Old 01-30-2005, 07:12 PM   #1
Subie Darkness
Member#: 80375
05 2.5rs sport
white
Default Newbie Q: Turbo on 2.5rs?
Hey as in the titled i mention that i'm a newbie so i don't know wut i need to do this
i'm thinking about putting the factory turbo on my 2005 2.5rs and wondering if this is possible and what i need to do this...?
Subie Darkness is offline   Reply With Quote
Old 01-30-2005, 07:18 PM   #2
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
why didnt u buy a wrx?
ure gonna need.. well.. a turbocharger... an intercooler. probably some exhaust modifications and probably more stuff than that.. ie fuel lines and pump.. maybe new injectors as well. some internals that i am unsure of because i dont know what the rs has thats different from the wrx inside considering the lack of turbo. i am sure someone else will give you a much more detailed response.
WRXdriver04 is offline   Reply With Quote
Old 01-30-2005, 07:45 PM   #3
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Do a search in aftermarket forced induction. But you will nee the above mentioned stuff, plus all the ancillary stuff. I think it would be best to try to either A.) buy a complete WRX engine, and swap it, along with ECU and exhaust. Or B.) buy the stock parts off of someone that has gone aftermarket on all the parts needed for a turbo system. try to buy the stock WRX parts that the person still has laying around. Here is some of what to look for:
-Stock WRX exhaust manifold.
-uppipe either a STi one or aftermarket would be best.
-turbo, either a stock WRX TD05H, or maybe a New VF-22 since they can be had cheap or other used VF series turbo
-turbo cross member, this is what the turbo mounts onto, if I am not mistaken
-stock WRX intercooler, with all hoses, and stock recirc valve
-stock WRX exhaust, or after market if you want. (At least an aftermarket downpipe)
-Maybe a WRX fuel pump, not sure if it is different from a RS fuel pump, capacity wise.
-I would go with STi injectors just for reliability and safety sake, screw the blue ones. Or go with modified blues or something like that, don't just use the stock blue injectors.
-Induction pipe, from airbox to turbo
-intake box, or short ram/cold-air for WRX
-ECU, gotta have something to run the whole thing. Get stock WRX ECU out of a wreck or something. try these guys http://www.fsautoparts.com/
You could probably source a lot of little stuff from there, but I would try to get stuff here, from memebers. You'll probably pay a lot less here.
If I am leaving anything out, someone please chime in.
DP
DonkeyPunch is offline   Reply With Quote
Old 01-30-2005, 07:58 PM   #4
Brad Pittiful
Member#: 34931
save yourself the headache...buy a WRX
Brad Pittiful is online now   Reply With Quote
Old 01-30-2005, 08:16 PM   #5
Uncle Scotty
OK buy Nates beans
westcoastroasting.com
Turboing an engine that was not designed from the start to be turbo'd usually ends up with a blown engine and a LOT of wasted $$$.
A motor swap may be possible fairly easily....check the 'conversions' forum....
Old 01-30-2005, 09:11 PM   #6
Subie Darkness
Member#: 80375
05 2.5rs sport
white
thx for the suggestion...it seems like i should probably do a wrx swap
Old 01-30-2005, 09:44 PM   #7
Laugh Damon
Member#: 69010
2008 obxt
but void your warrentee right off the bat?
Laugh Damon is offline   Reply With Quote
Old 01-30-2005, 09:46 PM   #8
WRXdriver04
Member#: 72560
04 WRX (stg. II)
java black prl
it just seems like you should have bought a wrx from the start instead of an rs..
Old 01-30-2005, 09:49 PM   #9
Capt Crunch
Member#: 10852
Then : JDM Ver 7 STi
Now : E46 M3 / MKVI GTI
yipes. brand new car and you're gonna do a swap?
I say bust out the suspension and brake and exterior mods until your warrantee runs out.
Capt Crunch is offline   Reply With Quote
Old 01-30-2005, 09:52 PM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
sell it and buy a 2002 wrx
Old 01-30-2005, 10:08 PM   #11
Laugh Damon
Member#: 69010
2008 obxt
The only reason I wouldn't suggest trading in your 2.5 for a WRX is insureance, you might not wanna have to pay a high price for insureance, thats why you got a 2.5 in the first place.
If I were you, get an older 2.5 or L, swap in a WRX engine, then you don't have to worry about a warrentee, or insureance.
