Old 02-12-2005, 06:35 PM   #1
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
Default ej25 same as ej257?
Over the summer I had the ej257 shortblock dumped into my WRX. Some Subi mechanic did the job for me on the side.. I was quite specific when I told him I wanted the ej257.
Something let go two weeks ago and I finally pulled the motor today. Stamped into the top of the block is "EJ25". Is it possible I didn't get what I paid for?
PeteDucati is offline   Reply With Quote
Old 02-12-2005, 07:02 PM   #2
Rippa
Member#: 39217
2003 WRX w/JDM 6MT
310whp/309wtq @ 19psi
From my understanding...
ej25 = 2.5 rs
ej257 = STi/FXT
I'm not 100% on this though, maybe the guru's can chime in on this one?
Rippa is offline   Reply With Quote
Old 02-12-2005, 07:13 PM   #3
kcook
Member#: 78074
2005 STi
wow that sux... ifu got the 2.5rs motor.. u should be able to tell from no TMIC... but if u got the sti engine.. u should know
kcook is offline   Reply With Quote
Old 02-12-2005, 09:08 PM   #4
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
EJ25 is on all 2.5L Subaru engines.
MZM is offline   Reply With Quote
Old 02-12-2005, 10:19 PM   #5
LiquidForce
Member#: 12811
2002 2.5l Wrx
517whp/516wtq (Stage pi)
I did the same swap this summer and I believe mine just has ej25 on it. I'll check tommorow for you when its light. I'd be amazed if an ej25 from an RS held up that long if you were still running the td05-16g.
LiquidForce is offline   Reply With Quote
Old 02-12-2005, 10:54 PM   #6
fogdor
Member#: 45726
2007 Mazdaspeed3
Cosmic Blue
^^^ What he said. I have seen an EJ257 being taken apart and it is indeed stamped "EJ25". I have NOT seen an EJ25 being taken apart but I would assume they are completely open deck blocks, without the support "ribs" at the top like the turbo'd motors have...
Linky of what I'm talkin about here -> http://wrxworld.com/projects/STIvsWRXEJ/index.htm
fogdor is offline   Reply With Quote
Old 02-13-2005, 05:59 AM   #7
PeteDucati
Member#: 44629
CNC 'd heads, cams
DB18g/EWG - F/S $8K
I'm not going to rip the motor down myself, I want the motor builder to do it so he can properly diagnose the problem. I should know more by the end of the week, and I'll update the post.
Ps. Oil started dumping out of the timing cover after hitting 20psi on the newly installed DeadBolt 20g. The Perrin catch can also leaked out a butt load of PCV sludge all over my engine compartment.. oil in the turbo and intercooler, but not much.. woo hoo to the catch can!
Old 02-13-2005, 11:29 AM   #8
LiquidForce
Member#: 12811
2002 2.5l Wrx
You probably lost a cam seal.
Old 02-13-2005, 11:29 AM   #9
gpatmac
Member#: 18446
2002 WRX wagon
psm
gpatmac is offline   Reply With Quote
Old 02-13-2005, 11:40 AM   #10
DeadBolt Enterprises
Vendor
Member#: 34272
2005 STi
Crystal Grey
You would have known if it was an RS block, it is a little bit thicker at the bell-housing in the area where the turbo mounts. The only reason I know this is that one of our dealers recently had trouble installing a 20G on an old Cobb worked 2.5L block that he had in his shop (he had it in the shop for over a year and a half). We started looking and realized that the reason the turbo would not mount (coolant line was hitting the bell housing) was that it was slightly thicker in that area than the EJ20 and EJ257.
DeadBolt Enterprises is offline   Reply With Quote
Old 02-13-2005, 05:58 PM   #11
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Axis, EJ25 is semi-closed.
unkadave is offline   Reply With Quote
Old 02-13-2005, 06:24 PM   #12
MZM
Member#: 514
07 Legacy Spec B
Impreza 93 STI
Default Coolant pipe and bell housing
FYI I just mounted your 20G on a EJ255 stock long block and the lower coolant pipe hits the bell housing. Not enough to get twisted shorts though. Torque the mounting bolts and it goes on after a slight remodel of the pipe. No problem.
Mike McBride
Old 02-13-2005, 06:29 PM   #13
unkadave
Member#: 55525
02 wrx wgn 2.5
Keep Right
Mike McBride
poooh The FPGreen is even a little bigger. Well at least I cans start planning for a soultion.
Old 08-16-2010, 04:04 PM   #14
sti-v8killr
Member#: 209562
2007 WRB STI
WHAT?
So do all EJ257s have an EJ25 stamp on top of the motor just under the alternator?
sti-v8killr is offline   Reply With Quote
Old 08-16-2010, 05:02 PM   #15
minifreak
Member#: 116914
2006 WRX Wagon
Obsidian Black
Yes, my ej255 wrx engine has the EJ25 stamped on it.
minifreak is offline   Reply With Quote
Old 08-16-2010, 06:38 PM   #16
Byzantium
Member#: 207826
85k 2002 WRX
Correct Fitment Crew #034
So you had to bump a 5 yr old thread for this?
Byzantium is offline   Reply With Quote
Na ej25 crank same as STI ej crank? bigolrig Newbies & FAQs 11 11-18-2009 04:48 PM
EJ257 cams same as 07 WRX EJ255 cams? Davenow Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 12 01-14-2008 03:26 PM
ACL bearings: N/A EJ25 same as WRX/STI EJ25? Patrick Olsen Built Motor Discussion 2 09-23-2007 12:02 AM
Phase I EJ25 Rods The Same As EJ22T's? MY99 2.5GT Built Motor Discussion 10 07-09-2007 12:15 AM
SOHC EJ25 heads : turbo same as N/A jsteele22 Normally Aspirated Powertrain 6 02-24-2006 11:08 PM
