Old 02-18-2005, 06:28 PM   #1
attitude
Member#: 52043
04 sti
Default anyone who has installed an avc-r on an 04 sti
please help me with the wiring diagram. i've been trying for two days now. apexi doesn't even know how to do it.
attitude is offline   Reply With Quote
Old 02-18-2005, 09:09 PM   #2
2phless
Member#: 69343
1998 TransAm cnvrtbl
What do you need to know? It's dark and freezing out now, so I can't go out and check but you need the tach wire and speed sense wire right? I can get wire colors and pin counts tomorrow morning if work isn't too crazy.
2phless is offline   Reply With Quote
Old 02-18-2005, 09:16 PM   #3
attitude
Member#: 52043
04 sti
id really appreciate it. there's the tach, ignition, 2 grounds, basically all the wires from the avc-r. and where they go, (the plug, wire number, color, any of the former, or all, i get nervous when i'm working with wires, gotta get it right)
Old 02-18-2005, 09:36 PM   #4
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
if i can find the book, i'll scan it for ya. you defenatly need it to install it. apex'i wouldn't send you one? like 98% of tuning companies , it depends on who you get on the phone unfortunatly
vtecTHIS is offline   Reply With Quote
Old 02-18-2005, 09:39 PM   #5
attitude
Member#: 52043
04 sti
my book doesn't have it for the ej257. they even said they dont know how to do it, because they never had installed one on an STi. im stressed the hell out.
Old 02-18-2005, 09:51 PM   #6
the_owl
Member#: 64787
just got worse
I got a guide for my wiring for the avcr online
05' STi
tapped it at the harness where the UTEC goes
avcr diagram
Ill leave it up till tomorrow
the_owl is offline   Reply With Quote
Old 02-18-2005, 10:02 PM   #7
attitude
Member#: 52043
04 sti
and its the same for the 04 sti? i thought that they were different than the wrx... i guess i was led in the wrong direction. thank you very much, if this is the right thing
Old 02-18-2005, 10:05 PM   #8
attitude
Member#: 52043
04 sti
my ecu only has four plugs...this cant be right.
Old 02-18-2005, 10:05 PM   #9
the_owl
Member#: 64787
just got worse
Ive had mine running since Dec 2004, I wired exactly like that.
If its wrong, thats ok cuz it works.
j/k its the same harness.
Old 02-18-2005, 10:05 PM   #10
the_owl
Member#: 64787
just got worse
scroll down to the 02+ wrx.
Old 02-18-2005, 10:06 PM   #11
attitude
Member#: 52043
04 sti
that has five plugs
Old 02-18-2005, 10:09 PM   #12
the_owl
Member#: 64787
just got worse
heres a different one I downloaded.
use the same link above
Old 02-18-2005, 10:11 PM   #13
the_owl
Member#: 64787
just got worse
or try this:
04_STi_ECU.zip
Old 02-18-2005, 10:15 PM   #14
attitude
Member#: 52043
04 sti
i guess i can figure it out from there...thanks for taking the time to help me out, hope i find the right stuff to hook up.
Old 02-18-2005, 10:16 PM   #15
the_owl
Member#: 64787
just got worse
the last one I posted is all you should need. 04_STi_ECU.zip. I have so many PDF docs for the sti, its hard to sort.
Old 02-18-2005, 10:18 PM   #16
attitude
Member#: 52043
04 sti
yeah, i will figure out tach, speed, ground, throttle, and power from that i hope...
Old 02-18-2005, 10:24 PM   #17
attitude
Member#: 52043
04 sti
i didn't see a tach, do you use crank position? or engine speed output?
also, on the throttle position, do you use the accelerator "main" "power supply" or "sub"
and which one for speed signal?
im so friggin lost with electronics...
Old 02-18-2005, 10:44 PM   #18
attitude
Member#: 52043
04 sti
sorry i'm a pain in the ass
Old 02-19-2005, 12:34 AM   #19
2phless
Member#: 69343
You can use tach, or tap a negative pulse for any injector. I didn't check owl's links since I don't think I'd remember anything well enough to verify them. The 04 Sti has 4 plugs in the ECU and all of those taps can be found there. The throttle position can also be tapped at the throttle body under the hood, white wire at the top of the plug. I don't think that input is used except for the 'bling' gauges on the AVC-R. Speed and RPM are used, and used well.
If you are confused about how to ground the unit though, I suggest you find someone to install it for you. And in finding that person, I suggest you do some serious research around your area, as there will be a ton of people who say they can do it, and just a small handfull who can do it right.
If you want to cruise down to the middle of NC. I'd install it for you.
Old 02-19-2005, 01:37 AM   #20
the_owl
Member#: 64787
just got worse
engine speed output=rpm
Every wire u need can be grabbed from the molexs in the diagram.
I used the main power supply for mine. I grounded to the wire in the diagram.
Old 02-19-2005, 08:33 AM   #21
attitude
Member#: 52043
04 sti
thanks a lot guys, and i would come to nc, but since my engine is out of my car, it would be a long trip. i should be dropping it in soon though.
Old 02-19-2005, 10:15 AM   #22
x99percent
Member#: 27108
2004 STi
2004 A4
My AVC-R doesn't try to make boost (doesn't utilize the solenoid) until I'm >= 40% TPS. That takes care of *most* PTFB issues.
x99percent is offline   Reply With Quote
Old 02-19-2005, 11:28 AM   #23
2phless
Member#: 69343
x99, how do you go about the settings to get that response. I get PT (but not quite FB) and would like to reduce it. I didn't see (or I didn't comprehend) any settings that involve the TP input. I have it all dialed by gear and RPM, but would like to get control based on TP as well.
Old 02-19-2005, 02:31 PM   #24
vtecTHIS
Member#: 48048
. Nasioc, serious
Bidnazz
i just used the auto learn function. it's worked great for me. and yeah the wiring harness is alot different for sti's and wrx. i was gonna send you the book and the sti wiring harness, looks like you got it though
Old 02-19-2005, 04:33 PM   #25
attitude
Member#: 52043
04 sti
thanks, i'll probably pm a few of you for help anyways.
Has anyone ran Koni's with d-rex extenders on a 04 sti with wrx donors? wantsti Brakes, Steering & Suspension 5 05-25-2009 03:21 PM
Anyone who has installed the Hypersingle... gpatmac Transmission (AT/MT) & Driveline 1 06-13-2005 02:32 AM
For anyone who has installed a Turbo Timer with Subaru Security System... netZ Car Audio, Video & Security 5 02-18-2002 05:34 PM
Help, anyone who has installed a flywheel in their WRX uuarex Transmission (AT/MT) & Driveline 7 10-29-2001 12:57 PM
to anyone who has installed a version 5 wing bttune2.5rs Interior & Exterior Modification 7 01-26-2001 12:05 AM
