02-13-2005, 06:16 PM | #1 |
Member#: 81483
Vehicle:2004 Forester 2.5XT White |
2004 Forester 2.5XT - TIRES
I own the vehicle and would like to put the STI wheels and tires on it.
My dealer tells me they will not fit. I found a dealer with a used set from the STI. They say, just bolt them on. Will they fit? I hate the stock tires and will put snow tires on the stocks wheels. Need a performance set.
02-13-2005, 06:53 PM | #2 |
Member#: 23260
BAIC
Vehicle:Patr ick Willis for Rookie of the year |
02-13-2005, 07:04 PM | #3 |
Member#: 4562
NWIC
Vehicle:2014 Electric Datsun 2005 Adventure van |
As long as it is for a 04 it will fit.
Do you plan to lower it at all? If not your car is going to look very strange. |
02-13-2005, 09:13 PM | #4 | |
Member#: 4955
South East
Vehicle:2004 FXT OffRoadSubarus.com |
02-13-2005, 10:50 PM | #5 | |
Member#: 1519
Vehicle:1998 Volvo V70R Silver |
Because the first dozen posts will be from WRX owners who don't know a thing about Forester offsets. This is the Forester forum, the person has a Forester question, and I think we can handle it from here. Bunny- '05 STi rims won't fit. '04 STi rims will, but you are going to be cutting it close on the offset; some would say too close if you intend to play with the suspension setup. Those tires are 225/45/17 which will work, but are going to look a little funny on stock ride height. They are also going to throw your speedo and odometer off. It depends on how deep you want to get into this, and what you want out of the car. |
02-14-2005, 07:44 AM | #6 |
Member#: 4955
South East
If a factory wheel is what you are after. Outback wheels have the correct offset for the Forester, 48 mm. They can be found in two flavors. 16 x 6.5 with 225-60-16's or even better 17 x 7 with 225-55-17.
Good luck, Richard |
02-14-2005, 11:34 AM | #7 |
Member#: 57149
NESIC
Vehicle:TMHK Thomas B Hanks First 6 |
Just outback wheels? Legacy GTs don't have the same offset?
Ben |
02-14-2005, 12:14 PM | #8 | |
Member#: 11070
Vehicle:2004 SG5 |
02-14-2005, 01:46 PM | #9 |
Member#: 4955
South East
Offsets are different between the Outback and LGT. The LGT's are not 48 mm, which is too bad because some are real nice looking LGT ones.
Richard |
02-14-2005, 02:57 PM | #10 |
Member#: 57149
NESIC
THANX
Ben |
02-14-2005, 04:44 PM | #11 |
Member#: 11070
Vehicle:2004 SG5 |
bummer. but then again, there are folks over at subaruforester.com running RS wheels which are +53mm if i remember correctly. they say they have no problems. go figure.
02-14-2005, 05:23 PM | #12 |
Member#: 1519
Caddy- I think it is more of an issue with 17s, since you get that much closer to the spring perch. 16s are easier to run on Impreza-spec offsets
02-14-2005, 06:32 PM | #13 |
Member#: 71056
BAIC
Vehicle:MY04 Forester XT PSM |
I have a set of 17" Prodrive P7's with a 52 mm offset, and I've never had any problems either. I could be wrong, but I don't think 5 mm either way will be a dealbreaker, even with 17's.
02-14-2005, 07:11 PM | #14 |
Member#: 11070
Vehicle:2004 SG5 |
so many contradicting opinions.... is there a source for an absolute resolution on this matter? otherwise we're just speculating really.
02-14-2005, 08:37 PM | #15 |
Member#: 1519
well THAT might be an SF vs. SG thang. Pioneer Lark6 attempted to run P7s on his SF and they rubbed, se traded them off for a swet of Superleggeras (+48).
02-15-2005, 08:19 AM | #16 |
Member#: 57149
NESIC
I'll order a LGT wheel today and hopefully have a definate answer tomorrow. I have the pink springs but I don't think that will affect anything. Stay tuned.
Ben |
02-15-2005, 08:23 AM | #17 | |
Member#: 2715
Vehicle:1970 911T Irischgrün |
Cliffs Notes version of my trial and error: SF: 225/55-17 on P7s = rubbing front & rear 225/50-17 on P7s = rubbing front & rear 225/50-17 on OZ SLs = okay! Traded SF for SG August '04. SG: 225/50-17 on OZ SLs = okay! I understand 225/55-17 will work okay with a +48 offset on the SGs as well, but I've still got a lot of good tread life left in the 225/50s. Hope this helps. Ed |
02-15-2005, 09:48 AM | #18 | |
Member#: 767
Vehicle:04 FXT 20 OB Onyx XT |
-Dennis |
02-15-2005, 10:00 AM | #19 |
Member#: 44464
Vehicle:2004 FXT-MT w/hitch for my c-crib |
i'm running 225x50x17 on BBS RK's 48 offset (from my WRX WGN) and they look, ride and perform great!
I also have the JDM Forester STI springs, 20mm sway with poltek endlinks ... (i'm a peaty copycat and love it) |
02-15-2005, 10:20 AM | #20 |
Member#: 1519
Ed's first Forester (OEM rims):
02-15-2005, 10:25 AM | #21 |
Member#: 57149
NESIC
I'll take a set please.
Ben |
02-15-2005, 11:00 AM | #22 | |
Member#: 2715
GIS "Conestoga" and you also get this, which is closer to the other car I have in my garage: |
02-15-2005, 12:22 PM | #23 | |
Member#: 71056
BAIC
02-15-2005, 12:48 PM | #24 | |
Member#: 767
Ed, The front and rear wheel circumference on your Conestoga is greater than the 1/4" difference advised by SoA. You're really gonna toast your diffs. -Dennis |
02-15-2005, 01:23 PM | #25 |
Member#: 57149
NESIC
I'll tell you how the 225-55's with pinks work after tomorrow.
Ben |
Blow off valve for 2004 Forester 2.5XT | SirWilliam | Newbies & FAQs | 10 | 06-25-2004 05:59 PM |
2004 Forester 2.5XT = 13.8secs@97mph 1/4 mile | daytontp | General Community | 75 | 11-25-2003 06:33 PM |
2004 Forester 2.5XT turbo? | markraz | Normally Aspirated with bolt-on Forced Induction Powertrain | 4 | 06-20-2003 02:25 PM |
2004 Forester 2.5XT its coming | WestCoastPimp | News & Rumors | 6 | 02-22-2003 01:01 AM |
2004 Forester 2.5XT | lakepop | Forester Forum | 74 | 02-18-2003 09:59 AM |
