Old 02-16-2005, 06:45 PM   #1
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Default I need to drain all power steering fluid. How?
The manual is mute on how to drain all the fluid, but it does mention doing it a couple of times. How can I get all the fluid out?
After my engine swap in which I had the lines off and the re-connected, I (stupidly) filled it with Valvoline synthetic power steering fluid. After start up, I got a shudder through the wheel when turning while stopped or at low speeds. Well, after a quick look at the manual, I saw Subaru specs Dexron III. I drained the resevoir and filled with Amsoil synth Dexron III, but the problem is still there. It seems most of the fluid is in the lines and rack, not the resevoir.
fragment is offline   Reply With Quote
Old 02-16-2005, 07:39 PM   #2
Unabomber
👌 Big Ron 👌
Member#: 18062
on car parts so PM
me b4 j00 buy
http://www.scoobymods.com/forums/att...achmentid=2131 Right click and save as, or it won't work.
Most people use a turkey baster to suck the fluid out of the reservoir.
Old 02-16-2005, 08:49 PM   #3
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Thanks, but I have that in my manual. Under the specs its says that the resevoir holds .3l out of a .7l capacity, so I need to get it all out, not just the bit in the tank. Think of it this way; my power steering needs an enema, I just need to know where to put the nozzle
Old 02-16-2005, 09:14 PM   #4
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Take off the return line (not the one that goes to the pump) and start the car. Run it until no more fluid comes out and shut it down. After you refill, start the car and turn the steering wheel lock-to-lock a couple times to get all the air out of the rack.
OneOBS is offline   Reply With Quote
Old 02-17-2005, 09:42 AM   #5
dsc
Member#: 15559
Originally Posted by OneOBS
Take off the return line (not the one that goes to the pump)...
I'm not sure what you mean. Both lines go to the pump, don't they? Do you mean to take the line that returns fluid to the pump and disconnect that line where it attaches to the rack?
dsc is offline   Reply With Quote
Old 02-17-2005, 10:31 AM   #6
OneOBS
Member#: 63076
2004 Outback Sport
Red!
One line from the reservoir feeds the pump. The other is the return from the steering rack. Drain the reservoir, disconnect the line that goes to the steering rack and stick it in a bucket. Almost all the fluid will get pumped out.
Old 02-17-2005, 12:47 PM   #7
fragment
Member#: 8050
2004 FXTi - Stage 2
Goooooooolld
Now that's a description I can work with! Thx
Old 02-26-2005, 09:06 PM   #8
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
The pump relies on the ATF for lubrication. Once all the fluid's out and your engine's still turning the pump, mightn't you do damage to the pump's bearings?
Could you remove the belt and turn the pump by hand instead, so as to put less load on the bearings?
vrg3 is offline   Reply With Quote
Old 02-26-2005, 10:10 PM   #9
Merdock777
Member#: 21256
2002 Impreza 2.5RS
BlindYoAssPlatinumSilver
What if he has a manual and has no ATF. I think engine oil for the pump would be more apropriate, unless it uses none. just pointing that first part out, I don't know how the pump works.
Merdock777 is offline   Reply With Quote
Old 02-26-2005, 10:21 PM   #10
munkis
Member#: 1847
Team Broken: V6 GF
rallyarmor.com
Take off a line from the rack (one that comes from the pump or the return), one that is easy to get to, im not sure if they are easy to get too though if they are, put the front end up in the air and then WITH THE CAR OFF turn the wheel back and forth till you pump all the fluid out, that will get the job done the fastest, easiest and safest way
Do not run the car with the pump dry or you will damage it.
Jay
Old 02-27-2005, 10:41 AM   #11
vrg3
Member#: 25796
1993 Legacy Turbo
Burgundy
Merdock777 - The power steering system uses ATF. ATF is a hydraulic fluid.
Old 02-27-2005, 12:53 PM   #12
OneOBS
Member#: 63076
2004 Outback Sport
Red!
Yes, use a little common sense and turn off the car.
Old 02-27-2005, 03:39 PM   #13
Hayes
Member#: 11808
Just use the turkey baster 3X times and you have 95% new PS fluid. Just drive a few milles between each time. I like the baster method because I don't like undoing any oil lines unless absolutly necessary because of the potential for leaks. I ALWAYS follow the manual so when it says ATF I use ATF. ed
Hayes is offline   Reply With Quote
How to flush power steering fluid?? veightkiller Service & Maintenance 28 10-17-2015 02:46 PM
is it necessary to flush the power steering fluid? Gel Mibson Newbies & FAQs 0 08-08-2009 08:25 PM
how to remove power steering fluid/coolant stains from my driveway/garage legacy2003 Interior & Exterior Modification 7 07-14-2005 01:46 AM
How to flush power steering fluid WRXwannbe Service & Maintenance 2 05-01-2003 09:06 PM
Draining and Refilling Power Steer Fluid 98kPa Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 1 08-06-2002 01:34 PM
