Old 07-15-2001, 01:27 PM   #1
Jimmy
Member#: 586
Default ASR TURBO installed and running good
I figured everything out
It run good i just have to tune it...other then that car runs ok
..I noticed that small amount of oil leak from oil filter when car is running any clue ??
Well i did tighten the oil filter iam going to runn the cxar again later on today to see iof it does it again
other then that everything seems fine
Jimmy
Jimmy is offline   Reply With Quote
Old 07-15-2001, 02:15 PM   #2
t.rod
Member#: 1447
2000 Impreza
2001 Dodge 2500
What electronics are you using?
t.rod is offline   Reply With Quote
Old 07-15-2001, 03:14 PM   #3
8Complex
Member#: 922
16 WRX (white)
04 FXT (red)
Do you have an oil cooler or is there a fitting near there that you could be mistaking for the leak? Possibly you just need to change it and clean the surface well before reinstalling.
Old 07-15-2001, 03:54 PM   #4
Jimmy
Member#: 586
walbro fuel pump and SAFC
soon J&S
maybe vertec FPR
Old 07-17-2001, 03:34 AM   #5
Digital_Boy
Member#: 730
Jimmy,
Any new developments on the car? Had time to inspect for the source of the oil leak yet?
If you can swing it, save up for a Wolf ECU or something like it. Well worth the money and effort to install and tune it.
Digital_Boy is offline   Reply With Quote
Old 07-17-2001, 08:47 AM   #6
jmott
Member#: 6713
2007 Prius
brown
oil coming out of the filter can mean blowby which would mean broken pistons/piston rings...
jmott is offline   Reply With Quote
Old 07-17-2001, 02:03 PM   #7
SubaFastR
Member#: 5786
The leak can also be contributed to too much crankcase pressure. Are you properly venting the pressure? When I was into V8s, we used to put a one way check valve in the exaust to suck out the crankcase pressure. Very illegal and effective.
Kevin
SubaFastR is offline   Reply With Quote
Old 07-17-2001, 03:57 PM   #8
STiShawn
Member#: 2348
2006 WRX TR
Steel Grey Metallic
look for the rubber filter gasket, it can get stuck on the mating surface and cause the filter to not seal right.
STiShawn is offline   Reply With Quote
AEM CAI Installed and running.. REX265 Newbies & FAQs 25 05-26-2010 02:22 PM
APS SR40 Turbo installed and dyno'ed... WR_eXe Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 44 03-17-2003 11:10 PM
Turbo Install and Tuning complete! Pics Inside! Thanks IDracing!! AWDball Texas Impreza Club Forum -- TXIC 26 12-22-2002 08:10 PM
LINK tuned and running good finally- just need to break in the clutch redmeanie Normally Aspirated with bolt-on Forced Induction Powertrain 0 08-17-2002 10:47 PM
ASR Turbo installed Jimmy Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 07-13-2001 10:01 PM
