Old 02-14-2005, 01:28 PM   #1
Geoffman72
Member#: 27891
2001 Impreza 2.5 RS
Blue Ridge Pearl - R.I.P.
Default Ummm, wow thats a lot of check engine codes
So my 01 RS has been acting like an out of tune carbed car in Antarctica. I go to the local autozone to get the codes pulled and they come up with;
Air Metering Sensor
Cylinder misfire on ALL banks
Catalyst inefficiency
Only mods on the car are a exedy lightweight flywheel and sport clutch. The plugs and wires were changed 8,000 miles ago and the vehicle only has 65,xxx on it. I do realize the lightweight flywheels do cause cylinder misfire codes also, but I dont believe this to be the case here.
How it drives;
I do think the cats might be clogged as the car just runs like its got a plug in its butt.
Sometimes it feels semi-ok. but other times it will spit sputter bog down backfire, etc.
Anyone have any ideas before I take it to the dealer?
Geoffman72 is offline   Reply With Quote
Old 02-14-2005, 01:36 PM   #2
RexyGirl
Member#: 63616
1996 Volvo 850 Turbo
with mods :)
If it is your cat convertor, it is covered under 8/80 warranty.
From they symptoms you described, sounds like that is probably it. To be sure, reset the light and when it comes back on, have it checked again. More than likely only one code will come back..the rest may have been in memory or triggered from the cat convertor.
RexyGirl is offline   Reply With Quote
Old 02-15-2005, 12:00 PM   #3
MrHorspwer
Member#: 4063
This may cause your misfire DTC.
The ECM determins if a misfire condition exsists based on the input from the crankshaft position sensor. On a smoothly running engine, a smooth and solid stream of data is received from the crank sensor. When a misfire occurs, a *stutter* is registered by the crank sensor (because there is no firing on a particular cylinder, the crankshaft quickly slows down, then speed back up as the next cylinder fires). This is interperated as a misfire by the ECM.
With a lightweight flywheel, an engine is allowed to rev quicker. The engine may now be able to rev at a rate that is faster than the crank sensors resolution. This will cause the crank sensor to *miss* signals. The ECM will also interperate this as a misfire.
It is very rare to have an engine misfire across all cylinders. Typically, you'll have one or two cylinders that will be your culprit. When you start seeing a scattering of misfire activity that shows no pattern, I'd be willing to bet that your flywheel is the culprit.
MrHorspwer is offline   Reply With Quote
Old 02-16-2005, 01:06 AM   #4
happyparrot
Member#: 61896
1998 2.5rs S/C
RBP
Exacly!
happyparrot is offline   Reply With Quote
Old 02-17-2005, 11:05 PM   #5
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
Well, if your air sensor is failing (error 1), it will in turn cause a misfire since the ECU does not know the actual A/F ratio (error 2). Prolonged misfire, or backfire will in turn damage your catalytic converters (error 3).
Check your MAF or MAP sensor (whichever your car uses) and make sure it's operating within specs. I would get the misfiring problem fixed before you cause even more expensive damage to the catalytic converters.
BJamerican is offline   Reply With Quote
Old 02-17-2005, 11:15 PM   #6
Uncle Scotty
Member#: 16200
OK buy Nates beans
westcoastroasting.com
ding...ding....ding.....
...and NOT posting the codes themselves....ie 'Pxxxx' is pointless for us to try to help, really. Some of us have the FSM and can help a great deal if you post the actual code..
Old 02-18-2005, 12:07 AM   #7
BJamerican
Member#: 5595
2005 Legacy 2.5GT
Satin White Pearl
I know the cat inefficiency code is P0420. My car throws that code about twice a year, and my dad's Outback recently started throwing that code randomly. In my case though, I'm guessing that an oxygen sensor is going bad since they have not been replaced in 136,000 miles!
need a lot of help w/ check engine codes suby ej25 Tri-State Area Forum 8 01-26-2005 11:02 PM
Help with check engine code Meche 2.5RS Normally Aspirated Powertrain 1 10-10-2001 06:20 PM
Check engine codes Wildman Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 07-21-2001 07:04 PM
Check Engine Code P0302, "#2 Misfire" hillman Legacy Forum 5 06-26-2001 03:14 PM
Check engine codes Kruf General Forum Archive 1 12-17-2000 05:46 AM
