Welcome to the North American Subaru Impreza Owners Club Monday August 29, 2016
Go Back   NASIOC > NASIOC Technical > Engine Management & Tuning > Other Engine Management
Old 02-14-2005, 07:37 PM   #1
Yeah baby
Member#: 68200
Default Hydra MAF Question
Can I get rid of the MAF in my STI and just wire in a intake temp sensor into the intake going to the turbo? Or is it better to tap it rite into the manifold..Thanks
Yeah baby is offline   Reply With Quote
Old 02-14-2005, 08:09 PM   #2
bboy
Member#: 56468
04 Improved STI
Dirty White
You could get rid of the MAF, but you'll need to know the type signal the MAF sends to the Hydra. I'm not sure that its a simple thermocouple signal, but if it is, those are cheap to buy and easy to install in your intake. www.omega.com has tons of different ones. I'd pick a Type that corresponds to the stock MAF one. Type K is the most common.
Old 02-14-2005, 08:44 PM   #3
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
8cmFP Red, RA 5spd, Hydra
Some people have put IAT sensors on the intake manifold or used a JDM manifold that already has an IAT sensor on it. Ask Phil. He should know since he's not using the maf on his car. I plan on doing the same same thing so I can use post intercooler temps. I think I remember Darth say that he runs a JDM manifold with the IAT sensor.
CK02WRX is offline   Reply With Quote
Old 02-14-2005, 08:46 PM   #4
Yeah baby
Member#: 68200
so I guess a regular ford/chevy intake sensor won't work? Also would anyone know which wires to use?
Old 02-14-2005, 08:52 PM   #5
CK02WRX
Member#: 27859
2002 EJ257 w/CP's
I'm sure it could be made to work but the question is: What is better/easier? I wish I had the answer since I plan on doing the same thing but my attention has been focused on getting a new tranny so I can aleast drive my car.
Old 02-14-2005, 09:24 PM   #6
bboy
Member#: 56468
04 Improved STI
Dirty White
I'm still looking but it seems the WRX/STi IAT sensor is a 5V thermoresistor. The Hydra would measure current running through at 5V.
You would need to run it into the same MAF connector in the engine bay, but thats a matter of figuring out the pinout of that connector.
Old 02-14-2005, 10:58 PM   #7
bboy
Member#: 56468
04 Improved STI
Dirty White
http://www.innovatemotorsports.com/f...p?threadid=255
Good read on basics of IAT; the best I could find.
The one they mention from DigiKey is $2.83. You can't beat that. There are only 13335 left, so hurry out and get one. www.digikey.com
Here are the key things you need to know:
1) input voltage (I believe it's 5V for ours)
2) thermistor resistance rating (the above is a 2.2 kOhm resistance, NTC)
Be sure you get these two right or the Hydra won't know what to make of the temp (voltage drops as resistance goes up and temp goes up (NTC)). Also, I have reason to believe that the IAT data may be used to set the wastegate duty as well as fuel trim. With two parameters in the mix, getting it right will be important.
As far as the MAF pinout is concerned, I can't find any info on which wires run to the thermistor. I may cut my dead MAF open and tell you later.
Old 02-18-2005, 04:13 PM   #8
Yeah baby
Member#: 68200
Talked to Andrew today..A Chevy IAT will work fine..
Old 02-19-2005, 09:33 AM   #9
Element Tuning
Member#: 54918
673 WHP Element
Tuning Pro Comp Engine
The GM IAT is the one you should use but keep in mind you will most likely have to retune the "Intake Air Compensation" maps for both fuel and ignition. It may only be minor if you run the sensor before the turbocharger.
I've had very good luck using the factory MAF sensor without the limitation of the stock housing (3.5" intake) but a post turbocharger IAT is always better. It will have to be tuned.
If you've never tuned the Element Hydra system, I would advice you first use your MAF and then upgrade later.
Thanks,
Phil
www.elementtuning.com
Element Tuning is offline   Reply With Quote
Old 02-19-2005, 09:54 AM   #10
antimullet
Member#: 44193
2008 WRX STi
Phil, can you detail this? Did you make a custom larger turbo inlet pipe, and then just mount the stock maf in it?
Thanks,
Mullet
antimullet is offline   Reply With Quote
Old 02-19-2005, 01:08 PM   #11
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
The JDM intake manifold does come with a IAT sensor in it, and as far as I can tell, reads exactly the same as the sensor on the MAF. I took both of them off the car, and laid them in my garage.. and then measured the resistance on both. Identical. Then I put both of them in my refrigerator (what's for dinner? Its not beef!) and again... identical.
I've been running the JDM intake/IAT for a few months now, and its worked very well. I've just got vampire clips on the stock maf harness leading to the sensor.
What I HAVE had to adjust is the fuel compensation for temperature differences. The temps inside the intake seem to be "smoother", not near as jumpy as at the MAF housing. Makes sense - intercooler, turbo, hot engine, etc.... all of that smooths the huge changes you would normally see.
Just made sure, whichever sensor you go with, is a fast reacting one and that you get it calibrated correctly.
