Old 02-11-2005, 11:04 PM   #1
stisp33d
Member#: 45122
5xtra hp for sti in name!
Default AP noob help
I've bought an Accessport off another member on here, and I have a couple of questions:
1. My Accessport isn't "talking" to my computer even though the Accessport is in "sync with PC" the message that comes up is "Couldn't identify Accessport (yyyy) call tech support". I've updated the software to 1.5v
2. What should my base map be? stock? or stage 2 (what I want to run now)
3. Do I just plug the accessport in, load a real time map, then unplug and drive?
Thanks.
stisp33d is offline   Reply With Quote
Old 02-11-2005, 11:38 PM   #2
johsti
Member#: 36049
2014 FXT Premium
1. you need to update the AP as well. click on this, and follow the readme file. http://www.accessecu.com/support/ReprogramAP_05WRX.zip
2. Flash stage 2 as your basemap if your car meet the maps requirements (TBE, or at least a downpipe). You don't want stock as a basemap.
3. Yes, or you can just run the stage 2 basemap as is. You don't have to load a realtime map.
johsti is offline   Reply With Quote
Old 02-12-2005, 10:00 AM   #3
Quack
Member#: 57264
2004 18g Wagon - WRB
PDX Tuned - 329whp/315wtq
i was just looking and do you (stisp33d) have a 02? if so, there isn't anything that you need in the new maps. it's mainly for the 04/05 models.
notes for 04/05:
Revision Notes:
1.21 - New Base Mapping based on MY05 program code including VIN reporting.
New Closed Loop / Open Loop transition parameters. Reduced delay to provide
quickier exit from Closed Loop operation. Reduced TPS (38%) and RPM (3800)
values to automatically switch out of Closed Loop. [BASE MAP UPDATE ONLY]
notes for 02/03:
1.21 - Revision number increased due to 2004-2005 map changes. There were no
required changes made for 2002-2003 WRX.
Quack is offline   Reply With Quote
Old 02-12-2005, 10:01 AM   #4
Quack
Member#: 57264
also if you go into you com port properties and lower the buffers down, that may help
edit: if you didn't upgrade your AP yet, but don't have the older map manager (v1.3), i have it.
Old 02-12-2005, 03:07 PM   #5
Marty Gagnon
Member#: 59102
2003 TO=RS VAN=WRX
Blue'z
upgrade your software for AP
Marty Gagnon is offline   Reply With Quote
Old 02-12-2005, 03:08 PM   #6
Marty Gagnon
Member#: 59102
2003 TO=RS VAN=WRX
Blue'z
and run a stage 2 as base
AP noob who go his AP stolen has a question Dutch_Mafioso AccessPort 1 03-30-2009 02:18 PM
AP 1 problem--AP noob Imprezive42 AccessPort 21 05-06-2007 01:48 AM
AP noob question. Should I keep it in the car? Badkarma Engine Management & Tuning 9 12-07-2005 07:51 PM
AP noob---quick question itjustWoRX Engine Management & Tuning 11 06-17-2005 09:54 PM
Cobb AP noob question wrxetta Engine Management & Tuning 2 05-20-2005 01:04 PM
