Old 02-15-2005, 03:34 PM   #1
elcorazon01
Member#: 73988
Default Adding a sway
Okay so I want to add a sway bar to y sway-less L and I an not sure about all the parts I need. There was a thread that offered a little help but it basically said buy a kit. I have the sway bar from an 00 RS and I need the rest. So what is the rest...links and/or info is greatly appreciated. I am itching to do my drum to disk conversion and I figure I should add the sway bar at the same time so I don't have to have two allignments done. Thanks.
Andy
elcorazon01 is offline   Reply With Quote
Old 02-15-2005, 07:41 PM   #2
I_H8_1.8
Member#: 12733
'15 Fiesta ST
You'll need the endlinks, the body mounts, and the rear control arms from an RS that have the mounts for the endlinks, and the bushings. You can usually find endlinks used for cheap-I've got a set of Kartboy endlinks I need to sell, actually. PM if interested. I got my control arms from http://www.speedysusedparts.com/ and they sent the whole setup from the swaybar to the control arms. I may have some spare parts lying around; I'll have to check. If not, you could always go see/call your dealer and have them order the stuff for you.
I_H8_1.8 is offline   Reply With Quote
Old 02-15-2005, 07:49 PM   #3
I_H8_1.8
Member#: 12733
'15 Fiesta ST
I just checked, and I have the body mounts, stock endlinks, Kartboy endlinks, and a brand new set of bushings if you're interested. Then, you would just need the control arms and nuts and bolts.
Old 02-15-2005, 09:45 PM   #4
petawabit
Member#: 18978
96 brighton
05 AP2 ,09 GE8
what did you guys do with the evap canister in the rear? It seems to occupy a hole for my rear swaybar mount. Did you guys relocate the bracket or something?
you need:
bracket
little brass thing that attaches to bracket
endlinks
lateral link with mount or you can get a poltec hub-mounted endlink and kill two birds with one stone.
swaybar and bushings and bracket
petawabit is offline   Reply With Quote
Old 02-16-2005, 12:20 AM   #5
I_H8_1.8
Member#: 12733
'15 Fiesta ST
I didn't have that problem because my car is a '95- the evap canister is in the engine bay!
Old 02-16-2005, 12:32 PM   #6
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
befor -96 have the canister in the engine bay
if you haven't ordered these parts yet allow me to suggest somthign
buy whiteline parts instead
the sway mounts are much better
the latterallinks are also not very expensive and much much better
Adding Rear Sway Bar to oversteer confusion chaddeus Brakes, Steering & Suspension 7 06-02-2005 03:51 PM
adding a sway bar to a 95 L evorev Subaru Conversions 0 09-28-2004 01:35 AM
('93-'01) adding a sway bar stickfiguredanny Impreza Forum 7 06-18-2004 01:52 AM
Adding rear sway bar to Impreza L STinger Brakes, Steering & Suspension 5 01-12-2004 04:19 PM
Effects of adding Front Sway Bar on '02 WRX? wrx2.0 555 Brakes, Steering & Suspension 9 10-14-2003 10:13 AM
