Old 02-18-2005, 01:31 PM   #1
solarakid
Member#: 49671
03 WRX PSM
Stage 2
Default noise when turning left
when i am turning left at a slow speed (ie pulling into and out of parking spots) i get this sound. not grinding but more of a low pitch kind of creak. any thoughts? cv joint? any help you guys can give would be great?
solarakid is offline   Reply With Quote
Old 02-18-2005, 03:49 PM   #2
footracer
Member#: 62479
2002 Wrex Wagon
Red
CV Joint. My old legacy made that noise... i ignored it for a while and tried to push my luck. The axle sheared off and shredded the front left tire in my parking lot. Get 'er fixed. Instead of just a new cv joint... tire, axle, cvjoint
footracer is offline   Reply With Quote
Old 02-18-2005, 04:04 PM   #3
solarakid
Member#: 49671
03 WRX PSM
Stage 2
damnit. thanks for the help.
Old 02-19-2005, 01:07 PM   #4
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
You have a fairly new WRX, though; it shouldn't be blowing a CV joint already. Have the dealer look at it; it might be nothing but if it really is a CV joint it should be covered under warranty.
Mike Wevrick is offline   Reply With Quote
Old 02-19-2005, 07:27 PM   #5
solarakid
Member#: 49671
03 WRX PSM
Stage 2
the only thing is i have bigger sway bars, drop links, and an antilift kit so im a little worried that they wont cover it. the car only has 14,xxx on it so i would hope im not blowing things already.
Old 02-19-2005, 08:37 PM   #6
AlboWRX
Member#: 37719
2003 WRX
Well, I`ve noticed some noises on some new paved parking lots and I dont know if thats what you are experiencing but worth a shot. And it happened with all the cars that pulled in and out,including mine. Have you had this noise appear when you take corners on the street at low speed?
AlboWRX is offline   Reply With Quote
Old 02-19-2005, 10:31 PM   #7
solarakid
Member#: 49671
03 WRX PSM
Stage 2
no not at all on regular cornering or turns at low speed. maybe it it the lot. never thought of that.
Old 02-20-2005, 10:34 AM   #8
AlboWRX
Member#: 37719
2003 WRX
Case CLOSED.
Weird Noise When Turning Left or Right Sleepy60 North West Impreza Club Forum -- NWIC 10 05-04-2009 03:34 AM
Grinding noise when turning left ralliharri Brakes, Steering & Suspension 3 02-10-2007 12:28 AM
Grinding noise when turning left? redhouse Service & Maintenance 2 11-14-2005 08:35 AM
grinding noise when turning left TmR197 Transmission (AT/MT) & Driveline 3 01-21-2005 10:23 AM