Old 01-30-2005, 10:19 PM   #12
saar
Member#: 43770
2013 Impreza WRX
RNN14 GTiR
Remember the RS engine runs 10.5:1 compression.....the wrx stock has 8:1.....The stock wrx turbo runs a typical 13.5 PSI ....I can imagine 13.5 PSI and 10.5:1 compression would go toghether very well...
saar is offline   Reply With Quote
Old 01-30-2005, 10:50 PM   #13
Charge
Member#: 3313
I'm sorry, but if you can't afford the insurance jump for a WRX, how can you afford to do a swap? The costs are substantial, and the risks involved(no warranty) also warrant a substantial amount of cash to be available to do this in a fiscally responsible manner.
I never understand that. I can't imagine insuring a WRX over a 2.5RS would amount to more than a $1000/year difference. Besides, to get your insurance to cover the swap parts, you might possibly need to notify them of the changes ahead of time, which could result in a rate increase anyways.
Charge is offline   Reply With Quote
Old 01-30-2005, 11:50 PM   #14
Laugh Damon
Member#: 69010
2008 obxt
A WRX swap is a one time cost though, insurance is every month, eventually the insurance will cost more then the swap.... might take a while, but it will.
Old 01-31-2005, 04:21 AM   #15
Subie Darkness
Member#: 80375
05 2.5rs sport
white
well i'm not planning to do a swap just now...just want to research about it
i got the 2.5rs b/c i couldn't afford a wrx just now and ya i probably get some coil over and other things before doing a swap
the problem with a 2.5rs is there is almost nthing you can do to the engine (i'm a newb so there might be, just don't know about it...if someone knows pls make suggestions)
but thx for the good info guys
Old 02-01-2005, 10:47 PM   #16
JDM_Scobaru
Member#: 57809
I 2nd that
Zach
JDM_Scobaru is offline   Reply With Quote
Old 02-04-2005, 02:07 PM   #17
dmatthew
Member#: 69247
2005 2.5 RS Wagon
Crystal Gray Metallic
You can do some minor performance upgrades such as changing your exhaust and when a CAI comes out, swapping that in.
Apparently Injen has an 05 CAI but I haven't really seen anyone use it other than Caplin2.5
dmatthew is offline   Reply With Quote
Old 02-04-2005, 02:20 PM   #18
pezman04wrx
Member#: 66558
Too bad subaru doesn't do what Saturn does ... If you don't like your car or want something different in the first month, you can trade ... No fuss no muss ...
pezman04wrx is offline   Reply With Quote
Old 02-04-2005, 02:36 PM   #19
davidji
Member#: 59980
03 Forester
For a WRX?
davidji is offline   Reply With Quote
Old 02-04-2005, 10:44 PM   #20
RS_to_WRX_swap
Member#: 40337
95 L Coupe Swapped
99 Outback
DP
The turbo crossmember dosn't hold the turbo, its holds the motor. They call it a "turbo crossmember" because there is a notch in it to give clearence for the header and up pipe.
RS_to_WRX_swap is offline   Reply With Quote
Old 02-05-2005, 09:18 AM   #21
DonkeyPunch
Member#: 18987
2014 Forester
Dark Grey Metallic
Judging by your screen name, I am not going to argue, I was just unsure exactly what the part was, but I knew it was needed.
Thanks,
DP
Old 02-13-2005, 08:37 PM   #22
93subi
Member#: 81255
98 05 LGT, silver
98 Trans AM, Red
sounds like a real expensive way to blow that motor up if u ask me
93subi is offline   Reply With Quote
Old 02-14-2005, 01:33 AM   #23
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
if you get the kit...use a 2.2L turbo it's really small has great boost response and will have less of a chance of poping your 10.5:1 compression
HeMan1320 is offline   Reply With Quote
Ball Bearing T25 Turbo on 2.5RS bambams247 Normally Aspirated with bolt-on Forced Induction Powertrain 6 12-05-2003 01:38 PM
Scooby Newbie Q: Eyelids on 2002 RS fukamoto Vancouver Impreza Club Forum -- VIC 13 01-30-2002 08:16 PM
newbie with a question on turbos on 2.5rs...which ones...???? QCK HNDA Normally Aspirated with bolt-on Forced Induction Powertrain 20 11-06-2001 02:51 PM
newbie with a question...2.5rs turbo question...which ones???? QCK HNDA Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 11-03-2001 08:10 PM
Legacy Turbo on 2.5RS? BongMan Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 17 03-22-2001 07:13 PM
