Welcome to the North American Subaru Impreza Owners Club Sunday July 5, 2015
Old 07-16-2001, 12:42 PM   #1
Marinator
Member#: 7644
1993 Impreza L
Default 93 Impreza trouble codes
I know it has been covered, but I can not find my wires to connect to get the ECU to display trouble codes. Could anyone with a '93 Impreza 1.8 AWD help me out?
Thanks
Marinator is offline   Reply With Quote
Old 07-16-2001, 12:48 PM   #2
Max Umbarger
Member#: 1112
2006 FXT
RBP
I have the same year Impreza. Under the dash board, you can see the steel pipe that the steering wheel shaft runs through. Right in that area there is 2 green connectors, and 2 black connectors. Connecting them together will run the codes. If I am correct, the car only need to be on, but no ignition.
Max
Max Umbarger is offline   Reply With Quote
Old 04-15-2006, 11:02 PM   #3
anothermbdusted
Member#: 110218
1993 imp L awd wgn
aqua frost
i know this is old but i want to say thanks max
anothermbdusted is offline   Reply With Quote
2008 Impreza Built In Trouble Code Reader Jon [in CT] Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 2 05-17-2013 11:14 AM
93 AT impreza TCU CODE Shiro_Ki Transmission (AT/MT) & Driveline 1 02-28-2009 02:33 PM
TCM trouble code on 05 impreza metalsman Transmission (AT/MT) & Driveline 0 03-24-2006 01:12 PM
If you have the Peper scan tool, here's an Impreza trouble code file Jon [in CT] Service & Maintenance 0 01-30-2002 06:32 PM
Trouble code description? Greg555 General Forum Archive 3 02-21-2001 12:03 AM