DarthChicken is offline   Reply With Quote
Old 07-09-2005, 04:19 PM   #12
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Where on a JDM intake manifold is its IAT sensor? I assume you meant to say throttlebody assembly?
jblaine is offline   Reply With Quote
Old 07-09-2005, 04:45 PM   #13
DarthChicken
Member#: 9073
2006 ariel atom
wrb/bbs gold frame
No, the V8 intake manifold has a seperate IAT sensor, right under the throttle body. Next to the PCV valve.
Old 07-09-2005, 05:12 PM   #14
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Oh. Hm.
Old 07-25-2005, 01:29 PM   #15
AZScoobie
Member#: 8785
02 [email protected]
netcom.com
V7 spec C cars had this sensor under the intake manifold. It is used by the ecu for the IC water spray. I wonder if the US STI has one as well. If thats the case you can buy that sensor at the dealer.
Clark
AZScoobie is offline   Reply With Quote
Old 07-25-2005, 01:32 PM   #16
n2xlr8n
Member#: 18960
02 WRX MBP
It lives! ; )
Thanks for the info; I must have missed this post.
n2xlr8n is offline   Reply With Quote
Old 01-25-2007, 05:43 PM   #17
ride5000
Member#: 32792
2003 GGA MBP
12.9 / 105+
hey, who's got a part number for this jdm sti iat manifold-mounted sensor???
OR, who's got a spare one from a pull?
ken
Old 01-26-2007, 11:02 AM   #18
Element Tuning
Member#: 54918
673 WHP Element
From my understanding most ended going back to the "bolt the MAF in the fender" mod. The intake manifold sensor would heat soak and take too long to register the colder air after the car had been sitting at idle. I've been running the MAF in my fender well for years and have never felt the need to change. Also I have configured the IAT correction tables to work in this orientation. It's similar to the intake temps you would see from a cold air intake.
Thanks,
Phil
Old 01-28-2007, 11:59 PM   #19
jigga
Member#: 9960
2002 Impreza WRX
WRBlue Perl
Thanks,
Phil
But how do you mount the maf sensor in the fender when using a turbo with a 4 inch intake without restricting things?
or does one just get a maf sensor 'flange' welded into the side of the 4 inch intake piping??
jigga is offline   Reply With Quote
Old 01-29-2007, 01:14 AM   #20
AZScoobie
Member#: 8785
netcom.com
You dont J.
Clark
Old 01-29-2007, 01:39 PM   #21
rjrutzky
Member#: 30367
2005 Legacy GT
NASA SE PTB Champ
From what I am gathering, you just bolt the sensor itself in the fender (no pipes involved) and this gets ambient air temps. I worried about this at first thinking that the MAF would go bad being exposed to debris, but now I realize that the maf sensor and the IAT sensor are two different things. And the IAT part of the MAF/IAT sensor is more rugged and has lasted in many others applications. Just let 'er breathe free if you have a MAP based ecu
rjrutzky is offline   Reply With Quote
Old 02-14-2008, 12:22 PM   #22
upnorth
Member#: 118573
07 STi
I am surprised that so many people would mount their IAT sensor in the engine bay. At high engine loads/speeds i would imagine the IAT sensor would read lower due to all of the convective cooling of the air at high speeds. But the actual intake temp of the air would be higher due to the turbo compresssing the air. Wouldn't this actually make the correlation work the wrong way? I guess a really good intercooler would go along way to evening the gap but it kind of takes the logic out of the correction imo.....
upnorth is offline   Reply With Quote
Old 02-14-2008, 12:45 PM   #23
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Sorry if this sounds flippant, but there's no point in discussing this any further until someone has figured out a fast-reacting IAT solution for mounting at the intake manifold that works with the Hydra properly.
The maps Phil made are for the stock MAF/IAT pre-turbo and it works well enough for just about everyone.
Is it perfect? No, but many people are over-emphasizing the importance of this. Unless you're competing in an EXTREMELY tight class of cars somewhere where every 1/8th HP on your bleeding edge engine tune is crucial, it doesn't apply to you.
Old 02-14-2008, 01:32 PM   #24
upnorth
Member#: 118573
07 STi
your point is well taken ... do you have a link handy to a thread that discusses where we're at in more detail? I am taking materials engineering in school right now so i could try to investigate the sensor responses/calibration of various thermistors if needed. It would be really cool if you could use the IAT sensor to account for the evaporative cooling of a methanol/water mix for the people that run that setup.
John
Old 02-14-2008, 01:55 PM   #25
jblaine
Member#: 8512
2002 WRX chassis...
stage-infinity.com
Easiest way is to search for: hydra IAT
DarthChicken did a lot of poking around at it and I think n2xlr8n did also, both of them sold their Subarus though.
Hydra random questions jblaine Other Engine Management 4 10-26-2006 11:17 AM
Hydra EMS question aznatama Other Engine Management 12 06-28-2005 01:20 PM
Hydra vacuum question :) EuroSTI Other Engine Management 1 06-18-2005 10:38 AM
Hydra/wideband question masiolli Other Engine Management 2 04-21-2005 11:05 AM
Dumb Hydra Nemesis question Pi7467mp Other Engine Management 1 11-14-2004 05:13 PM
