Old 02-19-2005, 01:34 AM   #1
SoobyStu
Member#: 81045
Default Just got my ver7 motor running and problems
Well today i thought was gonna be a happy one as i thought my car was ready to take out but i have come into some problems. I have put in a ver7 sti engine into my 03 wrx and i'm having the following problems.
My boost gauge is not showing any vacum or boost.
Car is idleing bad between 1750 2000 up and down
When the car hits boost around 3500-4000 it splutters and hesitates.
Overall my car is acting like its very sick
Please someone help
SoobyStu is offline   Reply With Quote
Old 02-19-2005, 02:25 AM   #2
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
is there a check engine light on? and if so have u pulled the code to find out what it is? Check for a boost leak, i drove for a month cussing and swearing trying to figure out why i couldnt boost more than 10psi. I checked all my hoses everywhere and they were good. It ended up being my metal intercooler splitter punctured one of the rails on the TMIC and i was leaking air through the intercooler .
so check those and post back
ImprezaRSfan! is offline   Reply With Quote
Old 02-19-2005, 02:38 AM   #3
SoobyStu
Member#: 81045
Yes i do have a check engine light but i need to get an OBD scanner tomorrow. Also what is the hose that runs to the inner passenger fender wall? its next to the hose that goes to the turbo. I have'nt figured out where it goes maybe on the inlet pipe?
Old 02-19-2005, 11:32 AM   #4
ImprezaRSfan!
Member#: 13520
99rs ej207 spec-c
its for sale
take a picture
Old 02-19-2005, 01:54 PM   #5
SoobyStu
Member#: 81045
OK here are the pictures one there is a hose not connected near the turbo inlet and the other is next to the fuel line hose
http://img.photobucket.com/albums/v6...holds/pic1.jpg
http://img.photobucket.com/albums/v6...holds/pic2.jpg
Old 02-19-2005, 03:07 PM   #6
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
hmmm, i cant see what ur talking about, but make sure all of ur vacume lines are conested properly, and just double and tripple check your work. the simplist mistake will make ur car act up, or not run at all. i put the fuel lines on backwards and the car wouldnt start, i was about the pull the einge again thinking it was a bigger problem then it was.
snowman4us is offline   Reply With Quote
Old 02-19-2005, 04:28 PM   #7
SoobyStu
Member#: 81045
anyone can tell me what these hoses are and where they go?
Old 02-19-2005, 04:31 PM   #8
SoobyStu
Member#: 81045
just got the cel codes PO365 and PO390
I checked this code out and it says camshaft postion sensor "B" cicuit (bank 1)
Old 02-19-2005, 05:30 PM   #9
SoobyStu
Member#: 81045
For the love of god heeellllllllpppppppp
Old 02-19-2005, 06:58 PM   #10
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
The one laying on the turbo inlet is the return from the boost solenoid. It goes back into the turbo inlet at the very front of it, where you have that breather hose running. If you have it plugged because of another boost controller, then look elsewhere. I don't know where that other ones going or what it's for.
Those codes are because the AVCS system is not hooked up.
Old 02-19-2005, 07:41 PM   #11
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
make sure ur cam angle sensors are hooked up...on the USDM WRX its on the driver side hear. intake cam.
Old 02-19-2005, 08:50 PM   #12
SoobyStu
Member#: 81045
K i realized why it was running sooo bad, i had 91 octane and it was detecting a knock, so it wouldn't let me go over 45000.
What is the main funtion for the boost solenoid?
Old 02-19-2005, 10:21 PM   #13
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Sorry, but that probably wouldn't cause it to run bad.
The boost solenoid is what regulates your boost...good luck.
Old 02-20-2005, 01:06 AM   #14
SoobyStu
Member#: 81045
Al;right then just installed the AVCS and that got rid of the CEL's. But its still stopping me from going over 4500 revs???????
I haven't benn able to connect my speedo to the JDM tranny because the WRX harness plug is different. The WRX has a square plug with 4 prongs and the JDM has a rectanglur plug with 3 prongs.
I was told that this could be the problem what do you guys think?
