Old 02-15-2005, 11:12 AM   #1
Keith
Member#: 191
2012 J train
Brown
Default dumb question. drive shaft from 98rs works with wrx tranny/rear diff
Right?
Just wondering cuz mine is hitting the body of the car. Even after we moved it down, It still hits the body of the car.
Was wondering if there is any problem there.
should i pick up a wrx drive shaft?
Keith is offline   Reply With Quote
Old 02-15-2005, 01:29 PM   #2
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
What part of it is hitting the car? The propshaft is probably not your problem, something is sitting at the wrong height.
Old 02-15-2005, 06:26 PM   #3
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
Hmm maybe too simple but your propshaft carrier bearing isnt upside down is it?
Scoobie Steve is offline   Reply With Quote
Old 02-15-2005, 07:45 PM   #4
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Heh I was thinking that exact same thing.
Old 02-15-2005, 10:54 PM   #5
Storm
Member#: 5218
96L Most Over-
Developed Beater
Can't be. The bolts would never line up.
Jay Storm
Old 02-16-2005, 12:35 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
are you using an auto shaft on a manual transmission?
Old 02-16-2005, 01:54 PM   #7
Ds baruuuuu
Member#: 4724
01 01RS
brp
is it hitting the body or the shifter?? when i did my sway i used an 01rs driveshaft there were 2 things i had to do the carrier baring on the wrx has spacers that bring it down about 1/4" or so after i did that it was still rubbing on the shifter bushing that dolts to the floor i had to grind down the bushing on the back ofthe shifter
Ds baruuuuu is offline   Reply With Quote
Old 02-17-2005, 11:09 AM   #8
Keith
Member#: 191
2012 J train
Brown
hitting the body, you can see where it is hitting.
It just freaks me out a bit. I can feel the driveshaft spinning when I'm in 1st and 2nd...doesn't seem right
Old 02-18-2005, 02:17 AM   #9
Mumbles
Member#: 248
It's not still hitting is it?
Mumbles is offline   Reply With Quote
Old 02-18-2005, 02:24 AM   #10
Keith
Member#: 191
2012 J train
Brown
yep still is
Old 02-18-2005, 05:48 AM   #11
BANG4BOOST
Member#: 49963
420 impreza
lol! you didnt bolt in the drive shaft brackets correctly. flip the bracket around, thatll hold it up the CORRECT WAY.
BANG4BOOST is offline   Reply With Quote
Old 02-18-2005, 09:21 AM   #12
Mumbles
Member#: 248
It is the correct way. The carrier bracket has a lip, the lip has to face downward, otherwise it wouldn't mount flush to the body. I can't believe it's still hitting. How sure are you keith that it's not something else?
-B
Old 02-18-2005, 11:22 AM   #13
Keith
Member#: 191
2012 J train
Brown
pretty damn sure dude. hahaha next time I come out there I'll let you drive it.
I can feel the tranny moving man, weird. I'm wondering if I should get some Group N engine mounts/tranny mounts. Wondering if my old ass L mounts are just soft as hell?
Old 02-18-2005, 01:40 PM   #14
totoherbs
Member#: 7321
.... 122 IggPoints
Work... ahhh... so tired.
That could be part of it...
The braket was on the right way... well as close as you can get with washers and long bolts.
Old 04-25-2005, 05:31 PM   #15
Keith
Member#: 191
2012 J train
Brown
any other ideas about this one? Which drive shaft DOES NOT fit the L? (wrx tranny/rear diff is installed)
I'm thinking of just buying another wrx (05 wrx) drive shaft as I can get it pretty cheap.
Thing hits pretty hard against the body unless I REALLY slip the crap out of the clutch in first. Doesn't hit so hard in second unless i drop the clutch.
Old 04-25-2005, 06:47 PM   #16
AKGC8
Member#: 1305
2000 Impreza
I don't know what to tell you. In a 99 Impreza L, I've ran an 02 WRX tranny and 02 WRX rear diff with both an 02 WRX driveshaft, as well as a 99 L driveshaft at some point or another. All parts from 5 speeds. Didn't have any problems with either the WRX or L driveshaft. Have used both stock L mounts and STI mounts at some point or another too. There has to be something wrong besides the driveshaft.
How did you bolt the rear diff up? On the WRX, it mounts a little differently. You've got the oem rubber spacers in the propshaft carrier right? I think I remember those being a little longer on one side than the other, that could be a problem if they were flipped(not the whole carrier, just the rubber washers).
AKGC8 is offline   Reply With Quote
06 WRX Tranny/Rear DIFF/Axles/Driveshaft lagodcm Drivetrain 17 10-26-2009 12:55 PM
WTB WRX tranny, rear diff, pedals, + other misc. parts sicksubie NESIC Private Classifieds 3 12-12-2006 08:58 AM
WRX tranny/rear diff/axles/driveshaft annointed Private 'For Sale' Classifieds 23 11-27-2005 09:04 AM
WRX tranny/rear diff/axles annointed Tri-State Area Forum 18 07-21-2005 05:31 PM
WTB: WRX tranny, rear diff, rear SEDAN axles DeusExMachina Private 'Wanted' Classifieds 4 12-10-2004 10:59 AM
