Old 02-12-2005, 02:03 PM   #1
rickG888
Member#: 14820
2002 WRX wagon
Sedona Red
Default air splitter/sealing options for GC8 TMIC?
I have a GC8 with a USDM swap and JDM STi IC and have tried a few USDM splitter ducts but am not happy with the way they work and look.
Without major fabricating, where can I buy a good duct system for a GC8 hood to marry to an STi IC and give me a good tight seal with the air flowing in. Does anyone sell a good GC8 splitter or do I have to make something work.
Also, has anyone used heat resistant foam,insulation or rubber to seal the IC for maximum air intake into the IC.
I want a good seal and don't want a fire or melting hazard under the hood.
I would be curious to see what other swappers have done under their hoods.
Of Course pics are worth a thousand words too.
thanks
rickG888 is offline   Reply With Quote
Old 02-12-2005, 02:43 PM   #2
greenemac2003
Member#: 38813
1999 RS ej20/stg2 AP
silverthorn
Go with the stock wrx hood splitter and duct work. I have one on mine and have the usdm wrx engine with stock intercooler and it works perfect. It just bolts up where the stock solid cover was on my 99 2.5rs. Subaruparts.com has the full setup for like $60 bucks not including shipping. Try this link: http://www.subaruparts.com/diag/?mod...category=910-1 . Cut and past on your browser. Hope this helps, you may have to use the Sti setup, not sure if the Sti I/C is any taller than the wrx I/C. Call Subaruparts.com and compare the parts for the two.
greenemac2003 is offline   Reply With Quote
Old 02-12-2005, 08:58 PM   #3
kgb
Member#: 1366
2000 RS-T -> RSTi-8
Blue Ridge Pearl
So which part would I really need? I've got an AVO intercooler and definitely need an air splitter that works...
kgb is offline   Reply With Quote
Old 02-13-2005, 12:20 AM   #4
Ds baruuuuu
Member#: 4724
01 01RS
brp
just buy the gt spec one for a gc8 i think rev-lab has them for like 85 bucks or so made for a gc
Ds baruuuuu is offline   Reply With Quote
Old 02-14-2005, 01:00 PM   #5
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
if you are like me...just make one...really easy
Old 02-14-2005, 02:07 PM   #6
squirrelmasta
Member#: 33445
2005 Chevy Silverado
Cherry Red
I've seen them made out of the stock solid cover. looked pretty good on the set up i saw.
-Eli
squirrelmasta is offline   Reply With Quote
Best option for large TMIC under 2000 RS hood? AcquaCow Normally Aspirated with bolt-on Forced Induction Powertrain 11 05-10-2007 02:04 AM
STi Air splitter with duct for 04-05 STi hood scoop west005 Private 'For Sale' Classifieds 5 07-01-2006 02:09 AM
front lower control arm options for gc8 imprexxa Brakes, Steering & Suspension 31 03-11-2005 11:50 PM
aftermarket Shock options for gc8 soobyfan Brakes, Steering & Suspension 2 05-08-2004 08:50 PM
Fog cover options for GC8 (mesh/clear)? Siper2 Interior & Exterior Modification 2 08-12-2002 12:49 PM
