Old 02-18-2005, 09:21 PM   #1
criz
Member#: 56497
2008 WRX STi
Default where does the AP's boost display max out?
Hey guys... i have my sti running the stage 2 base, with the HWG real time map and when i'm in 4th, 5th (didnt try 6th) I hit 18.3 psi... to me that is weird how 4th and 5th both peak at the same boost point, so i'm just wondering if the AP's boost display maxes out there, or that my boost really is reading correctly.
can anyone shed any light on this?
side note: I just swapped out my stealthback with the cobb tbe, and absolutly love it... cobb's tbe is tip top
criz is offline   Reply With Quote
Old 02-18-2005, 10:06 PM   #2
criz
Member#: 56497
2008 WRX STi
any ideas?
Old 02-18-2005, 11:05 PM   #3
criz
Member#: 56497
2008 WRX STi
bump
trying to figure this out tonite, so i can properly tune this...
Old 02-18-2005, 11:22 PM   #4
fasterthanrayswrx
Member#: 48672
2005 Subaru
WRX
sorry....I don't know the answer...but darn 18.3. Im running txs steathback with stage 2 and see 17ish max.
free bump
fasterthanrayswrx is offline   Reply With Quote
Old 02-18-2005, 11:23 PM   #5
Skeete
Member#: 52569
2004 STi
ill try to see what my ap say tomorrow, cause my defi reads 18.75 psi max at stage 2 regular map, but i havent tried to see what the ap reads.
Skeete is offline   Reply With Quote
Old 02-19-2005, 02:11 PM   #6
Skeete
Member#: 52569
2004 STi
i just got back from testing that, and even though my gauge reads 18.75 psi, the ap only reads 18.3 psi, in both 4th&5th wot, so 18.3 is probably the highest it reads.
Old 02-19-2005, 04:27 PM   #7
monopoly
Member#: 76016
2014 Ariel Atom 3S
Custom Bumble Bee
Sounds like your gauge is off that little amount and the AP is holding you to 18.3 which is normal on a STi.
monopoly is offline   Reply With Quote
Old 02-19-2005, 05:45 PM   #8
Skeete
Member#: 52569
2004 STi
the ap climed extremly fast to 18.3 psi and suddenly stopped and would hold for second or two,(seeming like it hit a limit) while my gauge was at 18.75 psi; before boost started to taper to 18 psi, which showed on both my gauge and ap. so to me it does seem like the ap's readout is maxed at 18.3 psi.
Old 02-19-2005, 07:10 PM   #9
criz
Member#: 56497
2008 WRX STi
damn, thanks guys
man, that's ghetto! why would it max out at that boost level? i'm going to see if I can contact Cobb about this
Old 02-19-2005, 07:54 PM   #10
hondaeater69
Member#: 60324
I highly doubt the psi display is capped at any reading. If it is, it's probably at 99.99. Sounds like a descrepency between the two gauges, that's all.
Old 02-19-2005, 08:31 PM   #11
Skeete
Member#: 52569
2004 STi
it makes sense and is what i would have thought, but it really seemed like the ap maxed out. so far two of us have experienced it, and maybe someone eles can give it a try.
Old 02-20-2005, 05:21 PM   #12
criz
Member#: 56497
2008 WRX STi
yea, my scanmaster 3 reads that i'm peaking at 20psi... and the AP keeps reading at 18.3 and nothing more...
hmmmmmmmm
Old 02-20-2005, 05:36 PM   #13
hondaeater69
Member#: 60324
hmmm, is right. i hit 20 lbs easy in fourth, i'll try it in the next few days.
Old 02-20-2005, 05:38 PM   #14
03WRX83
Member#: 30246
0394 WRX/Supra
WRB/White
18.3 is the max. i noticed that also. sux..
03WRX83 is offline   Reply With Quote
Old 02-20-2005, 07:42 PM   #15
Jaxx
Member#: 177
The 93 W/EJ20K
Series 10 FRS
the sensor maxs out at 2.5 bar so .....
Old 02-20-2005, 08:17 PM   #16
hondaeater69
Member#: 60324
weird, because the scan master and AP read off the same stock sensor in the manifold. I think you're right, it is capped. I hope that's changed for the ST version/datalogging. I'll have to call cobb bout this. I ran my car tonight, i think the highest I seen was 18.3 too, but I'm not 100%, it was a short road and there just too many god damn things to monitor in my car any more.
EGT, RPM, AFR, SPEED, Radar, and two boost gauges. . .I really need that ST for datalogging. . .before I kill someone.
Old 02-20-2005, 10:15 PM   #17
criz
Member#: 56497
2008 WRX STi
what's up with that cobb? and its funny how we all just noticed it now huh?
Old 02-20-2005, 10:21 PM   #18
hondaeater69
Member#: 60324
well i never use the ap to monitor boost levels, it's too bulky. . .it is weird though. I"ll call'em monday.
Old 02-21-2005, 12:19 AM   #19
PDXTuning
Member#: 49831
2008 Get Tuned Now
Knowledge is Power
I suspect the Cobb and I know the Deltadash (and the Scanmaster from what I hear) use the SSM protocol, which allows you to see both absolute and relative boost pressure.
Due to a limitation in the protocol, the Relative Pressure value can't go over 18.3psi (actually, it is 18.4 by the DD program). If you instead read the absolute pressure, and subtract the current atmo pressure, you can read up to 1.55 bar (22.4psi). The sensor itself becomes very non linear above 22psi, so I would not use it for anything above that.
So, your AP is reading as expected for the relative values. I suppose Cobb could change it to read the absolulte if needed. The deltadash can read both, and I always log the absolulte.
Cheers,
Jeff Sponaugle
PDXTuning.com
PDXTuning is offline   Reply With Quote
Old 02-21-2005, 07:20 AM   #20
criz
Member#: 56497
2008 WRX STi
awesome, thanks for the great insight PDX
Old 02-21-2005, 04:40 PM   #21
hondaeater69
Member#: 60324
Just called Cobb to verify and that's exactly what it is jeff, thanks for the input. The ST will have the option to read the full sensor, up to 2.5 bars
Old 02-21-2005, 04:42 PM   #22
criz
Member#: 56497
2008 WRX STi
can't wait to get the ST
Installing mechanical boost gauge. Where does the little restrictor pill go? lennyTR Factory 2.5L Turbo Powertrain (EJ Series Factory 2.5L Turbo) 7 09-05-2008 07:54 PM
Does cobb ap2 boost reading max at 18.4lbs? STI_SLC AccessPort 22 01-07-2007 11:47 PM
Where does the Coolant come out? metoo Texas Impreza Club Forum -- TXIC 19 10-05-2005 09:22 AM
Where does the boost go? MOG_22 Bay Area Impreza Club Forum -- BAIC 1 12-23-2002 07:08 PM
Stock boost controller & bypass valve... where does the boost go Fubaru Factory 2.0L Turbo Powertrain (EJ Series Factory 2.0L Turbo) 4 12-19-2001 11:11 PM
