Old 02-16-2005, 11:26 AM   #1
lotus2843
Visiting NASIOC Timeout
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Default EJ25 shortblock in 92 legacy (ej22t) OEM swap?
I bought my 92 legacy for the shortblock (ej22t) to put in my impreza, i also bought a whole ej25 (2.5RS) motor for the heads and intake to put on my ej22t, Will it be an oem swap to put the ej25 shortblock back in my 92 legacy and use the legacy top end?
lotus2843 is offline   Reply With Quote
Old 02-16-2005, 12:20 PM   #2
Jaxx
Member#: 177
The 93 Imp W/EJ20K
flat black
in certin states an abortion like that is illegal
no it won't
Old 02-16-2005, 09:49 PM   #3
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
will it work with n/a ej22 single port heads?
Old 02-16-2005, 09:58 PM   #4
Hondaslayer
the artiest
Member#: 4562
1998 Forester,lifted
95 Legacy,75 VW Westfalia
Yes,
But why take out a beautiful engine like the EJ22t and replace it with a EJ25?
Unless you are referring to a EJ257 (STi) block
Old 02-16-2005, 10:35 PM   #5
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
the ej22t block is mated with ross 9:1 forgies and eagle rods, with ej25 (rs) heads. i just dont want to throw the legacy away. and i have an ej25 (rs) block thats not doing me any good otherwise. id like to use ej22t heads because of HLA, but if i have to use single port heads and ej25 block just to get my legacy up and running again its worth it dont you think?
Old 02-16-2005, 10:38 PM   #6
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
PS: the ej22t/ej25 hybrid's powering a 94 impreza
Old 02-16-2005, 11:02 PM   #7
Hondaslayer
the artiest
Member#: 4562
Ah,
I see
Yes it will work. Use the 2.5 litre headgaskets.
PS We have done about 6 of these conversions. They are torquey little bastards!
Old 02-16-2005, 11:37 PM   #8
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
What heads can i use? ej22t (HLA) or ej22 and keep in mind this is a non turbo ej25 block i have
And you have mated ej25 blocks with ej22 heads 6 times...
Old 02-17-2005, 07:47 AM   #9
Hondaslayer
the artiest
Member#: 4562
We have always used the EJ22 heads.
And yep.
The first one had P&P'd heads,extrude honed intake,throttle body,cams,exhaust dump and nitrous. The body was nearly falling off
Another one was boosted for about 20 minutes
Use the 2.5 litre injectors from an older outback. 2 of the cars had detonation issues and those took care of it.
Old 02-17-2005, 08:58 AM   #10
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
Both are 270cc side feed injectors.....
Old 02-17-2005, 10:29 AM   #11
Diz
Member#: 874
2003 Honda S2000
2004 Mazdaspeed MX-5
Agreed. We did one of these motors and added the following:
Delta cams
JC Sports intake
Brullen replica headers
custom 2.25" cat-back
lightened flywheel
torque chip
The car is a 94 AWD L wagon (~2600lbs) and is a blast to drive. Of course, I did the drum -> disk conversion, WRX brakes up front, SS lines all around, yadda, yadda, yadda...
The car is a blast to drive on a daily basis, but is a bit unrefined. It has no AC, PW, PL, cruise or ABS.
Diz is offline   Reply With Quote
Old 02-17-2005, 11:37 AM   #12
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
My legacy is turbo, and my heads are different then non turbo ej22 heads. i plan to still boost it to 7-10 psi if the swap will work
Old 02-19-2005, 11:42 AM   #13
lotus2843
Member#: 67670
1994 Red GC8
JDM ej20/ej22t
I just picked up an eaton M90 supercharger. So i will be blowing 7psi instead off boosting from the rhb5. i suppose it will have its ups and downs
WRX td04L, headers, tmic, installed in 92 Legacy-T hotshot2109 Pre-2002 Factory Turbo Powertrain 26 03-08-2010 07:06 PM
ver 4 sti tranny swap in to my 92 legacy ss 00boostedRS Transmission (AT/MT) & Driveline 4 08-19-2009 12:20 AM
ej20 to usdm ej25 shortblock swap, need some help! xxxjuhstenxxx Subaru Conversions 1 01-21-2008 10:15 PM
EJ25 Shortblock swap RyansJDMgc8 Subaru Conversions 13 09-16-2004 06:30 PM
wrx cd player..in 92 legacy turbo? scubaracer Legacy Forum 21 11-27-2002 08:46 PM
Message Board Statistics All times are GMT -4. The time now is 04:44 PM.
