Old 02-14-2005, 05:57 PM   #1
BlackoutWRX
Member#: 74589
2000 94 Infiniti G20
90 S13 Coupe
Default how often do you change your air filter?
every other oil change? every 10 thousand miles? how often do you do it?
BlackoutWRX is offline   Reply With Quote
Old 02-14-2005, 06:06 PM   #2
mainerex
Member#: 70092
2002 wrx stage4+
psm
buy a k&n filter and then clean it as it needs its
mainerex is offline   Reply With Quote
Old 02-14-2005, 06:14 PM   #3
zinc99
Banned
Member#: 56030
02 stage 2 wagon
Dont get an K&N the oil in those filters is well known for messing up your MAF sensor. Get an perrin or something else that can be cleaned.
zinc99 is offline   Reply With Quote
Old 02-14-2005, 06:18 PM   #4
BlackoutWRX
Member#: 74589
90 S13 Coupe
nah im more into wasting money to save the hassle. im not looking for alternative ideas, i just want to know how often you guys change yours (for those of you that change them)
Old 02-14-2005, 06:22 PM   #5
zinc99
Banned
Member#: 56030
02 stage 2 wagon
In that case when its dirty(looking at it big dark spot), or every 20-30k. But that depends on were you are driving >20k if its dirty roads and dusty, 30k if its a nice clean city.
Old 02-14-2005, 06:23 PM   #6
Subie Gal
GC84Ever
Super Moderator
Member#: 301
1970 FF-1 & '70 Van
02 WRX/01 RS
I just change it when it needs it
on the rally car? 1 - per day - per rally
on my street car?
i check it every-other oil change just to be safe
jamie
www.subiegal.com
Old 02-14-2005, 06:44 PM   #7
mmorningstar
Member#: 73432
2008 Ford Mustang GT
Performance White
damn, I keep forgeting to order that HKS foam filter...thanks for reminding me...
mmorningstar is offline   Reply With Quote
Old 02-14-2005, 06:45 PM   #8
powerslide23
Member#: 61956
2008 Tribeca
Pearl White Metallic
Just like Jamie said, change it when necessary. If you normally drive on freeways and less dusty environment, every 15K is just right. More than 15K, IMO should be fine but may not have the optimum air flow and filtration again that just a guess-timate.
powerslide23 is offline   Reply With Quote
Old 02-14-2005, 07:35 PM   #9
rbcsaver
Member#: 78039
02 WRX
WRX Blue
Standard is to hold it up to the sulight and if you can easily see sunlight through it then it is OK.
regards,
Steve
rbcsaver is offline   Reply With Quote
Old 02-14-2005, 08:45 PM   #10
BillJC
Member#: 31002
I haven't changed mine for 50k miles. I put an K&N in there and forgot about it. Everytime I look at it, it keeps getting dirtier and dirtier but, it still allows sun light to pass. This thread reminded me to check it out again.
BTW, I haven't cleaned it in all this time either.
Bill
BillJC is offline   Reply With Quote
Old 02-14-2005, 08:54 PM   #11
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Once a year or every 10-15K.
The K&N filter is not the problem. Its the over-zealous owner that cleans and re-oils his filter with too much oil.
OneOBS is offline   Reply With Quote
Old 02-14-2005, 11:50 PM   #12
skinart76
Member#: 30769
2003 WRX Wagon
Sonic Yellow
Yep, K&N is actually pretty good. I cleaned mine at the 30K mile tune. People often over oil the filter, therefore causing the dirty MAF sensor. K&N filter actually works better when it's a bit dirty, so no need to clean it that often.
skinart76 is offline   Reply With Quote
Old 02-15-2005, 02:52 AM   #13
Gethin
Member#: 2998
Cleaned my K&N 4 times since it was new, no problems. I let it dry after oiling it liberally.
Gethin is offline   Reply With Quote
Old 02-15-2005, 08:31 AM   #14
Hayes
Member#: 11808
I change mine at ~30,000 and it still looks quite good. Most filters do a better job of filtering as they age (within reason) so changing every 5 or 10,000 miles may be doing more harm than good. Off roading or gravel driving is another issue. ed
Hayes is offline   Reply With Quote
Old 02-15-2005, 08:32 AM   #15
Hayes
Member#: 11808
I like my car too much to use anything but oem or equivlent.
Old 02-15-2005, 08:41 PM   #16
BillJC
Member#: 31002
I hate my car, that's why I use a K&N.
Old 02-15-2005, 10:49 PM   #17
Integra96
Member#: 64196
2010 Family Sedan
I just changed mine at about 10k miles. It was filthy and somewhat clogged up with crap. I live in super-dusty Southern Arizona.
Integra96 is offline   Reply With Quote
Old 02-18-2005, 08:18 AM   #18
TJRCS
Member#: 59199
2008 STI
wow~ I did my first change at 7.5K. I'm also planning to do around 15K again.
TJRCS is offline   Reply With Quote
Old 02-19-2005, 02:46 AM   #19
erikkellison
Member#: 67412
2013 WRX
Let it dry?
Correct me if I'm wrong, but I'm pretty sure oil doesn't evaporate that readily, so "letting it dry" isn't really doing anything. You might want to blot it off or something next time, because if you oil the filter liberally, the only way to get excess oil out of the filter is to remove it. It won't disappear on it's own, unless you blow on it under pressure by installing it and running your car, which would then put you in the group of people that over-clean and over-oil their K&N's, and thus mess up their MAF. And I know you don't want that
erikkellison is offline   Reply With Quote
Old 02-19-2005, 05:31 AM   #20
en3d
Member#: 5238
GGA Black
What I did was buy a K&N but kept my stock one. when I clean/oil my k&n, I run my stocker until I know all the excess oil is off (usually a couple of days).
Do I "over-oil", don't think so but rather be safe than sorry with the MAF.
en3d is offline   Reply With Quote
Old 02-19-2005, 10:49 AM   #21
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Every 30k like the manual says. I check it at 15 though and turn it around to even out the dirt deposits. How often to change it really depends on how dusty your area is.
Mike Wevrick is offline   Reply With Quote
Old 03-13-2005, 08:44 PM   #22
shemoves
Member#: 80663
2005 STi
I thought the Perrin still had to be oiled...? Anyone know of an air filter that is washable, reusable, non-oiled, and has both good flow and filtering?
shemoves is offline   Reply With Quote
Old 03-14-2005, 06:58 PM   #23
JasonCSU
Member#: 40864
2003 WRX
2008 BMW 135
I'm curious as well. Right now I'm deciding between a Perrin, K&N, and a plain paper filter.
JasonCSU is offline   Reply With Quote
Old 03-14-2005, 07:15 PM   #24
DrD
Member#: 22412
2012 Legacy 2.5GT
Ice Silver Metallic
I change it once a year (10k miles or so) - it's pretty dusty here, though.
Old 03-16-2005, 02:35 AM   #25
eltrouble
Member#: 79493
2003 WRB WRX Wagon
5 doors > 4 doors
eltrouble is offline   Reply With Quote
How often do you change your synth oil in your wrx D-I-Z-Z-L-E Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 58 12-03-2012 08:30 PM
How often do you change your underwear? FunkerVogt Off-Topic 28 12-21-2006 02:18 AM
OT guitarists: how often do you change your strings? ToddZ199 Off-Topic 26 05-04-2006 01:41 AM
How often do you change your oil? Chris51080 Service & Maintenance 14 04-23-2003 07:52 AM
Newby question, how often do you change your oil? SteveGood Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 2 09-21-2001 02:53 PM
