Old 02-16-2005, 05:12 PM   #1
rs-scooby
Member#: 11071
2015 FXT
Dark Gray Metallic
Default What aftermarket Wrx Intercoolers fit in a GC8
Basically looking to see what others have done that have a wrx engine swap in an older 2.5rs gc8. Which ones fit, which ones need modifications and which ones plain suck
I did a search as well but its hard to find the proper way to word it for good results.
Any help is grealty appreciated.
RYan
rs-scooby is offline   Reply With Quote
Old 02-16-2005, 09:03 PM   #2
Scoobie Steve
Member#: 2289
1998 [email protected]
Subaru L Ver 6 STi Type R
TMIC or FMIC??
Scoobie Steve is offline   Reply With Quote
Old 02-16-2005, 09:15 PM   #3
rs-scooby
Member#: 11071
2015 FXT
Dark Gray Metallic
oops forgot to say it was for a tmic
thanks
Old 02-17-2005, 10:33 AM   #4
HeMan1320
Member#: 26067
2003 WRX
Open Sourced
I know the Ver8 TMIC fits...
HeMan1320 is offline   Reply With Quote
Old 02-17-2005, 11:51 AM   #5
rs-scooby
Member#: 11071
2015 FXT
Dark Gray Metallic
usdm or jdm ver8? I was reading that the usdm one doesnt fit quite right
Ryan
Old 02-17-2005, 01:55 PM   #6
Zephyr
Member#: 3362
2001 I've wired a
Few cars in my day
JDM V7 fits right on. USDM you'll need all of the brackets for the intercooler.
Z
Zephyr is offline   Reply With Quote
Old 02-17-2005, 02:06 PM   #7
Homemade WRX
Member#: 33782
96 bastard child
search FIRST, then PM!!!
I was going to be getting a PWR for a really cheap price and I would have found out, but it sold...so good luck on the search...I'm really interested in what will fit too
Old 02-17-2005, 02:47 PM   #8
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
my jdm ver8 tmic well be for sale soon when i find a fmic
ImprezaRSfan! is offline   Reply With Quote
Old 02-18-2005, 07:29 AM   #9
2000wrx
Member#: 66659
2000 L WRX'd
The V7 is nice, large and cheapish. I think that the MRT is one of the largest that will fit a GC
2000wrx is offline   Reply With Quote
Old 02-18-2005, 08:21 AM   #10
DuoMaxwell
Member#: 24565
2000 V6 STi RA #856
Nothing from 96 and up will go with the EJ20G trust me there are some items in the way!!
DuoMaxwell is offline   Reply With Quote
Old 02-18-2005, 10:10 AM   #11
IllNastyImpreza
Member#: 36333
98 2.5RS
tuning student...
just get a wrx IC and shave off half an inch, works mint.
IllNastyImpreza is offline   Reply With Quote
Old 02-18-2005, 10:40 AM   #12
Jon Bogert
Member#: 1133
09 GTR, 02 996 C4S
95 993 C4, 71 911, 04 STI
Or you could use an intercooler designed specifically for the 2.5RS. I just happen to know of one for sale...
http://www.rs25.com/forums/showthread.php?t=13594
Jon Bogert is offline   Reply With Quote
Old 02-18-2005, 12:52 PM   #13
dmross
Member#: 2818
2000 2.5RS
I have seen the APS TMIC unit fitted to a WRX swap, but it did NOT fit in my STI 6 swap. What I am getting to is that you should be careful when someone says "it fits" because it may be dependent on your swap.
dmross is offline   Reply With Quote
Old 02-18-2005, 01:00 PM   #14
Matt Monson
Member#: 832
99 2.5RS, '85 911
'73 914 and 2012 BRZ
Well,
What swap do you have in your car? What fits will be directly related to what generation EJ20 you are using...
Old 02-18-2005, 06:59 PM   #15
luvmyrs
Member#: 1048
2000 Nothing, thanks
to POS thieves.
Depends on a few factors.
1. which x-member you will use with your swap. IE Turbo Legacy or GD A/B
The Turbo Legacy will lower the engine about 1 inch lower in the engine bay.
That way you can use a TXS TMIC or most large aftermarket ones.
