#1 |
Member#: 56332
Vehicle:2005 STI Cobb Stg 2 |
Will I think I have found the cause why people including myself seem to burn out bulbs way before they are supposed to. As early as next day or 2 or 3 weeks after install. This usually happens with aftermarket bulbs as the OEM bulbs are more durable.
I was pulling up my driveway, lights shining on my garage, everything is fine. I finish pulling up and right before I turn off the car on, headlight is burnt out. Damnit I just replaced this Sylvania about 1 month ago. That month back when I replaced this bulb, I was working on Raammating my car. Of course stupid me had the stereo on and the battery was practically dead. Well after the first crank, my headlight bulb burnt out. Second crank, foglight bulb and side marker bulb burnt out. This along with the 2 or 3 other sylvanias that have burnt out lead to believe this conclusion. When going up a driveway, my car almost stalled, cut power to the headlights for a split second and turned them back on....burnt bulb. When cranking the car, same concept, amps drawn away from the lights while cranking, and immediately sent back to them the second I stopped...burnt bulbS. The foglight bulb and side marker bulbs were stock however. I had the OEM bulbs for about 6 months and they never burnt out this way even though I pull up the same driveway and get close to stalling it on occassion. I am pretty sure, even though I dont have the direct experience, that Sylvania will not be the only bulb to short out because of such scenario. I usually get them replaced for free but its beginning to become a pain in the arse. Burn the clutch much quicker if I rev like crazy going up the driveway?
#2 |
Member#: 63076
Vehicle:2004 Outback Sport Red! |
1. Don't start the car with any electrical load other than the starter. No lights, no AC, no blingin' ice, nada.
2. Have your charging system and your battery checked out. Your voltage may be varying way more than it should (even though you have all that other stuff turned on when trying to start the car). Autozone and Sears and other places will check it free. |
#3 |
Member#: 56332
I was thinking of getting an optima red or yellowtop. What do you think?
#4 |
Big Ron
Moderator Member#: 18062
I popped my drivers side low beam and foglight within a week of each other. I decided to remove the DRL feature in case that had something to do with it, something for you to consider too.
#5 |
Member#: 56332
Where is the plug for those located? I didnt think Michigan cars required DRL's yet again my car was from Ohio.
#6 |
Big Ron
It's hard to say, try searching. You can remove a plug behind the glove box or one near the passenger side strut tower. I did the one by the strut tower as it is far easier to get to. It's one of those pain in the ass connectors that you have to lift and pull in about 80 different directions to defeat the protections so you can pop it loose.
#7 |
Member#: 16157
South East
Vehicle:'03 Mazda P5 <>< '02 WRX & '08 MS3 SOLD!!! |
Here's where you disable the main DRL switch/plug behind the glovebox. With finesse, some have managed to unplug it without taking the glovebox out (smaller hands help). If you're one that gets easily frustrated, I would suggest taking some extra time and taking out the screws to the glovebox
#8 |
Member#: 80760
have any other pictures of the plug to unplug not so close up
#9 |
Member#: 73034
Vehicle:MY02 OBS |
that's awesome, I hate my DRLs! I am assuming this is a stupid question but, will I disable or hurt anything else by unplugging that clip?
Even better, is there a way to turn on the fogs without having to turn on the headlights? |
#10 |
Member#: 32535
Vehicle:2009 Nissan 370Z Monterey Blue |
WHy not switch brands? If you keep changing with Sylvania, maybe they are the issue. I have PIAAs in both my vehicles and they usually last about 2 years.
#11 |
Member#: 32792
NESIC
Vehicle:2003 GGA MBP 12.9 / 105+ |
the electric starter motor's coils represent a very heavy inductive load to the electrical system.
such a load will cause a voltage spike when current is interrupted. in other words, you get a very brief transient of >14v when you disconnect the starter. this can cause all sorts of havoc with tempermental loads, such as brighter than normal (read: hotter running) filament light bulbs, HID transformers and ballasts, etc etc. do what oneobs said: remove all other electrical loads while cranking. not only does this improve current reserves for the starting tasks, but it also prevents damage due to "flyback" voltage spikes. ken |
#12 | |
Member#: 78675
Vehicle:2002 white bugeye 04 kawasaki 636 |
#13 |
Member#: 63076
The picture is taken with the glove box removed. That black thing on the right is the door jamb.
#14 |
Member#: 75876
Hmmm I'm wondering are you putting finger prints all over your bulbs when you install them, you need to make abs. sure that you don't touch the bulbs are they will burn out early, something to do with the oil on your fingers, and if you do touch them you are suppose to clean them, maybe glass cleaner would work, I just never touch mine.
