Old 02-18-2005, 01:55 PM   #1
sid_vicious
Member#: 57342
1997 Outback
Default Heating/AC control illumination?
Hi,
Here's a miscellaneous question I couldn't find an answer to in my owner's manual or Haynes service manual...
I have a 97 Legacy Outback, and at some point, the lighting in the controls for heating and air conditioning (vent position, temp., fan power etc.) went out. I ignored it, as I haven't had much time to mess with it, and then it came back on very dimly for a while and again went out. Any idea of how to fix this? I couldn't find any info. about fuses, relays etc. that might associated with these lights.
By the way...anyone know off-hand what the best diameter tubing would be to put over the brake bleeder valve for changing brake fluid?
Thanks,
Andrew
sid_vicious is offline   Reply With Quote
Old 02-18-2005, 04:30 PM   #2
North Ursalia
Miss You Mom
Oct 1940 - Feb 2008
Super Moderator
Member#: 809
2000 2.5 RS, '14 For
92 5MT SVX
Pull the dash apart and replace the bulbs- they're a common item to blow out.
Brian
Old 02-19-2005, 10:05 AM   #3
Mike Wevrick
RIP 1/19/64 - 7/23/11
Member#: 24654
1957 Taggart Comet
atlasshruggedpart1.com
Why would all of the bulbs blow at once? (My 95 Legacy has the same problem.)
Mike Wevrick is offline   Reply With Quote
Old 02-19-2005, 11:24 AM   #4
Jon [in CT]
Member#: 2992
02 WRX Sedan
Here's one method:
http://www.scoobymods.com/forums/sho...hp?threadid=91
And here's an alternative method that avoids disconnecting the heater cable:
http://www.randomsoup.com/subie/how_acpanelbulbs.html
Jon [in CT] is offline   Reply With Quote
anyone replace factory climate/ac controls with wrx controls? littlebhatia Normally Aspirated Powertrain 1 11-13-2009 07:44 PM
Pic Request: Boost gauge mounted in drivers heat/ac vent i50caL Member's Car Gallery 3 10-19-2006 04:14 PM
WTB: RS drivers side heat/ac vent and rs side skirts, any color imprzya Mid West Subaru Owners Club Forum -- MWSOC 3 07-15-2005 10:15 PM
Any heating/ac guys out there? Midwayman Off-Topic 30 07-01-2005 05:34 PM
Heat/AC experts need help. bluers Off-Topic 6 06-06-2005 01:18 PM
