Old 02-14-2005, 08:39 AM   #1
White2.5GT
Member#: 25142
1998 Legacy 2.5GT
Default CV Axles
I think that the CV joints in my 1998 Legacy GT are going in the rear and I'm looking into the replacement of the whole axle as I heard that it would be cheeper then getting the joints replaced. I called my loacal dealership and they said that it would take 2 hours to replace each axle. I thought that it was a bit long (they might just be giving some EXTRA time)
So how long does it take to pop out the old axle and pop in a new one?
White2.5GT is offline   Reply With Quote
Old 02-17-2005, 09:53 AM   #2
Bottom Feeder
Member#: 2808
I've never done it before, but I know what's involved for the most part. If I had the car on a lift and the right tools (like the dealership certainly would have), I'm pretty sure even I could replace an axle in less than two hours. There's no reason why a trained mechanic shouldn't be able to replace both in two hours.
Bottom Feeder is offline   Reply With Quote
Old 02-17-2005, 01:40 PM   #3
subenerd
Member#: 72630
2004 STi
Post # 9 has great instructions for removing the axle.
http://forums.nasioc.com/forums/show...ight=torn+boot
I had a torn cv boot so me and a friend removed the axle, cleaned it, found out that the axle was in perfect condition so we only replaced the rubber boot and new grease. Total time was about an 1.5 hours (first time/beginner mechanics)
EDIT: That was for a wrx, dont know if the insructions are the same for a Legacy
subenerd is offline   Reply With Quote
Old 02-26-2005, 10:32 PM   #4
RRRR1
Member#: 51329
2002 WRX SEDAN
WHITE
In Indy we have a place, Indy Rac & Axle, remanufactured $189.99. You should have some place local like that. I would use them i I needed them.
I can remove and axle in 20-30 min.
And don't foget the sprung roll pin on the trans end of the shaft. I would replace those.
RRRR1 is offline   Reply With Quote
STi rear CV axle snapping? outbckspt96 Transmission (AT/MT) & Driveline 4 03-28-2005 06:40 AM
Need help sourcing (rebuilt) CV axles bliu South East Region Forum 5 03-02-2005 03:18 PM
is it hard to rebuild cv axles yourself turbocolin Transmission (AT/MT) & Driveline 3 08-21-2004 04:13 PM
Will the front CV Axles from a 2.5RS fit my 95 L? marcus12 Transmission (AT/MT) & Driveline 4 07-30-2004 10:01 PM
CV Axle question for the gurus marcus12 New England Impreza Club Forum -- NESIC 3 07-30-2004 07:38 AM
