Old 02-14-2005, 08:33 PM   #1
veightkiller
Member#: 78967
2011 335i
Default Guys I need your help about my STi cluster
i just bought and installed my sti gauge cluster V8..i didn't cut any wire's co'z im not really sure wich wire needs to be cut..if you can show me a picture it will help alot...and my radio is not working..there's no power on it...does it mean i blow up some fuse when im installing the gauge??? the dccd in on and the rear diff. temp. is on how can i turn does one off????
i installed it on my 02 wrx wagon...
thank's in advance
veightkiller is offline   Reply With Quote
Old 02-14-2005, 08:41 PM   #2
ATX25RS
Member#: 4597
2011 Mitsu Outlander
Sport (Ex-Suby owner X3)
try posting in the electrical and lighting forum....they have a lot of info in there.
ATX25RS is offline   Reply With Quote
Old 02-14-2005, 08:42 PM   #3
veightkiller
Member#: 78967
2011 335i
thank's men....
Old 02-15-2005, 05:07 AM   #4
bingwrx
Member#: 79684
2004 Impreza WRX
Red/Blue
Remove the bulbs that light the dccd and rear diff. temp from the back of the cluster.
bingwrx is offline   Reply With Quote
Old 02-15-2005, 10:28 AM   #5
smdandb2
Member#: 70656
Old Mazda3 Hatch
Shelby Lancer #623
thank's in advance
Well, you obviously knew a wire needed to be cut in order for it to work. Why did you continue installing it? There are 1000s of threads about this topic!
smdandb2 is offline   Reply With Quote
Old 02-15-2005, 04:10 PM   #6
kunfuzion
Member#: 1094
'85 Levin Hatch
color of rust
do a search. its been covered, multiple times.
kunfuzion is offline   Reply With Quote
Old 02-15-2005, 10:57 PM   #7
veightkiller
Member#: 78967
2011 335i
thank you guys for all ur opinions..i already cut the wire on pin 28.i didn't notice the pin numbers co'z they're too small..anyways im happy with my new gauge cluster..with a shift light and red color specially the needles go back and fourth when i start my car even thou it's a lil bit expensive i'd say it's worthy "for me"
Old 02-16-2005, 01:55 AM   #8
cnk
Member#: 10757
2013 BRZ Limited 6MT
There are no bulbs on the 04+ STi clusters. They use LED's. The only way to turn the lights off is to use some electrical tape from behind to cover up the display.
Calvin
cnk is offline   Reply With Quote
Old 02-16-2005, 05:49 AM   #9
bingwrx
Member#: 79684
2004 Impreza WRX
Red/Blue
Bulbs/LED's, whatever, I just noticed that the circuit board on the back of my WRX cluster has all the fittings for an sti, just no LED's in place and a bit less soldering I guess, if you remove the LED then then that specific symbol aint gonna light up, simple.
Old 02-16-2005, 12:09 PM   #10
cnk
Member#: 10757
Have you seen the location of the LED's on a real STi gauge? There's no room to fit a soldering iron in to remove the LED. Plus, why take the risk of removing the needles and not having them line up correctly afterwards? It takes a few seconds to lift the edge and slip electrical tape under to cover the display.
The circuit boards are different. . .you would know this if you ever looked at the two gauges up close. Just use the electrical tape. . .even simpler.
Calvin
i need help whit my sti cluster 2007 to fit in the wrx 2006 subaru_west Electrical & Lighting 2 01-12-2008 04:44 AM
guys i need your help about my sti cluster veightkiller Electrical & Lighting 2 02-15-2005 01:12 AM
attn: nice guy...we need your help yuzo Hawaii Impreza Club Forum -- HIIC 9 02-02-2002 09:06 PM
Guys i need your help please read!!! Future Subaru Driver1 General Forum Archive 4 05-31-2000 07:17 AM
Guys I need your help please read!!! Future Subaru Driver1 Technical Forum Archive 1 05-30-2000 08:44 PM