#15 |
Member#: 56332
Was wearing some latex gloves when did it, right out of the box so no oil film there. I try my best not to touch the bulbs but usually if I did they only last a few days. That doesnt explain the parking bulb going out too though since you can touch that all you want.
#16 |
Member#: 67127
Vehicle:3.3 I <3/h8 my GF3 1.8-2.5-2.2-2.5-2.2-3.3 |
I was gonna suggest you were touching the bulbs, but obviously that's not it. Either way, latex or not, hold the bulb by the base at all times. My fogs and sylvania's have been going strong for months now, cranking with them on, stalling a few times, etc. and I installed them without gloves or anything. Just dont touch the bulb at all.
Mabye an UD pulley would help? (unfortunately, this will make your lights dim at idle, which is also bad for them). (yes, I have one). |
#17 |
Member#: 59048
NESIC
Vehicle:2005 Black S60R w/ 18" Modas & Sport Body |
My Sylvania Silverstars last only 4-6 months. It's really starting to piss me off they only last that long. I may upgrade to Osram Silverstars and give those a try. For my foglights, I'll consider anything BUT Silverstars.
#18 | |
Member#: 67127
#19 | |
Member#: 78967
VIC
Vehicle:2011 335i Black |
#20 | |
Member#: 78967
VIC
#21 |
Member#: 31034
NESIC
Vehicle:2003 WRX Wagon WRB |
Thanks for the info on disabling the DRLs! I don't get why Subaru provides DRLs given how the headlights work ... and it bugs me that using the parking brake disables the DRLs, I know why, it still bugs me. Am likely going to get this mod done, too, although while I've replaced my both front marker lights once, and my cruise control swich light, all my other original OEM bulbs continue to work fine on my '03 after almost 3 years and 100,000 miles. Sounds like Silverstars don't last, will consider PIAAs if my stock headlight bulbs blow (they might not, y'know <G>).
Cheers, Sean |
#22 |
Member#: 89347
Vehicle:2004 wrx silver |
hey guys got Q? piaa headlights 100w and fog lights 100w will they burn wires or not and if any of you know how to change fog lights on 2004 wrx can you post it . thanx . i have silverstars in my headlights right now but not really putting out alot of light need more , no hid's for now may be later but let me know about those 100w bulbs if any of you used them.
#23 | |
Member#: 69586
International
Let me just say....Sylvania siverstars SUCK!
I had 2 silverstars burn out on me Even with my DRL disabled. My friends wrx burnt one out too. Also, my friend burnt 2 on his volvo, and my other friend burnt one on his mazda. Sylvania said its a "performance" bulb so the life expectancy is less than a regular bulb. Yeah, like a 2 MONTH lifespan! I just ordered some Narva rangepower +50 from Daniel Stern. they are cheaper than sylvania silverstars and supposedly, they are slightly better than the orsam silverstars. We'll see.... Quote:
#24 |
Member#: 59048
NESIC
You don't say? My fiance and I found out the hard way that Sylvania Silverstars have little to no life expectancy. At first, it would last anywhere from 4-6 months but my fiance is beginning to think it's more like 3 months. She's probably right.
I may have to take it up one level and get Osram Silverstars and see how those work out In regards to changing out foglights, IMO it's a PITA just because you need to get under the car, pull away the fender well cover and work with little room. Maybe someone has an easier way to do this? I have the foglight covers now and I'm gonna see how long the Osram Silverstars workout for me this coming winter. Driving without foglights in the summer/fall shouldn't be a problem. It's nice having foglights in the winter to spot them pesky pot holes |
#25 | |
Member#: 65751
NWIC
Vehicle:'10 VULVA |
Me too. hate DRLs but love the fogs. And im also curios about unplugging effecting anything else.
| Thread Tools | |
| Display Modes | |
| passenger headlight bulb keeps burning up | ineedparts | Electrical & Lighting | 9 | 12-14-2007 11:25 PM |
| 05 fog light bulbs keep burning out, Ideas? | Bbasso | Electrical & Lighting | 10 | 10-16-2006 02:36 AM |
| 04 wrx Left foglight keeps burning out?!?!? | NITROS | Electrical & Lighting | 8 | 12-13-2005 10:12 AM |
| Headlight and foglight bulbs keep blowing out!! | Blizwinter | Interior & Exterior Modification | 7 | 07-29-2004 01:26 PM |
| why do my Morettes keep burning out bulbs? | bleuquila | Electrical & Lighting | 9 | 04-07-2004 01:54 AM |