Old 02-20-2005, 01:07 AM   #15
SoobyStu
Member#: 81045
Where are they near
Old 02-20-2005, 09:53 AM   #16
dwx
Member#: 8343
2005 2012 Jeep
2013 DGM BRZ
Yes that is a problem. Odd that the plug is different, I've never seen one that was. The car will be in limp mode without the speedo sensor hooked up.
Old 02-20-2005, 06:01 PM   #17
Ver.III
Member#: 1185
I flap my gums
and now I'm a specialist
There should be a short "pig tail" wire on your stock 5-speeds speedo sensor that has both square end to the 3 prong end.
Ver.III is offline   Reply With Quote
Old 02-20-2005, 07:00 PM   #18
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
Where are they near
its on the Driver. locate the timing belt cover, look to the verry top of it. you will see wires going into a little senser(cant remeber if u can see the whole senseor of just the female part). but the plug(female) will be fasing the back of the engine...
just wondering, how did u get so far into the swap and not know where some of this stuff is, and not know the problems that come w/ the wiring? (im not trying to be an @ss, but just curious how u got so far w/o having bigger problems)
Old 02-20-2005, 09:23 PM   #19
SoobyStu
Member#: 81045
Bigger problems? cmon if i was to install this engine,tranny,suspension,driveshafts,etc,etc, never done it before and it started first time with no problems, Think i would be Mcguyver
All is well now ,and i have had my fair share of problems.I bought my 2 years ago and only started modding a year ago.
Its the little things that slow you down like.
How do these drive shafts come out?
What is this plug for?
What is this Hose for?
And as for the tranny harness, when i sold it to the other guy i must of given it to him by mistake,unplugged it from where the firewall is instead of the tranny.
Old 02-20-2005, 09:25 PM   #20
SoobyStu
Member#: 81045
It's hard to remember everything in reverse when there's soo much to remember.
I find it easier if i know what it is, and whats its function.
Old 02-21-2005, 12:55 AM   #21
SoobyStu
Member#: 81045
Well just got the harness put in and well its like whan i got my WRX the first time, heart pounding speed, and the thought of this car gonna get me in trouble
Refresh on the conversion i done.
JDM ver7 engine, VF34
JDM ver7 suspension
JDM 6 speed ,lightened flywheel, and upgraded clutch
Cusco sway bars
390 rear diff
legacy driveshaft
huge topmount, M2 (never heard of the name)
I went from cobb 2.5 to this
Cost was about $5500 including swapping my WRX tranny and engine
Old 02-21-2005, 12:52 PM   #22
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
so u did all the laber yourself, or did u paysomeone to put the engine and tranny in for u and u did the wiring?
Old 02-21-2005, 01:03 PM   #23
SoobyStu
Member#: 81045
I took out everything on my own.
Had a freind help me put the engine and tranny in, he didn't know much at all about cars but never the less i couldn't have done it without him.
The best and easy part i thought was putting in the engine and tranny (attached) in. I found that preety easy do. I was told without a tranny jack the 6 speed would've been near impossible putting it in seperate
Took me 3 weekends
Now i think it would take me 1 or 2
Old 02-21-2005, 01:07 PM   #24
SoobyStu
Member#: 81045
As for wiring??? the WRX harness plugs straight up. The only wiring i had to do was AVCS i bought the harness from eastcoast scooby took about an hour very easy to do.
Old 02-21-2005, 02:18 PM   #25
snowman4us
Member#: 21764
Some GDM V8,
JDM Flat 4 X2
so is it all runing properly and evrything? or do u still have issues?
Just got my rebuilt motor 1996 2.2L! JPX Legacy Forum 30 02-24-2006 10:39 PM
Just got my ver7 motor coversion done! SoobyStu Southern California Impreza Club Forum -- SCIC 81 03-02-2005 03:48 AM
I just got my new insurance quote and.... tm999xxx Tri-State Area Forum 17 07-20-2004 08:50 PM
grr just got my first dent consolations and advice accepted Jejunum Interior & Exterior Modification 10 03-13-2002 02:16 PM
WoooHooo just got my tranny cooler installed and.... GregBolby General Forum Archive 7 02-17-2001 01:57 AM
