Old 02-13-2005, 08:49 PM   #1
Keith
Member#: 191
2012 J train
Brown
Default almost done...new problem!! wee
So, thanks to Mumbles for his help this weekend, I can now turn my car and put gas in it
next problem.
When I let off the gas, (after the car has been driven about 5 miles), I hear this sound that sounds almost like grinding.
Part throttle (very little throttle) I hear it also, very loud.
After driving on the highway for a while, when I put the car in netural, the sound happens.
On the gas? no sound at all. Only when I let off the gas, or am part throttle
it seems as though it is coming from the rear end.
Is my diff brok3d?
The rear diff/tranny are from an 03 wrx, and I'm using 98 axles/hubs.
This sound DOESN'T happen when the car is cold though, takes a few mins after driving around for it to happen again.
There is fluid in the dif as well (correct weight)
ideas?
keith
Keith is offline   Reply With Quote
Old 02-14-2005, 12:36 AM   #2
PHATsuby
Member#: 13617
2001 Legacy GT back
to stock is a project too
I vote for rear diff, did you check the teeth mesh and backlash? If it is off that could be causing the issues.
sorry dont have any other info or ideas.
Ben
Old 02-14-2005, 01:31 AM   #3
Hurley 2.5 WRS
Member#: 43916
2001 Impreza 4.7
Blue Ridge Pearl
yup, its most likley the backlash and shimming. off throttle sound, but on throttle none.
Hurley 2.5 WRS is offline   Reply With Quote
Old 02-14-2005, 09:32 AM   #4
AKGC8
Member#: 1305
2000 Impreza
You seated the half shafts into the diff completely right?
AKGC8 is offline   Reply With Quote
Old 02-15-2005, 12:41 AM   #5
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
....grinding.... no good... I think, we heard that noise once on saturday, but we figured it was just your door.
Old 02-15-2005, 12:49 AM   #6
Mumbles
Member#: 248
Hmm the rear half shafts were entirely seated... Maybe they slipped out? This is strange, when i drove the car is was perfectly fine. What happened? haha. Let us know what develops.
You did check your tranny fluid right?
-B
Mumbles is offline   Reply With Quote
Old 02-15-2005, 08:24 AM   #7
Keith
Member#: 191
2012 J train
Brown
yeah dude, checked it.
Like I said before, this only happens after the car is driven for a little while/highway.
When I drove there, I thought it might be the half shafts, when we got them in I was all excited.
I took fishy out on a coffee run and he started to notice it, then when i drove home, once I got on the highway it started.
fluid was all there (both in diff and in tranny)
Old 02-15-2005, 08:31 AM   #8
Mumbles
Member#: 248
Dam. I can't tell if i can't hear it, but most likely it is the lash on the diff. Which sucks because we have no way to fix it ourselves. If you know anyone good with this i suggest you seek them out. It might have happened when you were driving with them slipping, one side and not the other etc.... might have toasted it.
-B
Old 02-15-2005, 09:06 AM   #9
Keith
Member#: 191
2012 J train
Brown
hopefully some stupid n00b crashes his wrx so I can take his rear diff..ehheh friggen things are xpensive man (junkyard wanted $400.00 for it).
Old 02-15-2005, 11:18 AM   #10
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
godspeed has/had one for 250
buy it and sell me yours for 50 i only need the lsd part
Old 02-15-2005, 11:21 AM   #11
Keith
Member#: 191
2012 J train
Brown
i found one for 150, i might pick that up, i'll sell u mine if ur interested
1 new tire on rear, other 3 almost done - big problem? SlackMeister Tire & Wheel 5 08-06-2005 06:08 PM
Swap almost done. tranny problem. guru's of mid-a, please help. AzNStiImpreza Mid Atlantic Impreza Club -- MAIC 1 07-18-2005 03:36 PM
After 6 month my suby totalled.My new Toy is almost Done SpoonTypeR Vancouver Impreza Club Forum -- VIC 37 04-11-2005 10:03 PM
My new model car, almost done. ImprezedRS Off-Topic 19 12-12-2002 07:11 AM
