!! bump~!!
Old 02-12-2005, 12:47 AM   #3
Ds baruuuuu
Member#: 4724
01 01RS
brp
theer are 2 wires coming off the ecu for the fuel pump controller plug b137 pin15 is violet/white the other is b134 pin13 light green/red then there is a +12v input(black/yellow) ground (black) then a black/orange and black/white that go to the fuel pump go to www.northursalia.com he has a wire diagram for an 04 wrx
Ds baruuuuu is offline   Reply With Quote
Old 02-12-2005, 01:06 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
I think he knows what the wiring is, but if you don't have the connector that those wires plug into, which then plugs into the controller, it makes things a little tougher.
Post something in the wanted classifieds and see if someone has one. Also check with the JDM dismantlers to see if they have one out of a JDM STI or other car. www.iaperformance.com usually has that kind of stuff around.
Old 02-12-2005, 01:45 PM   #5
greenemac2003
Member#: 38813
1999 RS ej20/stg2 AP
silverthorn
I need the connector as well. I'm goning to order mine through Subaruparts.com if my wiring harness doesn't have one and if that doesn't work I can always make a connector.
greenemac2003 is offline   Reply With Quote
Old 02-12-2005, 11:22 PM   #6
Ds baruuuuu
Member#: 4724
01 01RS
brp
even if you dont have the haeness its easy look on the bttom of the FPC every pin is labled i.e fp+= fuel pump pos fp- + fuel pump neg
Old 02-13-2005, 02:04 PM   #7
greenemac2003
Member#: 38813
silverthorn
Thanks.............
Old 02-17-2005, 01:18 AM   #8
PumpsGOTAWD
Member#: 33175
1998 Impreza 2.5RS
98 Unicorn EVO Killer
the way that i did it was i plugged it in under the rear seat and hooked up the mentioned wires above.. works fine for me i could take pics for ya if you need them let me kno
PumpsGOTAWD is offline   Reply With Quote
Old 02-17-2005, 09:25 PM   #9
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
i put mine under my dash next to the glove box. The ecu is right there and the wires going back to the fuel pump are right there, so spicing it is easy. If you dont have the connector just use some female crimp connectors that have a plastic coating so they are insulated.
JeremyRS is offline   Reply With Quote
Old 02-18-2005, 12:22 AM   #10
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
i put mine in the rear passenger panel in the trunk where it belongs, just drilled 2 holes on that piece of metal behind the carpet. Mines not working for some reason, need to troubleshoot it
ImprezaRSfan! is offline   Reply With Quote
Old 02-18-2005, 02:13 AM   #11
Mumbles
Member#: 248
I hope you used very heavy gauge wiring for that.
-B
Mumbles is offline   Reply With Quote
Old 02-18-2005, 11:01 AM   #12
bebeu
Member#: 43088
00 Impreza
hello,
I have a STI 8 JDM in a GC8.
I dont have this PFC, and i haven't CE !
I use the "PFC +" from the ECU for the "FP +"
and it's good.
Just one thing : I haven't timing on the pump. it run always when you put the contact.
I think it's because I haven't PFC.
bebeu is offline   Reply With Quote
Old 02-18-2005, 12:13 PM   #13
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
-B
i used 10 guage wire and connected it to the 2 wires that goto FPC from ecu. They are 2 14 guage wires and i connected it to 2 big 10 gauge wires and ran it to the trunk, that wouldnt prevent mine from acting normally would it, too big gauge wire?
Old 02-18-2005, 03:26 PM   #14
JeremyRS
Member#: 65126
00 Leggy Wagon
99 Silverado, 06 HD
-B
I used the connector out of the wrx harness, and useds the pigtail wires off it. And the wires going back to the pump I used the same guage as the stock wires. At first I just hooked up the power to the pump and not the ground, but i hooked up the ground for the controller, but I was getting a cel, so I just spliced in the ground back to the pump. But I had to run the ground all the way back to under the rear seat, because the ground wire that goes under the carpet from the right side kick pannel grounds more than just that pump. I've been driving it for a few months and I have no problems and no cel. The reason I put it under the dash and not "Where it belongs" is so i wouldnt have to run the wires from the ecu all the way to the trunk.
Jeremy
Question about fuel pump and injectors mistagreenthumb Newbies & FAQs 8 05-14-2010 06:53 PM
quick question about fuel pump Kaldar142 Newbies & FAQs 5 01-10-2008 10:18 AM
A question about fuel pumps. Slowsoul Newbies & FAQs 9 03-13-2007 12:33 PM
NEED ASAP!: 04/05 STI Fuel Pump Control Unit aka Fuel Pump Controller. dan2304k Private 'Wanted' Classifieds 0 05-25-2006 07:25 PM
Question about fuel pump w/ vf39 edoublepo Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 3 05-04-2005 03:13 PM