2. Any JDM ver 7/8 will fit under the hood.
3. To use the USDM STI's you need to modify the mounting brackets.
my 2cents
Frank
luvmyrs is offline   Reply With Quote
Old 02-18-2005, 08:07 PM   #16
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
how do u know? are u just posting off what u read someone else type or are u sure?
Old 02-18-2005, 10:13 PM   #17
luvmyrs
Member#: 1048
to POS thieves.
a little history about my car
98 impreza rs
its had a usdm ej205 with a GDA ver7 spec-c front x-member
now it has a full ver7 sti drivetrain swap.
point is ive been through this a few times
I have other friends in the area that have ej20 swaps in theyre RS's and theyre engines sit significantly lower then mine.
*EDIT*
Ive had the same TXS TMIC on both of the engines.
Frank
Old 02-20-2005, 09:44 PM   #18
garface
Member#: 1581
MY00 RS/STi7
MY01 RS Both Silverthorne
Hey Frank, my question is... If the xmember raises the engine an inch, then the tranny will be raised up in the front since it connects solidly to the engine. Wouldn't this affect the tranny mounts and the shifter linkage? Wouldn't it prevent the 6 speed from fitting in a gc entirely since it's so tight to begin with? Just a few q's,
garface is offline   Reply With Quote
Old 02-21-2005, 12:06 AM   #19
luvmyrs
Member#: 1048
to POS thieves.
ok perhaps an inch was too much for me to say.
But the point is. My roommate has a ej20'd GC8 with a turbo leg x-member. his engine seems alot lower then mine.
Old 02-21-2005, 12:13 AM   #20
Scoobie Steve
Member#: 2289
Seems????? I think we need measurement before yet another rumor gets started here. Some people still swear the GC tunnel needs to be bashed to fit a 6 spd
Old 02-21-2005, 01:31 AM   #21
Boxologist
Member#: 21118
yeah, u can't trust those low numbers!!
good point about the Xmember dropping the engine. i knopw VSigma told me last year that i would have to e carful searching tmic's cause i was looking at MRT ptoducts, and certain ones would hit the hood on an old school body as opposed to a GD.
i'd luv to fit a Hyperflow TMIC but am prepared to accept a v7.
Boxologist is offline   Reply With Quote
Old 02-21-2005, 10:24 AM   #22
luvmyrs
Member#: 1048
to POS thieves.
If anyone has web hosting, I can show you guys pics of my Ver 7 engine/6spd and TXS TMIC pics.
Old 02-21-2005, 10:40 AM   #23
luvmyrs
Member#: 1048
to POS thieves.
some food for thought... could there be a difference in height from on set of motor mounts to another set?
Old 02-21-2005, 11:44 AM   #24
Charge
Member#: 3313
The various engine swaps can make the height appear different. The intake manifolds were different on some, correct? So that could adjust where the intercooler sits, in relation to the firewall. It would also affect height, to a degree...possibly making one swap appear to be a different height than another.
To determine it was the crossmember, we'd need to know the car, the crossmember, the specific engine swap(total, block, heads, intake manifold, etc...) and the intercooler used(and if it was modified).
Charge is offline   Reply With Quote
Old 02-21-2005, 02:09 PM   #25
Kotir
Member#: 17300
1993 Widebody Wagon
748whp e98
The intake manifold on my Version 8 swap nearly hits the hood when it's closed (via looking inside when I didn't have the headlights/grill on)
I'm using a JDM new age crossmember
Kotir is offline   Reply With Quote
will WRX/ STi seat fit in my GC8 ImprezaZRoss11 North West Impreza Club Forum -- NWIC 11 04-01-2008 02:58 PM
will a txs, helix, or perrin tmic fit in a gc8 engine bay with wrx swap? legacy2003 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 12 12-08-2005 10:24 PM
What manifolds will wrx injectors fit in, AND fit an '01 2.5 motor??? Subasaurus Rex Normally Aspirated with bolt-on Forced Induction Powertrain 6 10-31-2003 01:14 PM
Will a WRX Intercooler fit in an RS? SubaFast1 Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 06-24-2001 04:09 PM
What aftermarket rims will fit our car?? raptor Brakes, Steering & Suspension 8 03-13-2001 11:14 PM
