#1 |
Techno Sapien
Moderator Member#: 449
Vehicle:2010 Legacy 3.6R Lim Azurite Blue Pearl |
#2 |
Member#: 61636
Vehicle:2004 Forester XT 1998 Ford Ranger |
Well, I'll be dipped....learned something totally unrelated from this. Just out of curiosity I clicked on the link to see what this mod is like. Peaty mentions location near "coin holder by driver's left knee." What?! What coin holder? That's always been a minor aggravation of mine that the Forester has no coin holder, and I've been using the ashtray which really doesn't work too well as a coin holder. So I go out to the garage and check, and sho enuf, there's a nifty little drop-down coin holder! Cool! Can't believe I missed that all this time.
This will make my trips through drive-thrus so much more enjoyable.See what we can learn from Peaty? All hail Peaty! |
#3 |
Techno Sapien
I lined the inside of my coin tray / fusebox cover with some rubber material so I wouldn't hear the coins rattle around
As an added bonus, you can remove that tray by opening up the hatch and pulling up and out. On the back of it tray is a map of the fuses ![]() |
#4 |
Member#: 33566
International
Hey Peaty, I searched ScoobyMods a bit for the fog light mod (separating the fog lights from the rest of the lighting) and wasn't able to find anything specifically for the Forester. Is it similar to the WRX or do we have different wiring?
#5 |
Techno Sapien
I haven't done that mod myself (I only run my fogs in the rain and fog w/headlamps) so I can't say for sure. I do suspect that they are similar though. What may be different is the wire colours.
I checked the forester site and here it is: http://www.subaruforester.com/viewtopic.php?t=4727 |
#6 |
Member#: 54604
Vehicle:2004 FXT Cayenne Red (sold) |
Peaty,
That's the same one for the climate control fix, right? I'll need one to wire in my LM-1. Guess I could run both the fan and the WB02. Frank |
#7 |
Member#: 1519
Vehicle:1998 Volvo V70R Silver |
color me a tech misfit, but what other uses might this little discovery serve? an XM unit?
#8 | |
Member#: 54604
Frank |
#9 |
Member#: 44501
South East
Vehicle:1984 "Skeletor from "He-Man" |
So... does anyone know what circuit this hot wire uses?
#10 |
Member#: 32636
Vehicle:2004 Impreza STi Silver/Silver |
Slight resurrection on this one; but does anyone know what fuse this goes back to. Or maybe just what kind of load I would be ok with before needing a relay on this wire? I am planning on hardwiring my RX65 and LE-30 and this is actually a perfect spot for me. I am guessing those two aren't too much for whatever this is/was for, but better to ask first than when there is a problem.
offset |
#11 |
Member#: 32636
Wait, I just double-checked and this is listed under the Forrester. Guess I need to go out and see if that wire is in the STi as well. If not, without more searching anyone care to share the best spot in that same area to tap power from?
offset |
#12 |
Member#: 3371
Vehicle:2004 Forester XT Java Black |
great find Peaty.
I found this exact plug & wire back when I was wiring my FF1000's so I used it as a 12v power source for the rocker switch on the lights. Then I decided to add an aftermarket sub and amp so I wired the hellas in with the high beams and I am now using the rocker switch to turn the amp on and off. At the time I was trying to figure out where I was going to get my 12v power from then I stumbled across this wire and tested it with the ignition on and off lets just say I was really happy after that. |
| Thread Tools | |
| Display Modes | |
| Exhaust leak sound from inside the cabin | Ryan314 | Service & Maintenance | 3 | 05-19-2010 03:51 PM |
| HELP-Need to find a wire for switched 12V inside the cabin....anyone know? | dchou | Electrical & Lighting | 2 | 02-07-2007 09:13 PM |
| Problem.... Sounds like "boost/air" inside the cabin...HELP! | essteaeye | Factory 2.5L Turbo Powertrain | 27 | 06-27-2005 02:39 PM |
| Stage 0, my car "hums" inside the cabin w/ the AC on. Whats up?? | wayoutwest | Factory 2.0L Turbo Powertrain | 19 | 08-14-2002 07:27 AM |
| Annoying Rattling Inside the cabin | Die Civic | General Forum Archive | 12 | 02-19-2001 01:10 PM |
